Navigation & Audio Change aux input to USB/Aux input
Old Aug 28, 2014 | 01:15 PM
Dr_Romulus's Avatar
Dr_Romulus
Hey guys. I was wondering if there is an easy way to tell if I can swap the aux only input on the stereo in my 2008 Cooper S for the input with Aux and USB? I've been googling and I can't find any info that helps me figure out if this is possible or not.
Old Aug 30, 2014 | 09:55 AM
Aelwulf's Avatar
Aelwulf
+1 I'm looking at a possible iPad kit but not sure if those include such an update. Any gurus that have an inside track if it's just a plug/cable swap or more's required?
Old Aug 30, 2014 | 10:17 AM
rkw's Avatar
rkw
MINI has a retrofit kit for USB+Bluetooth (both functions integrated in one electronics module). Parts + installation would be quite expensive.
http://www.motoringfile.com/2009/10/...-retrofit-kit/
Old Aug 30, 2014 | 11:11 AM
Aelwulf's Avatar
Aelwulf
Oi yeah, that's one's up there. I think I've seen plug-in BT mods of some sort that would be cheaper, and could do without the USB. It'd just be nice to have. So might be waiting a bit.
Old Aug 30, 2014 | 12:20 PM
Dr_Romulus's Avatar
Dr_Romulus
Yeah that seems crazy. You can get a BT-to-Aux unit for about 50 bucks. It doesn't let you skip tracks with the wheel controls but that's easy enough.
Old Oct 9, 2014 | 02:13 PM
Friedrice's Avatar
Friedrice
So i found the jack that has the usp/3.5mm. Looks like just a plug and play deal but I have no idea if it will infact work. Anyone try this yet?
http://www.ecstuning.com/Mini-2007-C...tem/ES2703734/
Old Oct 9, 2014 | 05:26 PM
CornerCarver's Avatar
CornerCarver
I'm interested in an alternative too. For now I bought a $25 bluetooth to aux module from best buy and it works great, but it lacks the steering wheel controls.
I found a kit on ESC Tuning, but I'm not having any luck finding a how-to.
http://www.ecstuning.com/Search/Usb/ES1599517/
Old Oct 10, 2014 | 06:31 AM
"So i found the jack that has the usp/3.5mm. Looks like just a plug and play deal but I have no idea if it will infact work. Anyone try this yet? "
You cant just plug it in and works. Thats for MINI that already have that socket duo for replacement, and would require some work and coding, which I have never seen done.
Just like the PDF linked above. One of the coolest and most integrated option Bluetooth w/ Music option.
http://www.motoringfile.com/wp-conte...578087307c.pdf but we found the dtat shows Production: 8/2007 - 8/2010 Gen 2 R56+ MINI.
Main install unit , using factory steering wheel controls ( if you have them ).
http://www.ecstuning.com/Search/SiteSearch/65412152530/
ULF Module High 84109229740
http://www.ecstuning.com/Search/SiteSearch/84109229740/ES1906933/
Convertible only requires ES1599508 & ES1305534.
IF using with iPhone 4:
Y cable ES255927.
Here is some more info a on how to do it.
https://www.northamericanmotoring.co...-delivery.html
Old Oct 10, 2014 | 01:36 PM
Blind Dog Daddy
Y cable ES255927.
I've installed over a dozen of thesein the past 5 yrears or so and cannot believe the expense. It's a labor intensive job that requires programming after the installation.
Old Oct 11, 2014 | 06:28 AM
Dr_Romulus's Avatar
Dr_Romulus
So, are you saying that if you currently have the one that just has an Aux plug you can swap it for this one?
That's the deal in my R56.
If that is the case do you know if it will actually play mp3 files from a thumb drive or pass audio through from a phone (pandora, google play, etc) or does it just charge a device?
I'm thinking an Aux plug BT module is my best bet but an extra USB to charge a device would be nice.
Old Oct 11, 2014 | 09:06 AM
rkw's Avatar
rkw
  1. It will play mp3 files from a thumb drive.
  2. It does not pass audio through the USB. You can use the aux input, but that is already possible without this option. It can read music files from a phone's storage if set up like a standard USB drive (however, it doesn't support MTP interface which is the default on most newer Android phones). With an iPhone and Y-cable, the headunit can read song information and send play commands, but audio still goes through the aux input. Really, this was already outdated technology when it first became available in 2008.
  3. The USB port is too low powered to charge most phones. It was designed for thumb drives.
Old Oct 21, 2014 | 03:44 PM
Friedrice's Avatar
Friedrice
So i just have the standard aux imput and it crackles like a mad bastard at any vol over a low wisper. I have the Nav head unit, factory blue tooth. I cant play **** through the aux without it sounding like the speakers are blown. Think its just the aux jack itself or is it something else? Cable from the aux jack back to the stereo?
Old Dec 24, 2019 | 10:18 AM
Lipofskyphoto's Avatar
Lipofskyphoto
Certainly the easiest thing to check is to try a new cable. That would be my first guess as to the problem.
If that's not it, spray electrical contact cleaner or 90% isoprophyl alcohol into the jack and work the plug a few times.
If that's not ti, it's very easy to pull the Aux jack from the dash and replace it with a parts yard one for next to nothing.
Old Dec 24, 2019 | 10:22 AM
Lipofskyphoto
Regarding adding USB.
My car came with a boost radio with Aux, but not USB.
I got a Boost radio with phone and USB from a parts yard for $50. The unit worked perfectly, but after hours of homework and trying , I concluded that I could not get USB or even Aux to work in my car with this radio.
The Mini that I took the USB radio from had a very different wiring arrangement, even though the radio's connections appeared identical.
Old Feb 1, 2020 | 07:57 PM
Lipofskyphoto
I now have Aux in. I got the identical radio to my original (no usb or phone) at a parts yard for $50 and the Aux works fine.
Old Feb 21, 2020 | 06:32 AM
donnellycolton's Avatar
donnellycolton
Currently have an aux-only module in '09 2-door, does anybody happen to have a wiring diagram for this? Can't find one anywhere. Trying to replace the module, but the wire harness that plugs into it is stuck, so I'll have to cut the wires, and want to make sure that I'm putting the right wires back in the right places.
Also, even though I only have the aux-only module, is there somewhere behind the radio that I could potentially get 5V+ power?
surfblue
Oct 24, 2018 01:20 AM
khumpert
Nov 30, 2015 11:48 AM
D3nZem
Aug 30, 2015 07:05 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
