Navigation & Audio DICE electronics iPod connector
Old Jul 25, 2008 | 02:44 PM
mini19's Avatar
mini19
I have a r56 w/o hifi. Will a Dice Electronics(I-BMW -T) work to connect my iPod? I used it in my 5 series and thought I would try before I did anything else.
Old Jul 25, 2008 | 03:46 PM
nicknbecka's Avatar
nicknbecka
The R56 changed over to the MOST bus, so the DICE iPod connectors won't work.
EDIT: Doh, past DICE connectors won't work, the RDS model linked below does, since it's an FM modulator and not connected to the car's network like previous models.
Old Jul 25, 2008 | 03:55 PM
tom @ eas's Avatar
tom @ eas
You have your choice of 2 kits:
DICE - Universal RDS iPod Integration kit for BMW & MINI
http://www.europeanautosource.com/pr...oducts_id=1909
mObridge - iPod integration kit for MINI Cooper
http://www.europeanautosource.com/pr...oducts_id=1653
Old Jul 27, 2008 | 04:56 AM
richs10's Avatar
richs10
Ok, incoming Noob question:
What the heck is DICE?
I googled,
I wikied,
Closest I get is something about getting names of songs to appear on the stereo readout screen?
What does it mean and why is it called DICE?
Thanks, Rich
Old Jul 27, 2008 | 07:29 AM
mini19's Avatar
mini19
Here is a link for a Dice electronics product.
I used on in my 525i, it worked great. All controlled by the factory syste, I guess not with my Mini
Old Jul 27, 2008 | 08:15 AM
bobj's Avatar
bobj
Check out:
http://www.newministuff.com/new/shop...roducts&cat=28
Old Jul 27, 2008 | 12:37 PM
richs10's Avatar
richs10
OK then, DICE is just a brand name?
Old Jul 27, 2008 | 04:39 PM
tom @ eas's Avatar
tom @ eas
Correct, a brand name.
Old Jul 27, 2008 | 10:39 PM
nicknbecka's Avatar
nicknbecka
Also, ICE is often used as an abbreviation for In Car Entertainment.
Old Aug 5, 2008 | 07:04 AM
SuperGreg's Avatar
SuperGreg
So the only way to get steering wheel control is to pay $599??
Old Aug 5, 2008 | 09:17 AM
nicknbecka's Avatar
nicknbecka
It's still way cheaper than a retrofit.
Old Aug 5, 2008 | 09:19 AM
SuperGreg's Avatar
SuperGreg
Actually the dealer quoted me $600 to retrofit the integration kit into the secret compartment. I'll just use the aux jack
Old Aug 5, 2008 | 09:58 AM
tom @ eas's Avatar
tom @ eas
The MINI kit is available for a bit less, but offers less features.
Old Aug 5, 2008 | 09:59 AM
nicknbecka's Avatar
nicknbecka
Sorry, I was comparing to a retrofit of the USB/iPod bit (which I've seen people report to be quoted $1000-1200), since the USB port is offered with the mObridge and it also bypasses the 250 track limit- yeah the iPod adapter that goes in the secret compartment is about the same.
Old Aug 6, 2008 | 01:54 PM
MCEnvy's Avatar
MCEnvy
Hey everyone, timely that I found this thread, as I'm looking at doing this on my own. A few questions:
- What specifically is the difference between the one you'd buy from the dealer and the ones offered here (ie. dice, etc)?
- Has anyone actually installed this on their own? If I buy the dealer-sold one, looks like the radio has to be programmed by the dealer. Can I not do this one my own?? (Info from: http://www.outmotoring.com/mini-coop...interface.html)
Thanks!
Old Aug 6, 2008 | 03:27 PM
tom @ eas's Avatar
tom @ eas
Thanks!
MINI iPod kit limitations:
- It takes a long time for the artists and albums listings to load. You can only see the first 250 artists or albums w/o nav and the first 500 w/ nav.
- You cannot shuffle play the entire library of songs on your iPod. You can only shuffle play the first 500 songs w/o nav and the first 1000 songs w/ nav. The solution to get around the shuffle play limitation is to create playlist containing 500 or 1000 songs.
- When you restart your car the last song playing does not start where it stopped, but starts over at the beginning.
The mObridge does not have these limitations.
Old Aug 8, 2008 | 10:18 AM
TOPLABDOG's Avatar
TOPLABDOG
Tom,
I had a couple of questions. Does the Mobridge allow full control via the steering wheel? Any additional requirements for install. I have the standard OEM CD palyer w/o Navagation. How hard is it to install? Have you sold the system to any NAM menmbers?Any chance of being able to look at the instructions?
Old Aug 8, 2008 | 11:55 AM
tom @ eas's Avatar
tom @ eas
Originally Posted by TOPLABDOG
Tom,
We've sold the kits to a few MINIs, not sure if they were NAM members or not. All control is via the steering wheel or radio.
Old Aug 8, 2008 | 12:05 PM
eyevin68's Avatar
eyevin68
i too am interested in this set up. will the Dice also give you mf wheel control?
can you rate the installation on a scale of 1 to 5, 5 being difficult. and how detailed are your instructions? as detailed as crutchfield?
Old Aug 8, 2008 | 12:13 PM
eyevin68's Avatar
eyevin68
1 more thing but probably not the last thing . i have a r55 w/out nav. i want to upgrade my system. is this a possibility?
DICE High Definition Radio w/ iPod Integration (MINI) and what else would i need.
Old Aug 8, 2008 | 01:43 PM
tom @ eas's Avatar
tom @ eas
MFSW controls and steering wheel control are the same - the mObridge offers this. On a scale of 1-5, I would rate this as a 2.
Your MINI will need to have CD Changer programming in order to utilize the kit, this can be programmed at any MINI dealer.
Old Aug 10, 2008 | 03:50 PM
mini19's Avatar
mini19
I don't have steering wheel controls, will this still work via the radio controls?
Old Aug 11, 2008 | 11:37 AM
tom @ eas's Avatar
tom @ eas
Absolutely.
Old Aug 12, 2008 | 07:47 AM
eyevin68's Avatar
eyevin68
Tom, what about the Dice Hi Def radio w/ ipod integration is this compatible with the R55?
Old Aug 12, 2008 | 09:54 AM
tom @ eas's Avatar
tom @ eas
Unfortunately, no - only the MINI or mObridge kit is.
USNAE2
16
Jun 17, 2022 07:17 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
pglgp1292
Aug 9, 2017 12:45 PM
schr5530
Oct 5, 2015 08:28 AM
