Navigation & Audio Kuda mount and GPS installed
Old Dec 31, 2007 | 09:37 AM
minibayb's Avatar
minibayb
Just wanted to say that I successfully installed the Kuda dashboard mount and a new Garmin 650 in my wife's Mini over the weekend. Wanted to thank all those who have posted hints and techniques which made this install go very smoothly. I actually printed out Lancning post with the pics and went to the car, very informative and very helpful. Great work guys and thanks again.
Old Dec 31, 2007 | 10:58 AM
celica414's Avatar
celica414
yeah, i've printed out the DIY too (very, very helpful), but now i'm stuck on where to hide the wires, did you hardwire yours?
Old Dec 31, 2007 | 01:05 PM
Creeve's Avatar
Creeve
im hardwiring my garmin, ordered on of these: http://www.partsexpress.com/pe/showd...number=265-570
and an add-a-circut. should be pretty straight forward
Old Jan 1, 2008 | 04:18 AM
minibayb's Avatar
minibayb
Yes, I hardwired mine. When I had the dash panels off for the Kuda install I just tucked the wire behind the panels and ran over to the passenger footwell area then got an add-a-circuit kit(got mine from Advance Auto here locally) for the install. Fairly straightforward and makes for a nice neat looking install.
Old Jan 1, 2008 | 07:24 AM
celica414's Avatar
celica414
how many amps did you use in the new fuse and what fuse location did you go to? I went to F32 with a 7.5 amp fuse
Old Jan 1, 2008 | 02:08 PM
minibayb's Avatar
minibayb
Same here on the circuit, used F32 but for no in particular reason. I thought about using the one for the CD changer as I don't have the 6 disc changer, at least that's what I thought that symbol meant(several plates stacked on top of each other) but went with what has worked for others. I did reuse the 7.5 amp fuse then added a 5 amp for the Garmin and works fine. It should not pull very many amps although I didn't research to find out.
Old Jan 1, 2008 | 02:44 PM
celica414's Avatar
celica414
cool, i added a 7.5 amp for the Garmin, i hope it's not too much ( i didn't see it written anywhere as to how much to use) Does your Garmin power on and off with the ignition?
Old Jan 2, 2008 | 06:13 AM
minibayb's Avatar
minibayb
Yes, powers on with the ignition and powers down with engine shut off.
DixonL2
Apr 13, 2021 08:05 AM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Phantogram
Aug 12, 2015 12:11 PM
