Navigation & Audio MINI Cooper wall thread, version 2
Depending on which subs you use, and whether you go with a sealed or ported enclosure, you're probably looking in the 8-10 cubic feet range. Going with a sealed enclosure means you need less enclosure volume, but for a pure SPL system, it's kind of hard to beat a properly-designed ported enclosure.
yea, you cant do sealed with these subs, they will perform like complete butt
the box, surprisingly, is going to be around 15-17 cubes gross, then minus the subs displacment (.5 ft^3 for both) and the displacement for the port/internal bracing.
cut the odd side pieces out. most of you will be confused, but im gonna get more done tomorow, and you will understand as the pictures progress, as to why its cut like it is.
9.5* angle
dry mock-up
sorta what im going to do tomorow. the sides will extend out with the side trim, thats why the side pieces are cut like they are.
one of the 18s, i may not even use this, im not sure yet
random pic
glued the sides down
9.5* angle
dry mock-up
random pic
not bolted down yet.
deleted the rear wiper. that plug will be there until i get a rear back up camera. im selling my Nakamichi head unit, as much as i like it, but i want to get a double din screen with Navigation. ill have to relocate the a/c controls, etc
not much done today...by the time i got home from work it was 5ish, then had to go somewhere at 8 so....
ill do this to the other side tomorow probably.
does it sort of make more sense now as to why the sides are like that?
just to throw this out there, i AM fiberglassing the ENTIRE interior of the box for added strength, and to ensure is 110% air tight.
no, seriously, the reason there was so much glue slop on the last one, was becuase i didnt have the little squirt bottle of TiteBond II, i just had the gallon bucket.
needless to say, i bought the 5 dollar squirt bottle
2 18"s...Woah, that would be rediculous...do we even have the airspace without a box???
