I had the left side fuel level sensor replaced. Now when I go to menu 6.0 I can se huge difference between the levels.
Is this normal?
I did a test..., filled up the tank (50lts) and I drove 372kms with an average consumption of 8lts/100kms . It seems even if there is only 7liter on the right side, it should be more less the 20lts indicate of remaining fuel.
I will monitor from here..., I suspect of having that left fuel sensor stuck for some reason.
When I looked at the video, simplecarguy's menu 6.0 also reports different fuel levels from the right and left fuel senders. See image below. Maybe this is normal?
Your menu 6.2 seems to report the electrical resistance readings from the two senders, which differs from simplecarguy'smenu 6.2 information.
Is your fuel gauge in the speedometer working as expected? If so, I wouldn't worry about the different menu 6.0 left and right readings because simplecarguy may have simply misinterpreted the true meaning, which is a mystery.
