Navigation & Audio Aftermarket infotainment Options
Old Oct 14, 2018 | 06:16 AM
  #76
carpecervisi's Avatar
carpecervisi
Originally Posted by darkturtleMCS
Did you have the factory Nav system before? I am curious what the LCI is and if that is what i could use to swap out my factory nav for something like this.
The LCI controls differ only in color. Pre-LCI were black and gray and that gray easily gets dirty and doesn’t wear well. The LCI controls are all black. I think it gives the center stack a nice visual upgrade.
I didn’t have factory nav, just the standard Boost system. These android units give an easy(ish) way to upgrade. The systems are pretty plug and play once you get the dash apart.
Old Oct 14, 2018 | 11:31 AM
  #77
darkturtleMCS's Avatar
darkturtleMCS
Carpecervisi, ahh, gotcha. I have the factory nav and it is horrible. Plus there are quite a few dead pixels. Anyone who sells these andriod aftermarkets all show that they are not compatiable with the factory nav but I was wondering if I just did a full swap, maybe with this LCI controls if that would work.It's almost like being punished for the original owner spending the big bucks for all the factory cool toys!
Old Oct 15, 2018 | 01:12 PM
  #78
treowx's Avatar
treowx
I have a couple of questions for people who have installed this unit.
Are you using the factory ground?
Does the unit use the OEM antenna or an adapter? I wonder if a ground loop isolator would help?
Its been a while since I have been on the car audio game but I remember back in the day when you would get an alternator whine it was usually a ground issue somewhere in the system.
I have reached out to the below to see if their updated system has fixed any of these issues.
https://www.hifimax.net/6-95-inch-an...2006-2013.html
Looks like the above will allow you to update to android 8.0 with 4gb ram and 32gb rom with an octacore processor.
These systems all look to be about the same just depends on who's factory the unit comes out of.
Old Oct 16, 2018 | 10:54 AM
  #79
treowx's Avatar
treowx
So my first attempt got deleted. I will try again without links.
Has anyone tried to use a ground loop isolator for the alternator whine feedback? I am thinking about ordering one of the nav units here soon.
Old Oct 16, 2018 | 10:58 AM
  #80
jiggersplat's Avatar
jiggersplat
I've had good luck with using those on other installs to get rid of alternator whine.
Old Oct 22, 2018 | 01:00 PM
  #81
howiestt's Avatar
howiestt
carpecervisi, do your steering wheel controls work for other apps beside built in? Doesn't work with my carplay adapter and other music apps.
Old Oct 24, 2018 | 08:26 PM
  #82
GeneralSpecific's Avatar
GeneralSpecific
Originally Posted by carpecervisi
I really like mine and think the sound quality is great...with the following caveat. Like others, I get serious feedback whine if my phone connects for a call via Bluetooth. I assume it’s the crap quality mic that is *somewhere*. It could be interfering with a factory mic, but I don’t think so. If my car had hands free prior to my upgrade, I never used it. And I just have the standard Boost stereo, not the HK with A-pillar speakers.
The stock ROM, as mentioned previously, doesn’t have the speedometer in MPH, but you can load other ones that take that negative away. I will post some screenshots later because I really like my current set up.
One ding I’ll give the unit is support. I’ve exchanged several emails with them asking for the factory ROM (I thought I made a backup but damned if I can find it) and they either don’t understand the request or are willfully not giving it to me. I can’t find it anywhere online and don’t want to brick it by loading an incompatible MCU.
A PX5 version of this head unit would be sweet, but I’ve never seen one. It performs very well, IMHO.
Good luck!
These aftermarket units don't use the car's mic, look around and you should see a hole on your unit, probably labeled "mic". To *vastly* improve your call quality, you'll need a secondary mic which can plug in to the back of the headunit. BUT, you also have to remove the built-in mic! Like, take apart the CD changer (in my case) and literally cut the crappy microphone out of it. If you attach a secondary mic, the headunit will still try and use the built-in mic AND the new mic. Have to remove the built-in one.
  #83
GeneralSpecific
Mine only works with the built-in stuff AFAICT.
Old Oct 29, 2018 | 01:08 PM
  #84
jiggersplat
Well I just pulled the trigger on an Android 8 version from Erisin. Fingers crossed. Feels a bit like gambling.
Old Oct 29, 2018 | 01:28 PM
  #85
Kittz's Avatar
Kittz
I am having this unit installed in my factory NAV R60 countryman as I type this.
AliExpress Mini Android Head Unit
Installer already called and said FM is not working... Pretty much what everyone else seems to have.
But the rest seems to be working so far... I will post an update after I pick the car up and play around.
Old Oct 29, 2018 | 02:03 PM
  #86
Kittz's Avatar
Kittz
I am having a 8 Core Andriod unit installed in my r60 Countryman that had factory NAV as I type this.
Installer already called said the FM is ****...
But other stuff seems to work. I will post more when I pick the car up and test some things out.
Edit: Adding more info about the FM on my 8 core android head unit. I picked up the car and the FM works fine. Just as good as the OEM Nav unit was. The installer couldn't pick up stations in the install bay. But outside the building it works great. Also the MIC and bluetooth calling features works pretty darn good as well. There is a background humming when making a bluetooth call though - But nothing deal breaking.
Old Oct 29, 2018 | 02:20 PM
  #87
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
can you post a link to the product you choose ?
Old Oct 29, 2018 | 02:22 PM
  #88
Kittz's Avatar
Kittz
Here you go (Hope link works)
Aliexpress Android 8 Core head Unit
Old Oct 29, 2018 | 02:26 PM
  #89
Kittz's Avatar
Kittz
Looks like my posts with the Links are requiring Mod Approval. So head to ali express and search for this text "Octa core 4GB RAM Android 8.0 Car DVD Multimedia Player for BMW Mini Cooper COUNTRYMAN"
Store name is Shenzhen Car DVD Playor Store
Old Oct 29, 2018 | 07:57 PM
  #90
Kittz's Avatar
Kittz
It won't let me post a link. It doesn't get mod approval.
But I can tell you it works great. The FM radio has no problems - it is pretty crisp and clear. No complaints so far except I can't get apple car play to work
Backup camera is awesome too..
File Type: mov
Old Oct 29, 2018 | 09:01 PM
  #91
Kittz's Avatar
Kittz
I just managed to get Apple Car Play working!
Also - If anyone is having problem with FM you can try wiring the Antenna's blue wire to the amp CTRL wire in the harness. (Pic Below)
Try wiring FM antenna to the harness for FM problems
Last edited by Kittz; Oct 31, 2018 at 08:37 AM. Reason: Added pic and more info about FM
Old Nov 8, 2018 | 11:06 AM
  #92
Jakomcbean's Avatar
Jakomcbean
Kittz, how did you manage to get CarPlay working? Might be worth the trouble if it works well. I dont lie the double DIN approach much.
Old Nov 8, 2018 | 11:16 AM
  #93
Kittz's Avatar
Kittz
I bought an in-line apple car play adapter that you plug your iphone into and then the adapter plugs in to the head unit. You install an android APK and then every time you plug your iPhone in, Carplay automatically launches. It works very reliably.
Old Nov 8, 2018 | 12:38 PM
  #94
jiggersplat
why would that help?
Old Nov 21, 2018 | 09:06 AM
  #95
Kittz's Avatar
Kittz
It is what the manufacturer suggested. Probably to supply power to the powered antenna (That wouldn't be powered without this setup)
Old Nov 21, 2018 | 09:08 AM
  #96
Kittz's Avatar
Kittz
You buy an Apple car play adapter and install an APK on the the android head unit. Then whenever you connect your iphone to the adapter, Carplay automatically launches.
Old Dec 1, 2018 | 02:04 PM
  #97
mrbubba's Avatar
mrbubba
Do any of these units have DAB?
I've had Chinese Android units in other cars and they were ok for what I paid (about £250), but always had one issue or another with each one.
My biggest issue would be if the fuel, EML and Speedo work properly.
The standard stereo is pretty poor, as I've just come from and Bang and Olufsen setup in my previous car.
Old Dec 3, 2018 | 07:11 PM
  #98
jiggersplat
Great googly moogly what a PITA to get to the stereo on this thing.
Complaining aside, I have my unit "installed" but there is no audio. There is mention previously in this thread about having to do "cut a wire" or something to get it working with the harmon/kardon amp, which I have. Does anyone have any more specific information than that or know where I can find it. The search terms are just coming up with a thousand people with blown H/K amps.
Also, I had two antenna cables into the back of the stock head unit, one with a black connector and one pink. I assume one is AM and one is FM. Anyone know which one is which?
Old Dec 3, 2018 | 07:30 PM
  #99
GeneralSpecific
Ahh ottomh I think it was a blue wire but it's been ages. I had to cross reference the install instructions from the manufacturers' website against my Bentley service manual wiring diagram. Hopefully someone else can chime in with more recent memory.
Old Dec 6, 2018 | 06:37 PM
  #100
jiggersplat
I will answer some of my own question... the HK amp will turn on with 12v applied to pin-13 (black wire) of the quad-lock connector. The harness supplied with my kit did not have pin-13 populated so I had to splice it into the car harness (or I'd have to find the pins that fit the quadlock connector and add it). It does not require activation via CANBUS as some threads on this forum have suggested.
BUT, there's a but. It's loud as ****. The lowest setting on the head unit is still super loud. I'm going to try and get an X9331 harness and splice a 4-chan line out converter and see what that does. I was under the impression that the HiFi/HK inputs were speaker-level inputs, but perhaps not. Hopefully it doesn't knock the signal down too much. I'm not sure line out converters are meant to be used like this though. I don't know if there will be any load on the head unit amplifier, which would be bad.
