Navigation & AudioBring your GPS and favorite CD or MP3. This is where navigation and audio options for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
I have a Kicker 10" and an amplifier. I have all the wiring and everything prepared. But do I need a RCA converter or is there some other way I can wire the head unit to the amplifier? And what do I hook the remote wire to in the head unit?
You will need a line out converter that converts the speaker signal to low level RCA output. I am unsure on the remote out, but possibly wire it to a switched 12v wire.
If your amp can take speaker wire input, just tap the rear speaker lines and run them to the amp, then to your sub. I've heard others have done this successfully. But I am no electrical engineer.
