Navigation & Audio Navigation DVD / player issue
Old Apr 2, 2015 | 06:12 AM
malsalah's Avatar
malsalah
Hello There, I am new to this forum and I apologize in-advance for any incorrect posting or any abbreviations. I just bought a 2008 Mini Cooper S with Navigation System option (sticker price $2000.00). The DVD is a 2008 version (old). Every time I turn the Navigation system on I get the message to insert the DVD, however, the DVD is already inserted, I cleaned the DVD several times, I even copied it and inserted the new copy, but keep getting the same message. I cleaned the DVD player using the CD/DVD lens cleaner. The player does play music when I install the music CD in it. My system is the stackable CD player and a DVD player for the DVD maps where DVD a face goes over facing the player. Wondering if anyone had this issue and how to start fixing it...would an updated DVD solve the problem, could it be a DVD player issue? I appreciate any input on this issue and welcome any feedback...Thank you so much….Mark
Old Apr 2, 2015 | 07:21 AM
geeks2you's Avatar
geeks2you
Are you insetting the navigation DVD in the top drive slot, or the one behind the lower control panel? If you press the small button on the right side of the lower control unit, the entire module will pop off and there is another dvd slot where you put the Nav DVD.
Old Apr 2, 2015 | 07:31 AM
malsalah's Avatar
malsalah
This is exactly what am doing...thank you for the picture..yes I remove the face cover and insert the DVD in the player (the bottom one) but nothing happens, keep asking me to inser the DVD. I even inserted the DVD in my comuter to see if it was corputed, was able to read it and open files. ...Thank you
Old Apr 2, 2015 | 07:35 AM
malsalah's Avatar
malsalah
my undestaning that the top one is a CD player and the bottom one is a DVD player for the MAPS...my dvd is the orinignal from 2008, is it possible is old? is it possible the DVD player is going bad even though it plays music when I insert a music CD in it (the bottom one)?
Old Apr 2, 2015 | 07:47 AM
geeks2you's Avatar
geeks2you
I have a 2010 DVD and it still loads up fine. My only problem is that I only have a European DVD since my Mini was built in Germany and driven there until last year. The service department is still trying to figure out how to make my Nav work here in the states.
Not sure about your question of the music CD playing in the bottom and then not reading the DVD.
Old Apr 2, 2015 | 09:16 AM
JPMM's Avatar
JPMM
you might install the disc and let it wait for a great while.
Old Apr 2, 2015 | 10:11 AM
malsalah's Avatar
malsalah
I had the disc in the player for hours at one time...twice it worked for probably 30 minutes then I got the message to insert the DVD even though it's in the player...Thank you
Old Nov 22, 2015 | 03:22 PM
BlackMagicMini's Avatar
BlackMagicMini
What was the outcome of this DVD issue? I have the same issue in my 09 MCS. Display says to insert DVD but it is in and always has been in and has never been taken out until today. I've inserted and ejected multiple times but unit will not read it. I can hear it spinning so the drive seems like its running. Anyone have the solution to this? What does a replacement unit go for?
Old Nov 22, 2015 | 09:04 PM
malsalah's Avatar
malsalah
I ended up replacing the top part of the player, the one you insert the maps DVD in, took it a part sperated it, actually my brother did most of the work. I bought it from the local Mini Dealer, I believe it was under $200, not sure of exact amount as it has Been several months, you have to take the broken part to dealer to get the $125.00 core charge, I think it was $125.00, I can look up the receipts. It has been working perfect since (knock on wood), using the old scratched up DVD.
Old Mar 20, 2016 | 07:51 AM
vtt316's Avatar
vtt316
I'm having the same issue with my 2009 clubman s. Do you happen to have the part number? Also was it an easy install? Thanks in advance!!!
Old Mar 20, 2016 | 08:31 AM
malsalah's Avatar
malsalah
I am sorry I don't have the part No, I could not find it, the dealer should find it when you explain what you looking for. It's the DVD player part replacement for the gps DVD player. I think it took about 1 1/2 hour. My brother owns a small used car lot and a small shop where he does all repairs for me. If you're a little handy you should be able to do it. I am not handy so he does it for me and I pay him. Hope this answers your question...good luck.
Old Jul 1, 2016 | 11:32 AM
andysinnh's Avatar
andysinnh
Having a similar issue with my '08 Cooper w/factory nav. In my situation the DVD player doesn't recognize the nav disc when it gets really hot (like sitting in the sun during the day). Once the car cools down (evening) it starts to work again. In other forums I've read that it's a sign that the DVD player component is failing and you need to replace it.
What I'm trying to figure out is whether the DVD unit itself should be replaced. My local dealer's online ordering system shows the following:
Part Number: 65839241764
dvd unit 2007-10
PARTS: Part included with ctrlr MSRP Core ? Save Online Price
$125.21 $200.00 $25.04 $100.17
Old Jul 4, 2016 | 06:41 AM
vtt316's Avatar
vtt316
that sounds about right for the pricing. let me you tell it wasn't easy to take out the unit out of the car. unless you really know your way around the mini be prepare to spend most of your day getting it out and putting it back together. cheers!!!
Toolman
Jan 20, 2016 06:50 AM
clintmeister
Aug 27, 2015 12:08 PM
minicoclub
Aug 25, 2015 09:07 AM
