Navigation & Audio Longer Y cables?
Old Apr 9, 2014 | 08:49 AM
paulsonm's Avatar
paulsonm
Longer Y cables?
Just picked up my 2014 convertible (1st time Mini owner) and shocked that no iPhone 5s compatibility or voice-activation is included. I have a lightning adapter which works with the Y cable but the cable is so short. Anyone use a longer Y cable they can recommend? I did not get NAV (as the salesperson told me it wasn't needed) but now I feel like I should have gotten it, nor did I get the iPhone snap-in holder.
Old Apr 9, 2014 | 01:15 PM
timp's Avatar
timp
I got a standard 'old style' Apple extender cable from Amazon - you can then put the Lightning adapter on the end of that. Y cable and extender are black but the Apple Lightning adapters white - doh!
Old Apr 9, 2014 | 07:19 PM
Btwyx's Avatar
Btwyx
I used a USB extender cable and a 1/8" audio jack extender cable. Eventually I soldered them into the unit in place of the USB and audi tails.
When I had to use a different y-cable I didn't bother and just put my iPod in the passenger footwell cargo net.
Old Apr 24, 2014 | 05:27 AM
Smoothmove's Avatar
Smoothmove
Amazon Amazon
Works great but you still need the lightning adapter
Old Apr 24, 2014 | 11:31 AM
yetti96's Avatar
yetti96
I use the standard y cable to a .2m lightning adapter to a lightning extension cable. It usually works but is sketchy.
Before my iPhone5 I had a 30 pin extension and it worked great, so when I got the 5 I added the adapter to the end of the 30pin extension and it charged but no audio signal worked.
So it works most of the time but it isn't perfect.
I am going to look into A2DP adapter and just use a 1a charger for power as I consume power using waze faster than the car can charge it.
Old May 1, 2014 | 01:44 PM
bratling's Avatar
bratling
Super Moderator
I tried one of those. Works with older iPods and iPhones, but not with anything that requires the Lightning adapter. :-(
Old May 7, 2014 | 12:07 AM
Werther Dong's Avatar
Werther Dong
I tried the same, Y+30pin extender + 30pin to lighting adapter, but there's noticeable static noise. so now i'm using y cable + 0.2m apple lighting adapter, barely enough long to reach the iphone5 on cravenspeed scissor phone mount.
Old May 7, 2014 | 04:02 AM
danjreed's Avatar
danjreed
Factory Y > Cable Jive 30 pin Extension > .2m factory Apple lightning adapter
No static, nothing falls out, everything works the way it should.
Old May 8, 2014 | 04:50 PM
bratling's Avatar
bratling
Super Moderator
Originally Posted by danjreed
Factory Y > Cable Jive 30 pin Extension > .2m factory Apple lightning adapter No static, nothing falls out, everything works the way it should.
Thanks! Going to try this.
PsychoRallye
21
Feb 17, 2019 06:08 AM
minimofo
Dec 26, 2015 12:03 PM
rikaro
Nov 24, 2015 02:05 PM
ahorvath
Oct 3, 2015 01:13 AM
MINI Stupor
Oct 1, 2015 11:36 AM
