Navigation & Audio purchasing THE OEM 8.8 touchscreen from mini possible??
Old Oct 27, 2019 | 05:47 PM
  #76
maaii's Avatar
maaii
Hi Sir
I can't find "WiFi" certification logo on this head unit, so it may not be able to use Carplay.
Could you please take a picture of back panel ? I want to see all connector of this head unit.
Old Oct 28, 2019 | 12:39 AM
  #77
Marios Pitsillides's Avatar
Marios Pitsillides
Originally Posted by maaii
Hi Sir
Does this help? I want to replace head unit to get carplay! Thanks very much for the help
Old Oct 28, 2019 | 01:49 AM
  #78
maaii's Avatar
maaii
Hi Sir
On left side, i can see GPS & BT connector. There is no WiFi Connector.
Sorry~~~
Old Oct 28, 2019 | 03:21 AM
  #79
Marios Pitsillides
Hi Sir
Sorry~~~
I understand but my question is different. I want to remove this unit and replace it with another one that does have wifi, carplay, etc. is this possible??
Old Oct 28, 2019 | 04:31 AM
  #80
Marios Pitsillides
Does anyone know if this will fit my mini countryman f60 2017? Thanks in advance
Old Oct 28, 2019 | 06:28 AM
  #81
ndal's Avatar
ndal
Yes Marios. It will work.
Old Oct 28, 2019 | 06:40 AM
  #82
Marios Pitsillides
Hi,
any coding needed to work? I just plug and play? Has anyone done this?
Old Oct 28, 2019 | 07:04 AM
  #83
ndal's Avatar
ndal
Flashing, coding, custom FSC to match your cars vin is required. I have done it a few times.
Old Oct 28, 2019 | 09:52 AM
  #84
6FT6's Avatar
6FT6
Also need to get a usb cable as the EntryNav cable is not compatible with the NBT Evo
Old Oct 28, 2019 | 09:56 AM
  #85
Marios Pitsillides
Hi,
Can you help me or guide me on the process to do it?? Any help if much appreciated! Thanks a lot!!
Old Oct 28, 2019 | 10:19 AM
  #86
ndal's Avatar
ndal
If you shave the trim on the usb cable a bit and rotate it 180 works fine. new screen cable is probably needed though.
Old Oct 28, 2019 | 02:58 PM
  #87
6FT6's Avatar
6FT6
I’ve done that but only for bench testing, won’t advise anyone to ruin their stock end in the car tho.
Old Oct 29, 2019 | 01:03 PM
  #88
Bezlar's Avatar
Bezlar
Looking to upgrade my daughters f56 mini s. She has the 6.5 non nav system. Was wondering what parts I need to have the touch 8.8. Also could someone tell me if this screen would work.
thanks
Old Oct 29, 2019 | 05:46 PM
  #89
maaii's Avatar
maaii
Hi Sir
If you want to use 8.8 touch screen, this part number of 6820386 is the only one you can choice.
You also need to code it on HU_NBT_EVO for touch screen function as below
CID_TOUCH = AKTIV
CID_HMI_TOUCH AKTIV
Old Nov 7, 2019 | 02:30 PM
  #90
Marios Pitsillides
Can someone tell me what is the part no. for the head unit i need to buy to have carplay on my mini countryman f60 2017?
Old Nov 7, 2019 | 06:43 PM
  #91
6FT6's Avatar
6FT6
Any one of these
This was the headunit I bought and it works perfectly.
Old Nov 8, 2019 | 09:36 AM
  #92
Marios Pitsillides
HELP!!! I have finally received the 8.8 touch screen (6820386) to replace my 6,5 non touch version.
But it does not fit :( it seems that it is slightly bigger. Any advise??
also, why does it say no signal? Is it because i have not coded yet??
All i did was plug and play so far.
Any help highly appreciated!!
Old Nov 8, 2019 | 10:10 AM
  #93
maaii's Avatar
maaii
Hi Sir
Yes, you need to code it.
HU_NBT2 3005 DISPLAY_PIP_CONFIG CID_DISPLAY_RES Comment = Display-Resolution for CID from 800x480 to 1280x480
HU_NBT2 3005 DISPLAY_PIP_CONFIG CID_DISPLAY_SIZE Comment = Display-Size for CID from 6.5 to 8.8
HU_NBT2 3001 EXBOX DISPLAY_VARIANTE Comment = Type of display Display_Variante and change from schmal (German for narrow) to breites (wide)
HU_NBT2 3006 NAVIGATION DISPLAY_SIZE_RESOLUTION Comment = display size and resolution change from 800x480 to 1280x480
Old Nov 8, 2019 | 10:51 AM
  #94
Marios Pitsillides
Hi Sir
hi,
thank you about the coding.
my concerns is that it does not fit in the dash. Any insights???
Old Nov 8, 2019 | 10:52 AM
  #95
6FT6's Avatar
6FT6
What exactly can't fit? Did you get the CID for an F60 that has Nav etc? The CID protrudes a bit more to accommodate the headhunit.
Old Nov 8, 2019 | 10:53 AM
  #96
6FT6's Avatar
6FT6
Whats the serial number for the CID you have? It looks like the CID for an F56.
Also is the top tab broken off?
Old Nov 8, 2019 | 11:06 AM
  #97
Marios Pitsillides
hi this is my current screen (6.5). The whole part i bought (that has the touch and central instrument iri plastic) does not seem to match to sort of clip on and screw and then to be able to insert the plastic trim. Slightly bigger based on my understanding
Old Nov 8, 2019 | 11:09 AM
  #98
6FT6's Avatar
6FT6
hi this is my current screen (6.5). The plastic frame around does not seem to match to sort of clip on and screw. Slightly bigger based on my understanding
Did you not get the CID (plastic frame) for the 8.8"? The 8.8" can't fit in the 6.5" frame.
Old Nov 8, 2019 | 11:25 AM
  #99
Marios Pitsillides
This is exactly what i ordered. It came with all included as attached. It does not have the following:
miedmann
3. RING STOP LED 8,8" 65509354034 26.48 EUR bought on schmiedmann
4. CENTRAL INSTRUMENT TRIM 51459308343 20.94 EURbought on schmiedmann
But they do not matter at the moment since i cannot fit on the dash
Old Nov 8, 2019 | 11:36 AM
  #100
maaii's Avatar
maaii
You bought the wrong part.
65509354027 Central instrument 8,8"
And also need to buy this.
51459332786 Trim, central instrument 8.8"
