R60 2012 R60 view of top of rear strut from inside the car
This is a view most probably don't see. I've been relentlessly chasing a knocking/rattle noise in the rear of my Countryman. Everything in the rear is new. Shocks OEM, Springs, insulators, trailing arm bushing and brackets, control arm and upper mount. The top nut was tight when assembled but as you can see with weight on it, the top bushing is no longer compressed and is separated from the top plate. The video links are the movement while driving over a rough road. I cannot figure out what the issue is. I've got about 50 hours in this battle and finally ripped out the side panel to get a bore scope in there. There should be a solid stack from the lower beveled washer and the top inverted washer. Yet there is space. tell me if you agree this is abnormal?
I sent this to Detroit Tuned since I bought my NM swaybar and end links from them. He told me the while aftermarket bushings don't work and all crush down like this. He recommended Powerflex bushings so that's next.
Unfortunately, yeah, that's normal for aftermarket rear bushings. Also unfortunately, the OEM bushings only come with new rear upper mounts.
Are you getting a clunking noise from the rear? What made you decide to stick a camera in there?
Poly bushings in that location will help with the shock doing its job, so should add to better rear suspension control.
Yes they all will mushroom more or less on the rear shocks from R50-R61s. Weather, condtions, and weight on the suspension also play a part. The design of that top mount tends to sag under load. When you have a lowered car or coilovers it seems to kill them faster. I have seen some last a while aftermarket and some just fall apart. You can get the foam part with tube washer on its own.
The factory MINI ones do this also over time. Early designs of the Genuine MINI factory part had more elastic in the foam mount (took a long time to fail on my 2005), they were made by lemforder for the foam part, then about 4 years in the changed ~2009 the design to more foam and less elastic. Then they tend to fail and mushroom down and clunk over bumps as they have deformed and dont bounce back.
I went to poly on my coilovers as i drive allot from PSB or Powerflex.
PSB: https://www.ecstuning.com/b-psb-part...t/psb664k~psb/
Powerfflex: https://www.ecstuning.com/b-powerfle...fr5-115x2~pfx/
so yes I pulled the side panel which is a pita to look down at the top of the shock as installed and found this big gap. Keep in mind these are new. You can see the big gap between the perch plate and bushing. Here is a picture of what it looked like when I installed it. Nice and squashed. Now not so much. I pray the power flex fixes this issue!
ECS, I would have gladly bought the OEM mounts if plates with the bushings had I known the aftermarket ones are such trash. I figured the Lemforder ones were the same as OEM. I’m so tired of aftermarket crap! I need a break and to put this thumping issue to bed.
Lemforder is the same, MINI (Genuine) changed the materials and all the aftermarket ones followed, they all used to have more rubber or elastic material with the foam. I have old ones (2005 built) that lasted maybe 60K and needed replaced, my new ones were a different material and they were genuine.
Just want to say that is great you were able to find this noise after so much time and effort. Kudos for the camera work to find and document it.
I hope you find a material solution for these isolator bushings that works.
Thank you for the note. It's been quite the journey.
The PowerFlex will definitely work. They might even be too stiff. I used the Problem Solver Bushings when I replaced mine. They use a slightly different bushing mold for the lower bushing, which makes it slightly more compliant, but it still hold everything in place.
https://psbushings.com/product/2-x-m...t-bushing-kit/
The canary in the cave for me was the High Pressure Fuel Pump. I checked with the dealership and the HPFP was like $1500. Woah! I'd never paid more than 50 bux for a fuel pump in my entire life. I started looking at third-party offerings in the $150 range. While this was tempting, I found post after post about under-performing to flat out DOA third-party HPFP's. I decided to go with OEM from FCP Auto for a little < $1,000. That was a little < 4 years ago and > 45K miles ago and she's still running like a champ.
I'm a little more fluid now than I was 15 years ago, so now I insist on OEM. My last divergence from OEM was a mitigated disaster, when I purchased front struts. At first glance they looked correct. But once I started removing parts it was clear that there was a slight difference, which rendered them useless. I put everything back together, took back the aftermarket (with a 10% restocking fee), purchased OEM and they fit like a glove.
This car is a "keeper" for me. I LIKE the car and plan on driving her for a long, long time. Ergo, I've used nothing but OEM parts on my R60 and I have zero regrets. No more aftermarket for me.
D
D
D
It's funny you say. After the dealership had quoted $4500 for "needed suspension work" after I tried to cash in a $60 alignment coupon, I had an Independent Mechanic inspect the underside of my R60 with the intent of getting a second opinion. I wanted him to flush out and replace any bushings that ACTUALLY needed replacing. I gave him carte blanche to replace anything that needed replacing. Ironically, he said that everything looked good. I asked for his opinion of the aftermarket (polyurethane?) "performance" bushings I had been reading about. He said I wouldn't install them. I asked why. He said that he had uninstalled TWO sets after customers complained of the horrible (stiff, I assume) ride. That's all I needed to hear. When I DO finally start replacing bushings, I'm going OEM all the way.
D
D
The Powerflex didn't change the ride at all that I can tell. The reason I didn't go OEM is because they make you buy the top plate which I didn't need plus I was told that the Lemforder bushings are the same ones supplied by Mini. Had I gone OEM to start with, I might have never had a problem but I won't know now. If the Powerflex fail, I'll try the OEM ones. Here is a picture of the Powerflex installed. No gap.
D
Soooooooooo, it hasn't been that long and my noise is starting to return. Nowhere near as bad but I hear it. In goes the borescope again and sure enough, I'm having alot of movement in the shock top and the preload on the top bushing is gone. The only thing I know to try is to shorten the metal sleeve that is 30mm long and grind off a mm or so. This is the only way to increase the clamping force on the lower and upper bushing as the lower bushing compresses a bit with the cars weight on it. I can't find any references that someone has done this or needed to do it. Shortening the sleeve will reduce the stack height and increase squeeze on the bushings.
D
the metal sleeve dictates the distance. You could add a washer under the cupped washer but the ID would have to be larger than the sleeve but you would loose the cupped effect if I’m explaining it clearly enough. I ground the sleeve 1mm and there is more pressure on the bushings now.
Keep us in the loop. Let us know if your fix is permanent or not. I appreciate your diligence on this repair. Good stuff.
D
anaustin
Jun 30, 2025 04:25 AM
AutoCoarsen
F54 :: Clubman Talk (2015+)
Nov 11, 2021 06:34 PM
BRGCountryman
18
Jul 23, 2021 11:16 AM
ivegota
R60/61 Cooper S Drivetrain
Feb 17, 2021 08:10 AM
