Navigation & Audio Bluetooth & Aux DEAD HELP
Old Jul 22, 2012 | 12:07 PM
schumm's Avatar
schumm
My Bluetooth & my Aux are completely dead. When I try to select the phone or the Aux as an option, it no longer shows I have them. The Aux is gone as a option to select. Please tell me it's not the ECU
Old Jul 23, 2012 | 04:32 AM
schatzy62's Avatar
schatzy62
Which bluetooth do you have?
Bluetooth or Bluetooth w/USB?
If it is Bluetooth W/USB it sounds as if the bluetooh module has become disconnected or has gone bad or maybe the fuse for it is bad and it is not turning on.
Old Jul 23, 2012 | 06:29 PM
schumm's Avatar
schumm
Blue tooth & Aux DEAD
Hi,
I have a 08 MCS Clubman with the built-in Bluetooth. I checked the fuse it looks goods. I have 4 audio choices on my stereo. Tuner, CD, Aux, USB. The Aux choice is now gone. It's completely gone. Are the two related? Are there wires near the passenger side foot area??
Old Jul 24, 2012 | 05:32 AM
schatzy62's Avatar
schatzy62
If you have a USB option on the screen normally then i am hoping you have a USB port under the center stack switches. Yes/No?
If that is the case then the audio for the AUX runs thru the bluetooth module. And in that case they would be related.
What kind of confuses me (and i may be reading your post incorrectly) is that you have no AUX selection but you still have a USB selection. Am i right or wrong on that? It makes a big difference.
Old Jul 24, 2012 | 11:39 AM
schumm's Avatar
schumm
Yes, The Aux option is not there anymore. The USB option is there,as is the phone option, but they both have a -- above the word like there is nothing connected. Can I replace the Bluetooth module myself?
Old Jul 24, 2012 | 12:26 PM
alexs3d2's Avatar
alexs3d2
You can, but it may not be the module itself: I would suspect a break in the MOST ring.
The MULF is only connected to the rest of the ECUs through an optical MOST ring. If the optic fibers are bent too much, then the light won't pass through.
Old Jul 24, 2012 | 12:34 PM
schumm's Avatar
schumm
My wife and daughter drove my car to Vegas, and they told me they were banging on my glove box to get it closed. Could something in that area been affected by this. Maybe a loose connection.
Old Jul 24, 2012 | 12:37 PM
alexs3d2's Avatar
alexs3d2
Possible... The ring runs behind the glove box so that it is possible for you to upgrade the car to the multi-disc changer system. When that is not present, then the connector there must have a loop. Maybe that came loose, or broke altogether.
Old Jul 24, 2012 | 12:49 PM
schumm's Avatar
schumm
How do I access that area to check
Old Jul 25, 2012 | 04:27 AM
schatzy62's Avatar
schatzy62
You still have not given us much detail on what radio system you have in the car.
Do you have HD radio, or OEM Navigation (in the speedo), in the car. If you have either of those and they work then it is not the MOST Bus.
Also it it was the MOST Bus then the USB option and Phone option should not show up either on the screen as the radio will not know that they exist.
It sounds more like a bad module to me.
Is the floor near and under the drivers seat wet or damp?
Old Jul 25, 2012 | 04:31 AM
schatzy62's Avatar
schatzy62
And also back on an 08 model there would not have been an optic loop back adapter on the optic lines behind the glove box it would have been down by the Junction Box Electronics (fuse box) and if a CD player was to be installed then the adapter would have been taken off at the junction box and the line up behind the glove box connected. Or at least that is how all the 08 and 09 cars i have worked on have been.
Old Jul 25, 2012 | 12:51 PM
schumm's Avatar
schumm
no, is the module under the drivers seat under that panel.
I have the OEM radio in the speedometer
Old Aug 6, 2012 | 12:49 AM
JohnBa's Avatar
JohnBa
My Bluetooth is also not working. I have Bluetooth with USB ('08 Cooper S with Premium pack, Boost head unit, HiFi speakers, No Satnav). When the phone starts with - - and then goes to the handset. The USB works, but when listening to the iPhone for 20 mins it goes to USB in the display (no audio) and about 60 seconds goes back to iPhone.
I'd like to check the module. Where is it?
Any other suggestions?
rikaro
Nov 24, 2015 02:05 PM
schr5530
Oct 5, 2015 08:28 AM
schr5530
Oct 1, 2015 05:11 PM
jennster
Sep 28, 2015 06:19 PM
