Navigation & Audio hard wire of nuvi
Old Jun 26, 2007 | 03:55 PM
Bobbyn's Avatar
Bobbyn
hard wire of nuvi
hey guys
i'd like to hard wire my nuvi.....can i eliminate that barrel resistor thing?
thanks
bob
Old Jun 26, 2007 | 07:10 PM
z3bum's Avatar
z3bum
The NUVI uses a mini-usb connector. I think Garmin may sell a bare-wire version of the connector. If not, you should be able to buy one online somewhere.
Not sure about significantly changing the factory 12v connector. The easiest thing to do would be to hide a 12v socket in the dash and plug the connector into it.
Old Jun 26, 2007 | 07:41 PM
Bobbyn's Avatar
Bobbyn
i guess i can leave that thing on.....since my nuvi is mounted up top i wanted to pick up power in the overhead light switch / sunroof pane
bob
Old Jun 26, 2007 | 09:34 PM
crash13's Avatar
crash13
Double check the output voltage of the lighter adapter. I was ready to cut off the adapter for my XM radio to hard wire it in to the car, but the output of the adapter is 6V. I may get a spare to dissect, although mounting an extra socket is probably the easiest way to go.
rob and the Blue Shifted MINI
Old Jun 27, 2007 | 10:08 AM
Bobbyn's Avatar
Bobbyn
hey rob
thanks for the input...yes i checked it nd its a 5 or 6 volt output. i'll have to put in a spare cig plug. i did that on my other mini on the passenger side for my laptop.
any idea which of the wires under the driver side kick panel will be a good accesory on wire?
thanks
bob
Old Jun 27, 2007 | 04:16 PM
crash13's Avatar
crash13
I'm not sure on wiring. My plan is to wire into the lighter. I like the fact that it is switched power. The power switch on my XM is a little flaky - last thing I need is to get in the car in the morning with a dead battery because the radio didn't shut off.
Old Jun 27, 2007 | 08:11 PM
Bobbyn's Avatar
Bobbyn
you can go right to the fuse box...it's just that it's on the other side. i do this stuff all the time i just thought someone may have already done it. i'll poke arounf with my metter or just run awire over
bob
Old Jun 27, 2007 | 08:43 PM
Meltz's Avatar
Meltz
I used one of these to connect from the fuse box to the Nuvi:
http://cgi.ebay.com/Direct-Hardwire-...QQcmdZViewItem
Old Jun 29, 2007 | 08:00 AM
Bobbyn's Avatar
Bobbyn
thanks for the reply.....i decided to just add a pwr port / cig lighter in the rear of of each footwell...one for my nuvi and the other for my laptop. i used an add a circut for the line
bob
Old Dec 29, 2007 | 09:15 PM
ekailee's Avatar
ekailee
Hey guys,
I'm really confused! Does anybody have a good way to hard wire my nuvi.
1. What voltage does the nuvi need
2. Waht is the barrel resistor
3. I thought to just cut the lighter plug and h/wire it (don't think this is right.
4. Found in other thread about fuse extenders
on and on You see my confusion.
Old Dec 29, 2007 | 10:26 PM
MINIBee's Avatar
MINIBee
I bought a lighter socket with bare wires at radio Shack. I attached the hot line from the socket to an Add-a-circuit and that went to the fuse box. The other wire from the socket went to ground. Then I plugged the stock cigarette lighter cord into the socket under the dash and ran the wire to the NUVI.
eliseo1981
Sep 30, 2015 01:53 PM
minimofo
Sep 30, 2015 12:26 AM
Filmy
Sep 7, 2015 08:27 PM
mikeandtricie
Sep 4, 2015 01:42 PM
Sep 1, 2015 04:02 PM
