Navigation & Audio How to: Update Nav software/enable British voice
Old Jan 14, 2016 | 07:08 AM
  #226
robertcoyle's Avatar
robertcoyle
I purchased the BMW v32 navi from eBay, hopefully that works, will post when it arrives.
Old Jan 14, 2016 | 12:45 PM
  #227
actulsiz's Avatar
actulsiz
You should be good!
Old Jan 15, 2016 | 09:00 PM
  #228
robertcoyle
Hope so. On another note, I can't seem to eject the disc I burnt, any idea how to?
Old Jan 16, 2016 | 03:43 AM
  #229
actulsiz's Avatar
actulsiz
Take the key out the ignition and tap the eject button. It may take awhile to eject but it will. If that doesn't work, disconnect the battery for 5 min and reconnect, then press eject again.
Old Jan 16, 2016 | 05:22 AM
  #230
robertcoyle
Ok, I'll give that a try. Thanks.
Old Jan 17, 2016 | 06:34 AM
  #231
robertcoyle
So the disc arrived, put it in and the it ejects its self after about 30 seconds, could my drive need replacing?
Old Jan 17, 2016 | 07:13 AM
  #232
actulsiz's Avatar
actulsiz
Can you post a pic of the disc?
Old Jan 17, 2016 | 07:22 AM
  #233
robertcoyle
Here you go. So now I have a blank screen. Pulled the fuses so will try again later.
Attached Thumbnails How to: Update Nav software/enable British voice-image-1603279012.jpg
Old Jan 17, 2016 | 07:39 AM
  #234
actulsiz's Avatar
actulsiz
Hmm. Our disks are slightly different. My disk actually shows the Part# and the manufacture date. Are you sure that your disk is a original and not another copy? My was ordered directly from a BMW dealership. Look at my attachment.
Attached Thumbnails How to: Update Nav software/enable British voice-image-195288694.jpg
Old Jan 17, 2016 | 07:58 AM
  #235
robertcoyle
Oh, so I purchased a copy then, could that be why it ejects?
So I need to order from BMW, I did asking mini and they stock it anymore.
Old Jan 17, 2016 | 08:05 AM
  #236
actulsiz's Avatar
actulsiz
Can you send me the ebay link to where you purchased that disk? Yes, BMW & Mini do not keep that disk any longer. I only got mine because I knew a friend that worked at BMW and made a special order for my disk. It took almost a 1/12 months for me to receive the disk since it came directly from Germany. You may have difficulty finding it.
https://www.ecstuning.com/Search/Sit...891/ES2676160/
Old Jan 17, 2016 | 08:09 AM
  #237
robertcoyle
Ah, I see. So what would be my best option at this point. Here is a screen shot of the item number.
Attached Thumbnails How to: Update Nav software/enable British voice-image-2280846270.jpg
Old Jan 17, 2016 | 08:26 AM
  #238
actulsiz's Avatar
actulsiz
Do you have the MK4 nav? What year is your Mini? This update disk that we are talking about only works for Mini's that came equipped with the MK4 ie 2005/2006.
Old Jan 17, 2016 | 08:29 AM
  #239
robertcoyle
Mines a 2003, has the same unit as the item description picture, and the Service Manager at Mini it was to. Is there any where safe to download a copy?
Old Jan 17, 2016 | 08:33 AM
  #240
actulsiz's Avatar
actulsiz
Does your navigation system unit have cd-rom written on it or DVD?
Old Jan 17, 2016 | 08:35 AM
  #241
robertcoyle
It must be a CD-ROM
Attached Thumbnails How to: Update Nav software/enable British voice-image-2500231231.jpg
Old Jan 17, 2016 | 08:52 AM
  #242
actulsiz's Avatar
actulsiz
It must be a CD-ROM
Did you follow the install instruction like the link below? igniton on #1, drivers door open etc...?
Old Jan 17, 2016 | 09:05 AM
  #243
robertcoyle
I did yes, I'm wondering if I need to install the original software first as the system has crashed.
Old Jan 17, 2016 | 09:17 AM
  #244
actulsiz's Avatar
actulsiz
That's what I'm thinking. Maybe that should work. Then you can upgrade from that. The dealer should be able to install the original
Old Feb 9, 2016 | 11:48 AM
  #245
minihooligan773's Avatar
minihooligan773
On 2005 Mini Cooper how can you tell which version fireware you have in it?
Old Feb 9, 2016 | 01:33 PM
  #246
RB-MINI's Avatar
RB-MINI
There should be a code in the top right hand corner of the settings screen like SW 4-1/00
Old Feb 9, 2016 | 04:38 PM
  #247
minihooligan773
I have SW 4-1/50 how old is that?
Old Feb 9, 2016 | 05:08 PM
  #248
RB-MINI's Avatar
RB-MINI
Not sure, but I think SW 4-1/100 is the latest for the '05 DVD based systems. It has a 3D view mode and the auto cancellation of the safety screen after about 15 seconds. I haven't used the 3D mode, but having the safety screen disappear automatically is great. It's the only reason I upgraded.
Old Feb 11, 2016 | 12:48 PM
  #249
minihooligan773
If I buy 2015 update disk from BMW High DVD format I read online should work with the 2005 system. My question is will the DVD also update the fireware to 4-1/00 or do i need separate disk. Any one have a disk that works for sure they want you sell.
Old Feb 11, 2016 | 01:01 PM
  #250
RB-MINI's Avatar
RB-MINI
This firmware disc was a separate disc. Check with your dealer... the MA at my dealer was offering to upgrade the system for free a few years ago. It should take only a few minutes if no issues pop up. Also, the disc used to be available from MINI for about $9. Maybe Pelican or ECS can still get the disc.
The NAV map discs after 2009 are on two discs and not one. It probably won't matter unless you frequently cross territories of the discs.
