Navigation & Audio [eas] Official DICE iPod integration kit Q/A thread
Tom,
I just installed the Dice and everything works fine when the dice dock cable is connected directly to the ipod itself. When i connect the dice dock cable to the ipod dock then plugging the ipod onto the dock, the Dice doesn't recognize the ipod. I have a G4 20gb ipod and the car has nav as well.
Tom: more diagonsitic info
Tom:
Here is some more diagonistic info for the DICE with a 2007 Convert with Nav and H/K.
1. As I mentioned before, when the iPod goes to sleep, which usually is after 36-48 hours, the DICE does not recognize the iPod in terms of what track/playlist/album you are on. You can only change songs by changing CD3, the album selection. During this time, you can get the songs to show on the radio and as before, it takes over the nav.
2. New info: When you get back in the car after a couple of hours (not sure of the exact length but at least 2-3 hours), the DICE figures out where it is and everything works fine in terms of controls (mine still doesn't show the album or playlist name, however). If you had it show the song name and had the nav on in the previous step, then the songs names will show in the radio, but the nav goes back to normal (no DICE hijacking the nav)!
I did some testing and as long as you don't change the mode on the radio (changing out of CD changer/iPod to radio or other), all subsequent starts of the car will have the nav system working fine and the song names showing on the radio like it should. The only time the DICE goes back to taking over the NAV is when you change the radio mode.
Tom, this is provided so you have some additional feedback in performing your diagonistics. It seems that the mode button is what "reconnects" the DICE to the NAV and that left untouched (after starting and stopping the car/iPod) it seems that the DICE ends up doing what it should/want to do.
Tom,
Tom:
On a further note - do you have the following command in your NAV settings: NAVIGATION/GPS>MAPS? I do not have a MINI handy to check for myself at the moment.
If so, scroll to those selections while in iPod mode and let me know if this overwrites the text.
Tom:
I usually leave my Nav in the maps mode while driving. When displaying text, the DICE does overwrite the maps, but as mentioned, only the first time (when you select text) not on subsequent engine restarts (and again, only if you don't change the mode). If you change the mode, it overwrites the map with text (screen says Phone in upper left corner).
Only the HD Dice need an external HD Radio antenna that is included. the regular Dice unit does not.
Doing so can be very dangerous if involved in an accident and will case premature wear on the dock connector over time. This is why the DICE cradle is recommended if you do not want to use a dock cable only.
Can the antenna be hidden in the antenna base with the GPS?
Hi all,
I went to this thread twice and think I'm now more confused than before
I'm gonna pick up my 2006 MCC tomorrow. It got the H+K kit but I don't know if it has the CD Changer cable already in there, I will check.
- The DICE as trunk install (not HD) gets the power strictly from the CD changer cable, no other connections required, right ?
- The same power source is also routed to the iPod then of course, right ?
- If I don't mind I could leave the iPod in the boot instead of routing a longer cable to the front, right ?
- My radio will show me Song names, Album names (then Song names inside the album) but won't show me the name of the Playlist (but then again the Songname inside the Playlist), correct ? I assume that results from the playlist not having an ID tag ?
- Is there a difference between the tags for mp3 and say AAC files like the ones from the iTunes Store ? Both will show up as text, right ?
Sorry, I really don't want to short cut here or ask the same questions already answered but I really lost the overview.
Thanks,
Volker
Thanks,
Volker
Hi all,
There are no problems with the DICE & MINI other than text display with NAV-equipped vehicles, which is something that is under investigation at this time.
Sorry, you missunderstood. Wasn't implying too many problems (although I am a bit grumpy with my issue). My point is there is are multiple threads where the units are discussed:
[eas] Official DICE High Definition Radio (w/ iPod support) Q/A thread (3 Pages)
(15 Pages)
New info on DICE Electronics iPod adaptor
(17 pages)
Point is there are a lot of messages to weed through to try to find answers.
(15 Pages)
(17 pages)
(15 Pages)
(17 pages)
(15 Pages)
(17 pages)
Tom,
I read through the this thread and I still am a bit confused. I have a September 2002 build 2003 Mini. It does not play MP3s and currently has the OEM AUX adapter installed. I am interested in the Dice unit but I have a couple of questions.
1-What is the difference in the trunk or radio models? I think I have the changer plug in the boot but I am not sure. Of course I can look if necessary. You say the only difference is that you don't have to run the cable from the boot. Why would anyone want the boot model?
2-I will eventually be installing a Parrot Bluetooth unit too. Will this work with it or preclude the Parrot installation? What do you think the best iPod/Bluetooth option would be for a 2003 if not the Parrot?
3-I understand that my HU won't do ID3 tags but what will the HU display when I am using the iPod? I have a two spoke wheel. What functions will the buttons have. I think I can get my hands on an 05 HU that will play MP3s. Will this be any advantage for me other than the ID tags?
4-And if in the future I wanted to go with an integrated satellite radio (I am waiting for XM and Sirius to be one) will this be possible?
On behalf of everyone I thank you for your yeoman’s work on this thread. Clearly I am not the only one who is confused. <G>
Rich
Rich
Tom,
Rich
Rich
Let me know if you have any further questions.
Is the full functionality supposed to be supported with the DICE and the iPhone? When I connected my iPhone up, it warned me about not being an approved accessory as expected, I declined turning off the cellular services, but the iPhone would not allow me to interact with the iPod functionality. I could play, and I think advance to the next song, but the iPhone screen wouldn't display any info nor give me any controls. I guess I can use the DICE controls through using the station buttons, but it'd be nice to have the iPhone screen and controls to work with. Is it a problem with my setup, or is this the expected results?
-tank157
-tank157
-tank157
-tank157
...The only time you would require a trunk interface kit is if you plan to run OEM Sirius or XM Direct, which requires the trunk connectors.
No idea on the Parrot systems - we prefer the OEM Bluetooth system.
If you do happen to score on a 2005+ HU, you will regain text display on the radio. Do keep in mind that text display is on your iPod at all times.
There's no telling when the merger will take place, but most people prefer the XM Direct kits...
Sounds like the best of all worlds? Am I missing something?
Rich
