Tigger 2.0
I want I say and hope it's a bad wire, because my friends early 2011 had a newer HPFP installed under warranty
mQubed Motorsport, Manic Tuning Dealer
Turns out a bad wire was not to be. The fuel pump is still not responding to ECU commands. New pump is arriving today. Maybe Tigger will be my Christmas present this year lol.
Well damn, damn and double damn. New pump and wire harness didn't solve the issue. The builder managed to get his hands on the wiring diagrams for the old and new harness and had to relocate one pin to work with my ECU. Still no joy. I even tried to upload a tune from a 2014 ECU. Unfortunately, while the TriCore 1797 processor is the same, some of the other hardware in the MEVD17.2.2 and MEVD17.2.7 is different. Even with the correct vin and other code copied the ECU would not boot on a test bench. So apparently it looks like the only option at this point is to replace the 2014 intake cam with a 2011 cam and use the older style Continental HPFP.
My guess is you must use the 2011 cam to make use of the continental HPFP. Will you still be able to get a 2011 cam with the added 1 mm lift to work?
I wish that were an option but BMW considers their data proprietary.
Yeah the problem is the interface where the pump mates to the cam. They are completely different. The older N18's have what looks like a T that fits into a fork on the cam similar to the N14 whereas the newer Bosch pump has a triangle shaped fitting that fits into a machined recess in the cam. I'll post some pictures up when I get a chance.
On the other issue...machine the parts to fit? (I'm in California and have a mini lathe and micro mill you can use)...set up in my garage...I have made some billet aluminum gps mounts for a few R56 and GP2's...swivel ***** and such...one with a dual mount radar detector plate
Thanks for the offer but I'm on the other coast. Your suggestion did give me an idea though. I went and took a very close look at the interface at the end of the cam on my old head. It's a bit hard to tell but it may be possible to swap the ends. It appears to either a be separate end piece or its a machined shear point that would allow the end to shear off if the HPFP seized. I'll clean it up and use some dye penetrant on it Monday. Then I should know which it is.
Glad I could help...good luck
Your welcome. I just passed along what Dan at Mach V had already gone to the trouble to find out. I haven't been able to find anyone running 245 tires without rubbing. It might be possible with a 38mm offset but I think the arches would have to be heated/reshaped or replaced entirely. Had lots of compliments on the 235/40's though. Gives it an aggressive look and sticks like glue.
N18 Camshaft Research
Short Tigger update. Have one final experiment to try involving Ohms Law before spending $650 on a new intake camshaft and having to wait 5 to 15 days for it to get here from Germany. Not sure if my idea will work as I have not been able to get any hard data on the input response profiles of either of the pumps. One or the other could be linear or curved. Nobody at BMW is talking so we'll see what happens.
On a more interesting note I started taking measurements off my old head and recording lobe offset, rocker ratios, etc. and found a few things that made me go Hmm...
#1. Its possible to increase intake valve lift to 10mm by simply increasing the eccentric shaft lobe height a small amount when the valvetronic solenoid has the eccentric shaft rotated into the full throttle position. This could be accomplished by removing the eccentric shaft and having part of the lobes plasma sprayed and reground. I verified this by placing a feeler gauge between the eccentric lobe and intermediate rocker arm and measuring intake valve lift from the seat. The math worked and valve lift came out to 10mm on the nose. This approach would have the advantage of not altering idle quality at all. The alternative would be plasma spraying much more material on the intake cam lobes PLUS re-profiling the eccentric shaft lobes to restore idle and cutoff. Didn't get a chance to experiment further for 10.5mm of lift. However, I doubt you could get much more out of the intake geometry without beginning to compromise the stability of the intermediate rocker arm.
#2. The exhaust camshaft lobe offset and profile appears to be very similar to the N14. Unfortunately, the N14 camshaft can not be used as it has no provisions for a vanos actuator. The solution would once again involve plasma spray and regrinding to increase lobe offset.
From a manufacturing standpoint the costs for an eccentric shaft should be less than that of an intake cam (less material, less machining etc...Based on that it might be possible to actually manufacture a cam kit consisting of an eccentric shaft and exhaust cam for approximately the same or even slightly less money than an N14 kit.
Sorry no mention of the amount of material that would need to be applied to any of the lobes in #1 and #2. (For reasons see paragraph previous to this one
.) All hypothetical anyway until the cams can to be prototyped and thoroughly tested.
I gotta say Tigger, your thread definitely puts mine to shame. With all your hypotheticals and thorough analyses, you've really delved deep into the N18's which I haven't seen anyone do before. Good job.
When do you see the project getting completed? My old block is gathering dust at the shop, hope to work on it when I'm done with this project...!
RA and Tigger...You both are very impressive in your technical knowledge and skills...with that said...there are engine builders out there that I have used (El Monte, California...Hokenson Automotive) that have custom ground camshafts and crankshafts for my race motors in the past. Maybe you can hook up with one to give you a custom grind or at least some good info...I suppose the "end switch" didn't work out on the HPFP thing...?
Do any of us ever truly complete our projects? I'm already thinking ahead to XTA coilovers with lower control arms and drop links all around. That will have to come after the meth and tuning showdown though lol. If I can resolve the electrical control issue with the Bosch HPFP maybe this week. Made some enlightening progress today. I was surprised to find out its possible to get 200 bar of fuel pressure at idle. Unfortunately, had to order a component that wasn't available locally and is coming from Ohio. It's possible that the light at the end of the tunnel might not be the train I thought it was.
Stage 5 anyone?
Thanks for the extra leads. I had initially planned to contact LSM and Crower. Ideally I'd like to be able to use the same company for prototyping as well as manufacturing. I have however had a few conversation with local shops on prototyping. Either way the manufacturer would at a minimum need to be ISO-9000 compliant, sign an intellectual property rights agreement as the premise is applicable to the N55 as well, and be willing to make small production runs initially.
The end switch is do able but would require building a jig to ensure the Hall effect interrupter notches are correctly located. If they're off a few degrees it will throw off the cam timing by the same amount.
Camshafts
I was thinking more like a one-off cam not necessarily a prototypical type run of parts...
Stage 5 anyone?
Stage 5 anyone?
Stage 5 anyone?
Stage 5 anyone?
Hahahaha.... I should have known better than put it in writing. Turns out it was the train after all. Just not possible to get an MEVD17.2.2 ECU to control the newest Bosch pump. Normalized everything else but the response curves are different. New intake cam on order from Germany. Guess I'll just fume while I wait for delivery. Friggin BMW.
Reason
Yeah, reason for everything...probably run better with new cam...
Well the old cam only had 1900 miles on it so probably not much difference. On a positive note I'll have both versions of the intake cam if I decide to go the more complicated route with the cams later on. I've also got a little time now to go back and do some more work on re-designing my short-ram intake which will be going on later.
$800 to flow the heads then $100 labor to replace the valves afterwards. Same size as stock 29mm intake, 26mm exhaust, lower stems undercut for better flow, upper stems gun drilled to save weight. There's no room in the cc for larger valves due to shrouding. Ferrea has an office about half a mile from where I work :-) If I were going to do it again I'd ceramacoat the cc, valve face and piston crowns.
Tigger. A question referencing your under cut valves. There not under cut on the N18 motors ? Mine were. Also, did they have a back cut on the intake valves ? When I disassembled mine, we checked the angles thru a optic machine. They were 37 with with a 30 degree back cut. Just curious. Look into the Cerakote V-136 for ceramic coating. With a bead blast cabinet using the red oxide material. You can do it yourself. Wife might not like the oven in the house be used for it tho.
. Pretty easy to do.
Not sure if they were or what the angles were. I can check and see if the machine shop kept the old ones. Funny you should mention wives cause I put my DP in the oven for a final bake before installation. My wife wasn't real happy about it either. My argument was "What? We cook in ceramic dishes for crying out loud". Now if I was rebuilding a shovel head in the living room....
