Navigation & Audio Pulling the HK Amp
Old Aug 31, 2006 | 06:58 PM
whovous's Avatar
whovous
Pulling the HK Amp
OK, I have figured out the problem with my HK system is the amp, and I've found a used replacement for a fraction of the dealer cost. I thought I'd pull and replace it quickly tomorrow AM before heading out for MTTS.
I yanked the lid covering the amp and discovered only one mounting screw is readily accessible.
All I want to do is remove and replace the amp with an identical unit. I even have the bracket for the replacement. Is there an easy way to do this, or am I looking at pulling the rear seats before I can get the rest of the cover off?
I think I am just a couple of inches away from where I need to be to both start and finish the job. Where do I go from here?
Old Aug 31, 2006 | 07:21 PM
GBMINI's Avatar
GBMINI
I don't think you can do it without removing the rear panel (and therefore the seats too) :(
Am I going to be able to see this sunroof design soon then?
Old Aug 31, 2006 | 07:26 PM
weezer2282's Avatar
weezer2282
Might try this: http://claire.shankrabbit.com/
Go to the audio mods section.
Old Aug 31, 2006 | 07:32 PM
whovous's Avatar
whovous
Wow, if all I need is a foot long screwdriver, I am going to be very pleased. This was starting to look like a very unpleasant job...
Thanks!
Old Aug 31, 2006 | 07:34 PM
whovous's Avatar
whovous
It looks like you are doing the entire length of MTTS. I'll be staying at the Omni in Charlottesville prior to my only leg.
Old Sep 1, 2006 | 12:18 PM
jwardell's Avatar
jwardell
You need to remove the whole side panel (and therefore, the rear seats), to remove the HK amp.
Old Sep 1, 2006 | 01:57 PM
GBMINI's Avatar
GBMINI
I'm there now ... I'll have to search around ...
Old Sep 4, 2006 | 03:35 PM
whovous's Avatar
whovous
A foot long (actually a #2 Philips with an 8" shank) did the trick. An inch longer would have been better still. A #3 would not work at all.
Getting the amp and bracket out of the opening, and back in again, was a challenge, and I lost one of the screws in the process. For now, I will get by with the bracket connected in only two places.
In any case, the sound is back where it belongs, and that is all that matters.
GBMINI, I saw GPMINI and its traveling twins in Charlottesville. Very nice.
Old Sep 4, 2006 | 05:33 PM
GBMINI's Avatar
GBMINI
I searched the parking lot but couldn't find your roof :(
Old Sep 5, 2006 | 02:09 PM
whovous's Avatar
whovous
*sigh*
maybe next time...
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Apr 28, 2019 11:37 AM
Fordgt4
Oct 10, 2015 10:42 AM
martinb
Oct 7, 2015 05:00 PM
Filmy
Sep 7, 2015 08:27 PM
