Navigation & Audio Shuffle setting For iPods - help!
Old Jan 20, 2009 | 12:18 AM
GregSpeakEasy's Avatar
GregSpeakEasy
Just purchased an 09 MCs. I want to put the shuffle setting on while I listen to my connected Ipod through the cable they provided connected to the bottom right half of the center console. I would try selecting shuffle songs, then plug in my ipod and try to change the songs after that with the steering wheel song skipper, or even with the other controls that change the songs, but for some reason they end up going into a playlist, or going in alphabetical order of the songs. Is it possible to play my ipod on shuffle settings in this modern vehicle? I was able to do it in my parents 08 Scion with the same cable and similar system.
I JUST WANT SHUFFLE!
rofl. Thanks guys.
Old Jan 20, 2009 | 07:38 AM
Kazy's Avatar
Kazy
You pick the option on the MINI. Under iPod, the "RND" button stands for "RANDOM", which is the option you want.
Old Jan 20, 2009 | 09:20 AM
Btwyx's Avatar
Btwyx
However the RND option doesn't stick, you have to turn it on every time you start the MINI. I've taken to randomising the playlists in iTunes before I sync the iPod, so I don't need the RND button.
Old Jan 21, 2009 | 06:14 AM
flyinlow's Avatar
flyinlow
The button on the steering wheel will select the next song in order, regardless of whether you have the RND button on or not.
It kind of sucks, any other device I've ever used when you have it on random, when you hit the next button it picks the next random song, not the next logical one.
Old Jan 21, 2009 | 06:29 AM
bentyyc's Avatar
bentyyc
Hmmm... I don't think that's true for everyone. In my '08 Clubby, hitting the "Next" button on the steering wheel does indeed select the next "random" track, if "RND" was selected first.
Might want to check that...
Old Jan 22, 2009 | 06:06 AM
flyinlow's Avatar
flyinlow
I have a 120gb iPod classic, the difference might be is that I have the integrated Ipod adapter in my Mini, I'm not using the Y cable. I'll have to give the Y cable a try and see if that works differently
Old Jan 24, 2009 | 10:39 PM
codemonkey's Avatar
codemonkey
No, it's like that for me too. Even specifically notes it in the manual. I have taken to just turning RND off and then on again, it picks a new random song.
EDIT: '09 justamini with the base stereo system, MOST ipod kit.
Old Jan 24, 2009 | 11:20 PM
Kazy's Avatar
Kazy
I can't tell whether mine does it or not with the next button. I randomize my songs on iTunes, but as far as I know it's randomizing when I hit "NEXT"
09 Justacooper with iPod/Bluetooth kit.
Old Jan 27, 2009 | 08:51 AM
flyinlow's Avatar
flyinlow
That's what I have to do as well to get it to go to the next random song.
Old Jan 27, 2009 | 01:27 PM
woohoo's Avatar
woohoo
I had this problem at first too (with the Y cable). First, we created a playlist on the ipod of all the songs and then in the MINI selected the playlist called "everything" then hit the "RND" button and it played in random order.
Then we figured it out without using the playlist...
If you put your ipod on shuffle songs BEFORE you plug it in the Y cable, and then select the "RND" button in the MINI it should play in random order. If it comes to song you want to hear the whole album for, just deselet the "RND" function. You can then re-select "RND" once you are ready for the shuffle function again.
Whenever the MINI gets stuck in a playlist/artist/genre etc, I always unplug the ipod and then make sure the ipod is on random song shuffle before plugging back in. And the steering wheel next button does select the next random song.
Of course, this is all meaningless for me now b/c my ipod was stolen!!! ergghhh.
Old Jan 27, 2009 | 06:08 PM
kuba_kuba's Avatar
kuba_kuba
on my '08 MCCS I sometimes need to switch the RND "on" then "off" then back "on" again to get the desired Shuffle effect. I usually wait about a minute between switching between the modes. Usually works as advertised though. I use the Y-cable.
Old Jun 19, 2009 | 07:58 PM
SDJoe's Avatar
SDJoe
BUMP
I have an O8 MCS and I have an Ipod Touch connected via the Y cable. When I hit RND and hit the next button, the next song played is a randomly selected song. Great!
However the RND button does not stay on when I start the car again. Is there a way for the RND button to be on all the time. As the OP stated, I just want Shuffle!
Thanks again
Old Jul 5, 2009 | 09:01 AM
dnr's Avatar
dnr
I have an 08 Clubman and an iPod Shuffle. I use the cable that came with the Shuffle, i.e., phone-jack to standard USB. I plug it into the in-dash USB port and all the information about the music shows up on the mini-dash. My issue is that no matter what I do, it always plays random. This is independent of settings on the iPod or setting the RND button on the iPod. Even this would be okay, except for the fact that of over 100 songs on the iPod, it plays a repeat pattern of about 25 songs and pushing buttons just cycles it through those 25 random songs. I know that they are random, because I know the order they were placed on the iPod. I also know that you cannot get it out of the loop. I don't know if this is a Shuffle issue or a Mini issue.
Any thoughts?
Old Jul 26, 2009 | 11:43 AM
Hmmm's Avatar
Hmmm
I am using a USB thumb drive, and always have the RND selection on. I am finding that while the MINI isn't playing the songs in alphabetical order, it's always playing the songs in a certain order.
For example, if I listen to song A, song D, and song X one day, and then come back to the car the next day, the MINI will start playing where I left off with song X. If I hit the back button, it will play song D, and back again and it will play song A.
So, I think the MINI loads the playlists, randomizes them once, and then keeps them in that order.
Ahh, well. I am still stoked that it reads my thumb drives. So much nicer than plugging in my iPhone all the time.
Old Jul 26, 2009 | 12:16 PM
dnr's Avatar
dnr
A thumb drive sounds nice. I agree that it makes the playlist and then repeats it. My problem is that the playlist is about 25% of the number of songs on the iPod.
Old Jul 27, 2009 | 02:31 PM
Hmmm's Avatar
Hmmm
Try this... seems to work for me. I use mediamonkey for managing songs on my thumb drive and my iPod. I had to stop using it for my iPhone because the jerks at Apple basically broke the functionality of mediamonkey with the 3.0 update.
In mediamonkey, sync your playlist to your iPod. This will copy over not only the music, but the playlist as well. Then, connect the iPod to your MINI, and load the playlist rather than using the directory listing.
Tis how I do it with my thumb drive and it works great!
ps
I picked up a new 4gig thumb drive for $15 bucks at the PX, really can't go wrong there!
Old Jul 27, 2009 | 04:34 PM
CarJon's Avatar
CarJon
I have an 09 MCS with the y cable iPod interface. Until about 2 weeks ago the RDN setting would stick. I would turn it on and it would always be on. Now I turn it on and if I shut the car off for 5 minutes (fill up time) the RDN sticks. If it is shut off for a longer the RDN setting is no longer checked. It is driving me nuts. I have done nothing new. The iTouch I use for music in the car never comes out of the car and stays plugged in.
Wish I could figure out what is different now.
Waszak
Oct 21, 2017 05:55 PM
dscott90000
Sep 9, 2015 07:55 AM
OutMotoring
Sep 8, 2015 06:27 AM
Ntety
Sep 2, 2015 08:39 PM
tag1260
Sep 2, 2015 07:42 PM
