Navigation & Audio purchasing THE OEM 8.8 touchscreen from mini possible??
Old Nov 8, 2019 | 11:43 AM
  #101
6FT6's Avatar
6FT6
Originally Posted by Marios Pitsillides
This is exactly what i ordered. It came with all included as attached. It does not have the following:
miedmann
3. RING STOP LED 8,8" 65509354034 26.48 EUR bought on schmiedmann
4. CENTRAL INSTRUMENT TRIM 51459308343 20.94 EURbought on schmiedmann
But they do not matter at the moment since i cannot fit on the dash
Needed to edit my response, you need some more pieces.
Old Nov 8, 2019 | 12:46 PM
  #102
Marios Pitsillides's Avatar
Marios Pitsillides
Okay as a summary to understand...
I bought an F56 screen? which is has some correct parts (See below points 2 and 3 that i checked and written on the parts receive today) that are compatible to the F60
1.Central information display 8,8´´ TOUCH (6820386) - This is correct part right?
2. Central instrument 8,8" (65509354027) - This is the plastic around that does not seem to fit mine. What part do i need?
Still need to buy:
3. Central instrument trim 8.8´´ (51459332786)
4. Blind ring LED 8,8" (65509354034)
Points 3 and 4 are also needed to finish the "job", but if point 2 is wrong then i need to address this first right? It seems larger to fit my dash and put the screws on followed by the trim and blind ring.
Looking forward to advise/support!
Mario
Old Nov 8, 2019 | 01:02 PM
  #103
Agent007pr's Avatar
Agent007pr
Hi All!
I'm currently in need of some guidance. I'm trying to source a iD5/6 HU. I've found a source but I'm told that I will need a ATM Emulator to get GPS working in the HU while not using CarPlay. Is this required or am I getting offered the wrong HU?
Thanks!
Old Nov 9, 2019 | 04:58 AM
  #104
Marios Pitsillides
Hi,
A brief update. Managed to install correctly the 8.8 on the dash and coding was done. However, still no signal since my head unit in Entry Nav :( i need to change the head unit also so that the 8,8 screen to work (as told by an expert shop). Since wiring needs to be done they told me a price of 2,500 euros. Any advise/comments?
Old Nov 9, 2019 | 05:55 AM
  #105
maaii's Avatar
maaii
Try to code as below
CID_APIX_MODE Set apix2
CID_COLOR_DEPTH Set 24
CID_COM_MODE Set mii
Old Nov 9, 2019 | 10:20 AM
  #106
Marios Pitsillides
Hi,
unfortunately the shop is 2 hours away and i cannot go back at the moment to tell them to do it. They told me that nothing can be done if i dont change the head unit. Any chance that what you suggest will work?
any other thoughts? Thx
Old Nov 9, 2019 | 02:40 PM
  #107
6FT6's Avatar
6FT6
Originally Posted by Agent007pr
Hi All!
Thanks!
That is a BMW headunit, don’t purchase it as you will need to get the ATM emulator as they said. Also you will need to find a coder who is willing to convert the system from BMW to Mini. I bought one of these and ended up purchasing another that was a MINI HU.
Old Nov 9, 2019 | 02:47 PM
  #108
6FT6's Avatar
6FT6
Hi,
You possibly have the wrong CID cable for voltge.
If the settings that @maaii mentioned are done, it works. I’ve done the same with my EntryNav and the cable that was already in the car, when I swapped the 6" for the 8".
Old Nov 10, 2019 | 04:02 AM
  #109
maaii's Avatar
maaii
6820386 touchscreen CID is APIX2 , it needs 12v to work.
I am not sure your entry nav can work with this new CID of touchscreen.
Old Nov 10, 2019 | 06:10 AM
  #110
Bezlar's Avatar
Bezlar
Ok so I have sourced a 8.8 touch screen and the correct nav head unit for my f56. Coding was done on the head unit for my car. I’m wondering what other pieces I’m going to need to install this into my Cooper s. I have the 6.5 boost system. Do I need new led ring and housing? Any cables? What do I need to make sure my usb still works?
Old Nov 20, 2019 | 11:25 PM
  #111
Budgett's Avatar
Budgett
[CITA = Marios Pitsillides; 4503342] Hola,
Una breve actualización. Logró instalar correctamente el 8.8 en el tablero y se realizó la codificación. Sin embargo, todavía no hay señal desde mi unidad principal en Entry Nav :( necesito cambiar la unidad principal también para que la pantalla 8,8 funcione (como lo dijo un taller experto). Dado que el cableado debe hacerse, me dijeron un precio de 2.500 euros. Cualquier consejo / comentarios? [/ quote]
I have a mini countryman f60, I have an 8.8 screen that I want to install, can you please tell me what parts I need to install the screen?
Thank you .
Old Dec 2, 2019 | 07:28 AM
  #112
Banner28's Avatar
Banner28
Good Morning Ladies and Gents,
I currently have the 6.5" screen. I'm wondering what it would take in order to convert from the 6.5" screen to the 8.8" with navigation. I'm looking to convert to the in-dash navigation so I can get rid of my portable GPS that's attached to a Click and Drive system and make it a lot more sleek. What all would I need to buy in order to make the swap and get it working for navigation with satellite radio (currently have working)
TIA,
Cody
Old Dec 7, 2019 | 10:17 AM
  #113
6FT6's Avatar
6FT6
Why are people asking the same questions over and over again? There is so much info in the thread, all it takes is a bit of reading.
You answer one person about what it takes to retrofit the EVO and the person right after asks the same question.
Old Dec 8, 2019 | 02:35 PM
  #114
varma1986's Avatar
varma1986
I have purchased the "8.8" BM 6820386 04 Q" part to upgrade from my 6.5" to 8.8" display.My vehicle is a MINI COOPER COUNTRYMAN F60 2018.Please let me know if this is the correct part number?.Thank You
Old Dec 8, 2019 | 04:13 PM
  #115
varma1986's Avatar
varma1986
Is BMW Part# 6820386 04 Q the correct 8.8" display?.
Old Dec 8, 2019 | 04:59 PM
  #116
maaii's Avatar
maaii
Hi Sir
This is correct 8.8" display with touchscreen function.
Good luck.
Old Dec 8, 2019 | 10:11 PM
  #117
6FT6's Avatar
6FT6
Originally Posted by maaii
Hi Sir
Good luck.
If he doesn’t have a compatible headunit then touch won’t work.
Old Dec 9, 2019 | 02:50 AM
  #118
varma1986's Avatar
varma1986
I think you will need this part for replacement of your list item#2
https://www.outmotoring.com/central-...509367674.html
Part#Central Instrument: 8.8 (sku: 65509367674)
Old Dec 10, 2019 | 12:30 PM
  #119
Budgett's Avatar
Budgett
Thanks to this post, I have updated my screen from 6.5 to 8.8 inches, everything has gone perfect, my car a countryman f60. Thank you !
Old Dec 10, 2019 | 02:04 PM
  #120
varma1986's Avatar
varma1986
Thanks.
Can u give me a step wise walk through regarding coding.
Did U have to change the head unit as well to get the car play?.What coding does that need?.
I use an aftermarket Car play kit ti get Android connected-Wired & Apple Car Play wireless-Joye Auto Tech kit.
  #121
varma1986's Avatar
varma1986
Looks very nice.
Old Dec 10, 2019 | 02:58 PM
  #122
varma1986's Avatar
varma1986
I purchased a 8.8" Touch screen to upgrade my 6.5" touch display.The purchase comes with the head unit of whose image is enclosed.Can someone go through this picture and tell me what special features this head unit has & if it can be coded into a MINI Cooper Countryman F60?.
Old Dec 10, 2019 | 03:43 PM
  #123
6FT6's Avatar
6FT6
Short answer is no. This is a M.O.S.T interface headunit which is for fiber optic equipped BMWs.This will work with a 2011-2014 Countryman.
Old Dec 11, 2019 | 04:22 AM
  #124
Bezlar's Avatar
Bezlar
Got my daughters 2016 f56 cooper s retrofitted done. Thanks to a very nice forum member here who helped me source the parts and coding. Install was a breeze. And to the guy up a couple post asking why we are asking the same questions over and over again, if your not here to help than just don’t post anything. For some reading part numbers and trying to understand all the different nvt units is a daunting task.
Old Dec 11, 2019 | 07:15 AM
  #125
6FT6's Avatar
6FT6
@Bezlar Since you have singled me out in your post let me respond in kind.
I have assisted countless of members in the forum and have answered questions that have been repeated on a regular basis. There are only two or three members in particular that respond to questions in this post and if you have read through you will see who they are. There are also members who ask the same exact question back to back, their questions get answered, they go do something different then come back and ask the same questions again, if that doesn’t frustrate you the kudos to you; I am not about to call names as this is a free and open forum and I also never quoted you or anyone else in my said post.
I started off just like everyone else with no knowledge, but I read and read some more, then I asked questions that were not answered clearly before.
Do have a good day sir/ma’am.
Edit: Scrolled up to see your posts and you didn’t ask repetitive questions, so not sure what’s the deal.
