Navigation & Audio Aftermarket infotainment Options
Old Apr 27, 2020 | 10:30 PM
  #201
hardkhor's Avatar
hardkhor
Originally Posted by jiggersplat
Looks like the same one I have...
Got a link to the one you purchased? Would love to compare so that I can mentally prepare if I run into the same issues.
However, at the same time I'm hoping it's going to be different because it has at least a built in canbus along with other built in features that I hope will work from the get go.
Old Apr 30, 2020 | 01:13 AM
  #202
alejandro galeano's Avatar
alejandro galeano
Hi i'm new to the forum and new to this I have bought the same screen but from seicane.com, i've connected everything but sound has been my problem, please if you could guide me through this process. i bought the same as jiggersplat
Old Apr 30, 2020 | 05:15 PM
  #203
jiggersplat's Avatar
jiggersplat
Which factory stereo do you have?
Old Apr 30, 2020 | 05:16 PM
  #204
jiggersplat
I think I got mine from Erisin.
Old May 1, 2020 | 01:55 PM
  #205
alejandro galeano
I got the mini boost cd with the hk sound system and bought the screen from seicane still with no sound, couldn't make the amp to turn on
Old May 1, 2020 | 06:02 PM
  #206
jiggersplat
There is an amp turn on lead in the car harness. It was not connected in the harness that came with my stereo. You may need to add it like I did.
Old May 1, 2020 | 08:17 PM
  #207
alejandro galeano
Mine has it, I belive its a blue cable becasue it says amp con I am going to add fotos, if it was it for the amplifier where should I connect it ? I've been searching but nothing comes arround
Old May 1, 2020 | 09:41 PM
  #208
bnjmnpl's Avatar
bnjmnpl
I've scrolled through nearly every post in this thread, and I am a bit overwhelmed by how many options there are. Is there one of these bajillion head units that most people can agree is the best choice, or are they all kind of the same?
Old May 2, 2020 | 08:32 AM
  #209
bnjmnpl's Avatar
bnjmnpl
Has anybody tried out this model? https://4x4shop.ca/product/mini-coop...sb-multimedia/
It seems like one of the few that actually ships from North America, plus they have installation videos on their page, but I haven't heard much about it otherwise.
Old May 2, 2020 | 12:51 PM
  #210
alejandro galeano
It only works on reverse gear
I finally managed to find the 12v signal that triggers the amp but I got new problem guys don't know what it is. When im in any gear except Reverse the screen pop some kind of danger sing, if somebody knows what is happening please let me know I would be grateful, this is the only thong that stops from putting everything together.
Old May 2, 2020 | 06:58 PM
  #211
jiggersplat
Something is backwards. It thinks you are in reverse and is trying to activate the backup camera. Poke around in the menus and see if you can find a setting to disable the backup camera. FWIW, I ***think*** it is an orange wire that goes from the CD player/head unit to the screen that triggers the switch to the backup camera. The head unit is supposed to detect when the car is in reverse from CANBUS and then puts 12v on the orange wire. If you have to, you can cut that wire and the splice the piece that goes to the screen to the reverse light wire on the footwell module, or if you don't have a backup camera just leave it disconnected.
Old May 3, 2020 | 12:40 AM
  #212
alejandro galeano
I was going to cut the orange wire you are telling me but found out there where 7 of them and one is disconnected and its labeled : BACK, im posting some pics and a video about my issue sorry for bothering but this is driving me crazy and Im so grateful for your help.
Old May 3, 2020 | 06:15 AM
  #213
jiggersplat
Is the loose end going to the CD player? Try just grounding it and see if that helps.
Old May 5, 2020 | 01:11 AM
  #214
alejandro galeano
thanks alot for saving me all this trouble. screen is workin fine
Old May 18, 2020 | 10:40 AM
  #215
hawtdogflvrwtr's Avatar
hawtdogflvrwtr
Chime module
Red & black are power and ground. Pink/Blue and the one below it are CAN-H and CAN-L. Don't recall which one is which and apparently I didn't write it down anywhere.
For anyone curious, Pink is CAN-L, Pink/Blue is CAN-H
Old May 26, 2020 | 06:09 AM
  #216
hawtdogflvrwtr
Installed warning retainer chime thing
I installed the (lc-bmrc-01). Works a treat after mucking with it for an hour. Here's the hookup.
Only wires required to the unit when using an android radio.
  • Yellow
  • Black
  • Pink
  • Blue/pink
You can cut away the full harness and JUST KEEP THESE CABLES LISTED ABOVE.
Install:
***I connected to the radio side of the harness as not to screw up the factory harness***
  1. Disconnect the battery (I didn't, but it goes without saying)
  2. Connect the black ground wire to pin 12 (massive black wire) on the mini harness
  3. Connect the yellow wire to pin 15 on the mini harness (big yellow thick wire)
  4. Connect blue/pink wire to pin 9 from the mini harness (color varies it seems)
  5. Connect the pink wire to pin 11 from the mknk harness (color varies it seems)
Troubleshooting:
If you're not getting the chimes, check that the pink wire is connected. It needs both pink and blue pink to make the noises.
Thoughts:
Suck part is, I was hoping to get turn signal noises also because the one from the aftermarket radio sucks and stutters and sometimes goes 10 seconds after signals are off. Oh well. BTW, I confirmed this with the manufacturer. It doesn't do turn signal noises.
Old Aug 9, 2020 | 11:49 AM
  #217
hardkhor's Avatar
hardkhor
Quick question. Does anywhere know where the 12v reverse light wire is in the front of the car? My unit has a short plug coming out that's for the 12v reverse light wire. Usually you would tap from the trunk side but since the short cable originates from the unit, I'm guessing there's a 12v reverse light cable somewhere in the front side where the headunit is...
Old Aug 9, 2020 | 12:29 PM
  #218
jiggersplat
You don't need it with CANBUS but if you really want it, tsp to he FRM in the driver's door well.
Old Aug 9, 2020 | 12:34 PM
  #219
hardkhor's Avatar
hardkhor
It doesn't exist in the wiring harness?
Old Aug 9, 2020 | 12:36 PM
  #220
jiggersplat
CANBUS is in the harness. 12v for reverse is not.
Old Aug 9, 2020 | 12:44 PM
  #221
hardkhor's Avatar
hardkhor
Why would they include a cable that's so short then...
Old Aug 9, 2020 | 04:23 PM
  #222
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Why? Because universal harness.
Old Aug 9, 2020 | 07:41 PM
  #223
hardkhor's Avatar
hardkhor
Ended up not using that blue cable. On a sidenote, does anyone purchase a rear camera that sits more flush?
Old Aug 29, 2020 | 09:03 AM
  #224
Pentium4HT's Avatar
Pentium4HT
Originally Posted by GeneralSpecific
Yes, but if I remember correctly I had to cut a wire.
I have the optical connector so I bought an adapter but it isn’t working. Do you remember what you had to modify?
Old Aug 30, 2020 | 07:22 AM
  #225
scottyb043's Avatar
scottyb043
Apologies for posting this but after reading this thread and looking elsewhere, I haven't seen a definitive answer regarding installing one of these units in a 2010 R55 with the factory Nav. Mine has the second "slot". Anyone know if there is an option for this?
