Stupid Shift . . .
Old Jun 8, 2006 | 04:58 PM
CutnThrust's Avatar
CutnThrust
Stupid Shift . . .
This morning, sans my normal espresso fix, I did something that I promised myself that I'd never do with this car.
The throw on my shift felt a bit odd. The clutch, however, felt the same as ever.
Simultaneously, my left foot was working involuntarily (normal) while my right hand was trying to adjust to the slightly abnormal feel in the shift throw.
The result: shifting from 1st to 2nd, I slipped the clutch in before fully engaging 2nd gear. UGH!
I immediately stomped on the clutch pedal . . . there was only very brief RATATAT. Fortunately, I was not getting on it at all . . . in fact I was pulling away from a stop sign rather gingerly. (probably one reason it happened to begin with!)
So, my spotless shift history with the car has been tarnished, but all the same it has made me wonder what is ocurring when this happens. Have I customized the teeth pattern inside my gearbox?
Old Jun 8, 2006 | 05:02 PM
justaguyinvegas's Avatar
justaguyinvegas
At least you didn't accidentally downshift into second instead of fourth on the highway. ...thank god I was going under 60.
Old Jun 8, 2006 | 06:36 PM
kapps's Avatar
kapps
Don't worry. A missed shift or two isn't going to hurt anything unless it grinds for a while. I've had the same thing happen.
Old Jun 8, 2006 | 09:53 PM
002's Avatar
002
Under 60, I did it tonight at 90. I'm not sure if I'm getting lazy or if something is wrong with car, but this would be the fourt time in the past year. Full throttle in third up to redline, hard shift into fouth...err... second, then full throttle again. It only takes a second to realize and put the clutch back in, but seeing the tach bounce off the 8000 mark is scary. I always expect to see smoke from behind or feel a misfire, but so far so good. The engine is definitely not the week part of the car.
Old Jun 8, 2006 | 10:11 PM
CutnThrust's Avatar
CutnThrust
I've "kissed" the rev-limiter as well, borrowing a term that I picked up from a response to a prior post I submitted on the same mistake . . . however my error was slotting 4th instead of 6th on the way up from 5th!
Old Jun 8, 2006 | 10:12 PM
MSFIT's Avatar
MSFIT
you would have to hold it grinding on the synchros for a good bit to do some damage...
Old Jun 8, 2006 | 10:26 PM
002's Avatar
002
Kissed it? I shoved my tounge down it's throat. The tach needle reached it's end stop.
Old Jun 8, 2006 | 10:31 PM
CutnThrust's Avatar
CutnThrust
Dog!
Old Jun 9, 2006 | 10:46 AM
kenchan's Avatar
kenchan
Don't worry about. even pro's mis-shift sometimes.
Old Jun 9, 2006 | 10:51 AM
gokartride's Avatar
gokartride
Alas, we are all human. Your car will be fine.
Old Jun 9, 2006 | 11:00 AM
kalbone's Avatar
kalbone
dont feel bad... it's more embarrassing when your out on the drag strip infront of tons of ppl and your racing a honda and shift from 2nd to 5th and then shift to third and still run a 17 beating that honda. it was fun!!!!
Old Jun 9, 2006 | 11:01 AM
shankrabbit's Avatar
shankrabbit
Was anybody around to see this mis-hap?
Somehow whenever I decide it to be a good time to mulch my gears there always happens to be an on-looker marveling at the beauty that is the MINI.
"Ohh look at that awesome little car"
**GRAGTGTGATGGGTTTTATTTT!!!**
Old Jun 9, 2006 | 11:11 AM
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
I have done the shift from 2nd to 5th a couple of times and boy did MIB fall on its face! Thankfully though not on a track or in competition!
Old Jun 9, 2006 | 11:14 AM
kalbone's Avatar
kalbone
[quote=shankrabbit]Was anybody around to see this mis-hap?
quote]
yea a bunch of people were there watchin and asked what happened, i told him i was waiting for him to catch up , but they didnt buy it.
Old Jun 9, 2006 | 11:15 AM
MSFITOY's Avatar
MSFITOY
Old Jun 9, 2006 | 07:31 PM
kenchan's Avatar
kenchan
Originally Posted by MSFITOY
he's in canada.
Old Jun 9, 2006 | 08:54 PM
MSFIT's Avatar
MSFIT
Old Jun 9, 2006 | 09:09 PM
002's Avatar
002
Originally Posted by kenchan
he's in canada.
Who you wink'n at.
PsychoRallye
21
Feb 17, 2019 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
02miniSguy
Nov 17, 2015 10:29 PM
MINI Stupor
Oct 1, 2015 11:36 AM
bahman
Sep 30, 2015 01:59 PM
