Navigation & Audio Anyone get the new portable NAV?
Old Jul 29, 2007 | 06:45 PM
  #126
bimmertim's Avatar
bimmertim
Originally Posted by z3bum
And the srf files?
The audio is a piece of cake. Just run a stereo headphone cable from the nuvi to your aux
input. I do this and use the nuvi as an mp3 player. When navigating, the music is interrupted by the guide voice as needed. Fun stuff.
Z3BUM,
What happens if your listening to the radio? Does the Nuvi still come through the car audio or does it revert back to the Nuvi speaker?
Old Jul 29, 2007 | 06:50 PM
  #127
ScottRiqui's Avatar
ScottRiqui
Originally Posted by bimmertim
Z3BUM,
No, the stereo can only monitor one input at a time (Radio, CD, CD Changer, or AUX). You need to have the head unit set to AUX in order to hear the GPS, which means that you can't be listening to the radio, a CD, or the CD changer input and still hear voice prompts from the GPS through the AUX input.
Old Jul 30, 2007 | 04:31 PM
  #128
ScottRiqui's Avatar
ScottRiqui
Originally Posted by pdoyle
Scott, could you possible post some pictures of your install?
Here are the pictures:
For the picture with the GPS mounted, I had the camera about where my head is while I'm driving, so you can see that the GPS doesn't block the Chrono Pack. To help make sure it wouldn't block anything, I mounted the post with the ball on it fairly high on the face of the Kuda mount.
My only complaint is that the covering on the Kuda mount is black leather, and the top of the dash is a dark grey, so it's not a perfect match. But it's not so far off that it bothers m, either.
Old Jul 31, 2007 | 04:16 PM
  #129
Sara'sMini's Avatar
Sara'sMini
Check out the my DIY alternative to the Kuda mount. Details at the following post
https://www.northamericanmotoring.co...7&postcount=31
Old Aug 4, 2007 | 10:38 PM
  #130
Scavenger's Avatar
Scavenger
I bought the external antenna for my Garmin Nuvi 360 today. I have the Nuvi mounted on the Kuda mount as shown above. It used to be that it would take several minute to locate satellites. Now, even on just battery, with the external antenna, as soon as it boots up it says "ready to navigate". That's a very nice improvement on signal reception!
Old Aug 5, 2007 | 02:38 AM
  #131
Sara'sMini's Avatar
Sara'sMini
Scavenger; Please forgive me for being argumentative. The definitive experiment to demonstrate the improvement in acquisition time accruing to the use of an external antenna is to measure the improvement in Satellite acquisition time after the NUVI has been turned off for 6 hours or more.
Background:
Presently there are just 3 competitors making top performance GPS chipsets, Global Locate, Media Tek and SiRF. The NUVI 360 uses SiRF but Garmin being a very careful company has turned off the "cold start" quick lock feature built into the SiRF chipset. This was done because Global Locate is seeking enforcement of Patents 6,417,801, 6,937,187 and 6,704,651 which cover the quick lock feature.
Here is a link to the story:
http://www.globallocate.com/PRESS/Pr...L_SuesSiRF.htm
If the slow "cold" acquisition is a bother, you can downrev the NUVI's formware to the version prior to January.
Go to the following link
http://www8.garmin.com/support/colle...t=010-00538-00
cut and copy the link into the wayback machine below:
www.archive.org/web/web.php
Go to the January 9 2007 copy of the page and download version 3.30 of the Unit software, programme it into the NUVI using the USB cable.
Version 3.30 will not include all the latest fixes to the SW, thats the price for quicker satellite acquisition. If you use the Bluetooth you might find the compromise unacceptable, depending on which phone you use with the NUVI.
Old Aug 5, 2007 | 06:43 AM
  #132
Scavenger's Avatar
Scavenger
I don't consider your post argumentative, but rather informative. My first use of the antenna yesterday was "warm" probably, since I turned it on and off within just a few minutes. So, I'll try it today now that it's been off over night.
Originally Posted by Sara'sMini
Scavenger; Please forgive me for being argumentative. The definitive experiment to demonstrate the improvement in acquisition time accruing to the use of an external antenna is to measure the improvement in Satellite acquisition time after the NUVI has been turned off for 4 hours or more.
Background:
Presently there are just 2 competitors making credible GPS chipsets, Global Locate and SiRF. The NUVI uses SiRF but Garmin being a very careful company has turned off the "cold start" quick lock feature built into the SiRF chipset. This was done because Global Locate is seeking enforcement of Patents 6,417,801, 6,937,187 and 6,704,651 which cover the quick lock feature.
Old Aug 5, 2007 | 07:19 AM
  #133
Sara'sMini's Avatar
Sara'sMini
Thanks for understanding my andragogical motives. I am irritated too at the slow cold start acquisition of the NUVI. The downrev option for me is impractical, I have the 660 which is currently at rev 3.80. I would have to go all the way back to rev 2.70 in order to benefit from the SiRF accelerated cold start feature. I can not figure out why Garmin do not periodically turn on the NUVI in the background every 3 1/2 hours for a minute to update the ephemeris data. If they just did this for 12-18 hours overnight 90% of us would get in our cars and have a "warm" welcome from our Garmin PNDs. Running the NUVI for 5 minutes total overnight would have nill effect on the charge in the battery. Im considering making a little circuit that powers the NUVI on for 1 minute every 3 1/2 hours as a work around for this issue.
BTW can anyone confirm that the battery actually charges from the car whilst the car is on and the NUVI is operational or is charging only done when the car is on and the NUVI is off?
Old Aug 5, 2007 | 04:47 PM
  #134
Minidrivr's Avatar
Minidrivr
Older firmware versions are available at this site.
http://www.gpsinformation.org/perry/nuvi/
I am sticking to an older version for my Nuvi 660 due to the change in the traffic display. The new interface for it is really annoying to me. I've never had the Nuvi take more the 1 minute to get a lock, moving, still, in my house, etc. Seems to work great. The chipset is a big improvement over Garmin's previous stuff.
Old Aug 5, 2007 | 06:15 PM
  #135
ScottRiqui's Avatar
ScottRiqui
Yes, the Nuvi charges even while it's operating, as long as it's plugged into external power. I've started off long trips with a partially-discharged Nuvi, and by the time I get where I'm going, the Nuvi is fully charged, even though it was operating the entire trip.
Old Aug 8, 2007 | 03:19 AM
  #136
rec's Avatar
rec
i installed mine into my R56 last night:
http://www.mini2.com/forum/general-d...ps-fitted.html
Old Aug 9, 2007 | 01:34 PM
  #137
mholtsberg's Avatar
mholtsberg
will these files work on a street pilot
Does anyone know if these srf files will work on a street pilot 330? Might be fun!!
any input would be appreciated................
Old Oct 17, 2007 | 07:48 PM
  #138
TWISTER's Avatar
TWISTER
Sorry no they wont
Old Nov 25, 2007 | 11:50 AM
  #139
d33jay's Avatar
d33jay
Thank you for posting the Nuvi Mini PICs. That was very nice of you. Now if I can only find some for the Classic Mini I will have for both cars
Old Jan 20, 2008 | 11:52 AM
  #140
STLMINI's Avatar
STLMINI
Anyone installed the garmin mount themselves? Any trouble with codes or computer?
Old Jan 20, 2008 | 04:16 PM
  #141
Brewmeister's Avatar
Brewmeister
Update? Your doing a clone of the factory mount?
Originally Posted by tom@kartboy.com
sorry i got carried away on the engine pitch mounts this weekend. i'll try and get to one this week. i'll see if i can get my friends car in the shop and see how much different the mounting points are from the R56
Tom
Old Jan 20, 2008 | 06:27 PM
  #142
abbydog3's Avatar
abbydog3
I did the install on my R53 using the official Mini mount.
No computer/code programming required.
You can do it!
Old Jan 20, 2008 | 08:43 PM
  #143
STLMINI's Avatar
STLMINI
Cool. I'm going to do it tomorrow night.
Old Mar 19, 2008 | 06:51 AM
  #144
cabriopilot's Avatar
cabriopilot
I know its a bit late in this thread but I felt it was necessary to thank Nor_Cal_Mini and Hunter99 for all their assistance with the MINI srf files.
Old Mar 19, 2008 | 02:16 PM
  #145
hunter99's Avatar
hunter99
Thank you. BBcooper here on NAM has been hard working on all sorts of custom SRF's that expand the files far beyond what Garmin and MINI ever did.
Make sure to give BBcooper a big shout out for this since the fair share of work goes that way.
I am been slowly, (very slowly) working to make a far better website out of it. In the future I would like to add a how-too and even custom files for other GPS units, including the factory NAV unit if possible. hat may take quite a bit of time but hopefully will get there soon.
Old Jul 26, 2008 | 07:23 PM
  #146
CarGuyNeil's Avatar
CarGuyNeil
This information was very helpful, thanks all for sharing.
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
The Rossness
Sep 17, 2015 03:06 PM
qwispichkn
Sep 17, 2015 11:28 AM
quality_sound
Sep 12, 2015 05:55 PM
