Navigation & Audio [eas] Official DICE iPod integration kit Q/A thread
Old Mar 4, 2007 | 08:35 AM
  #176
iflymini's Avatar
iflymini
Originally Posted by tom @ eas
Tim,
Glad MINI was able to get you back up and running. Here's the rundown:
CD1 = Songs within a Playlist
CD2 = Playlist Selection
CD3 = Albums within a Playlist
CD4 = Chapter search in Audiobooks
CD5 = iPod/AUX modes
CD6 = not used in MINI
Did you get an instruction manual with the kit? This will explain the features in more detail.
Thanks Tom! I think I do have the manual. Can't say I understand 'song browsing' though.
I think I may need to call you when in my GP. I can not control the ipod with my HU or MFC's. It will play through the stereo though.
Old Mar 4, 2007 | 10:15 AM
  #177
chipgrafx's Avatar
chipgrafx
Try rebooting the iPod by pressing the MENU & PLAY/PAUSE buttons on the iPod until the screen blanks out and an apple logo is seen. The iPod should not be connected to the DICE when this is performed.
Rebooting the iPod solved the problem of being able to use the controls on the iPod itself but the headunit no longer displays any scrolling text. All I get now is the disc and track info. Aside from that, everything is working fine. Any ideas about the text thing?
Old Mar 4, 2007 | 03:53 PM
  #178
tom @ eas's Avatar
tom @ eas
Press CD6/TRACK1 and return to CD1 for text display. If you would like one-on-one technical support, contact me by phone on Monday morning and I would be happy to help.
Old Mar 4, 2007 | 08:00 PM
  #179
chipgrafx's Avatar
chipgrafx
Worked like a charm... Thanks Tom.
Old Mar 5, 2007 | 11:33 AM
  #180
pjschaffer's Avatar
pjschaffer
Originally Posted by iflymini
Is there one for XM Direct? I hate the XM antenna on my roof (after other locations were tried).
There's no official MINI Part, but it is possible to mount the guts of the XM antenna under the base of the FM antenna. See this post for the coupe antenna or this post for the convertable antenna. It's actually pretty easy to do.
Phil
Old Mar 13, 2007 | 08:24 PM
  #181
nervenet's Avatar
nervenet
I have an 06 Cooper S with the nav system and I just installed the DICE. It sounds great but I can't seem to get it to release it's control of the nav system. Even when I turn the switches on the DICE to iPod Mode instead of DICE mode, it still wants to control the nav display. Is there a way for me to use the DICE and have it ignore the stereo and nav displays? I love the DICE, but not at the expense of using my nav.
Thanks,
Tony
Old Mar 13, 2007 | 08:31 PM
  #182
tom @ eas's Avatar
tom @ eas
Thanks,
Tony
At this moment, text display is not compatible with NAV. We are working on a solution and should have one shortly that can be solved with a simple firmware flash.
I would recommend turning off text display in the meantime, the iPod will still display the text on its screen.
Old Mar 14, 2007 | 09:00 AM
  #183
lintqueen's Avatar
lintqueen
Last words of advice
Ok, I have my DICE upgrade in hand (and have for several days, but I'm being chicken) and am ready to tackle it.
Where are the best instructions-for-taking-the-MINI apart to install the radio hookup with as many pictures as possible?
thanks!
Old Mar 14, 2007 | 01:17 PM
  #184
tom @ eas's Avatar
tom @ eas
thanks!
Email me directly and I'll provide some instructions for you.
Old Mar 14, 2007 | 04:13 PM
  #185
Kellonwheels's Avatar
Kellonwheels
I have that exact same car and am having the exact same issue. I will be eagerly awaiting a solve. Having the text display on the radio would be kickass, but taking control of my NAV is not so cool!
So how do I disable the text display for now?
Old Mar 14, 2007 | 10:50 PM
  #186
tom @ eas's Avatar
tom @ eas
Select DISC6/TRACK99 (pressing left arrow one time) to disable text display.
Old Mar 15, 2007 | 05:13 AM
  #187
nervenet's Avatar
nervenet
I have successfully disabled text display, and I'm much happier with the DICE now that I can listen to the iPod at the same time as using the nav. I'm looking forward to any sort of update that will restrict the text display to only the head unit, but for now this solution works.
Thanks!
Tony
Old Mar 15, 2007 | 04:55 PM
  #188
Kellonwheels
The DICE could be picking up interference from other devices in the vehicle. You can try relocating the wire to see if the noise is diminished or if you cannot find the source of the noise - a ground loop isolator must be used.
Some MINIs are more sensitive to engine noise than others. Here is a link to the version we offer on the website:
12 Amp Power Noise Filter
http://www.europeanautosource.com/pr...roducts_id=309
Let me know if you have any further questions!
Hey Tom - I just received my DICE, and this thing is awesome. What a great product!
I am having some trouble, however, that I am hopeful you can help me with. The issue is not so much related to the DICE, as it is my XM, but you may have ideas anyway:
I have a 2006 MCS with H/K stereo, NAV, DICE, and an XM Delphi SkyFi2.
Previously, I used FM modulation to hear the XM through the car speakers, and sound quality was about as you would expect. Not horrible, but not great. Now that I have an AUX input on the DICE, I thought I'd use it for my XM. The trouble is that I am hearing a LOT of engine noise when listening to the XM via the DICE AUX input - to the point where the XM is not usable. I am certain this is a problem with the XM, because when I connect an MP3 player to the AUX, there is no unwanted noise.
The XM is powered by the stock cig lighter plug.
Any ideas?
Old Mar 16, 2007 | 12:18 AM
  #189
tom @ eas's Avatar
tom @ eas
Any ideas?
The cigarrette lighter is not the best source - it's often referred to as "dirty power". Is there a way you can use another power source? If not, a ground loop isolator must be used.
Old Mar 16, 2007 | 11:52 AM
  #190
Kellonwheels
Yes - actually, I've already puchased a new 12v socket so I can wire the XM's power behind the dash.
What power source do you recommend I tap into for 'clean' power?
Old Mar 16, 2007 | 11:54 AM
  #191
tom @ eas's Avatar
tom @ eas
Try testing going directly to the battery for starters - this will deptermine if this is the problem or not.
Old Mar 16, 2007 | 12:41 PM
  #192
flingger's Avatar
flingger
Hey Tom...when do you need my car for more testing?
Sterling
Old Mar 16, 2007 | 12:50 PM
  #193
tom @ eas's Avatar
tom @ eas
Sterling
Were you able to get the new radio installed?
Old Mar 20, 2007 | 06:33 AM
  #194
FelixFJ40's Avatar
FelixFJ40
Forgive me if this question has been answered, but I read through the thread a couple times and didn't see it.
With the DICE unit, will my iPod turn off when I shut off the car, or will I need to turn the iPod off separately each time?
Old Mar 20, 2007 | 08:40 AM
  #195
MINI-IZED's Avatar
MINI-IZED
With the DICE unit, the iPod will pause playback immediately after turning the car off and 15-30 seconds later the iPod will power down automatically.
Old Mar 20, 2007 | 09:41 AM
  #196
tom @ eas's Avatar
tom @ eas
Old Mar 20, 2007 | 09:42 AM
  #197
FelixFJ40's Avatar
FelixFJ40
Great, thanks!
Old Mar 20, 2007 | 11:11 PM
  #198
anon0mus's Avatar
anon0mus
thanks!
I'm in a similar position as lintqueen only I have the HD DICE. I've e-mailed and am still awaiting to get the instructions, but in the meanwhile...can the instructions with pics be added to the EAS Knowledgebase?
Old Mar 20, 2007 | 11:17 PM
  #199
tom @ eas's Avatar
tom @ eas
If there is a MINI in the Orange County area, we would be happy to perform a complimentary installation in exchange for pictures for our knowledgebase.
Email me directly for details.
Old Mar 21, 2007 | 11:53 PM
  #200
CapWKidd's Avatar
CapWKidd
Dice With Pre-April 2005 HK HU With Nav....
So, will I get any text? The Icelink would sometimes show text on the nav, but the text would change size... what can I expect for text output on my car? Anyone have a POST April 2005 HK HU to sell me ?
Doug
