R56 2011 with BMW performance BBK
Old Apr 19, 2022 | 10:35 AM
Nashviller56's Avatar
Nashviller56
Hey all.
just a quick question.
I installed the BMW performance big brake kit, and I had to install 20mm spacers to make the wheels fit. I’d rather not need spacers, but I’m curious as to what wheel offset would I need in order to achieve it?
here’s pics
Old Apr 19, 2022 | 11:53 AM
Zillon's Avatar
Zillon
Wheel offset isn't as important as spoke design. The LMs don't allow for a ton of brake clearance to begin with.
Those brakes look identical to the JCW GP2 calipers; I ran 17x8 Team Dynamics Pro Race 1.2s in a +38 offset on my GP2 when I had it.
Old Apr 19, 2022 | 11:57 AM
Nashviller56
Yeah the calipers are the same design, everything else is just OEM GP2.
also thanks for the info, I had my eye on some rpf1’s in 17x7 +35
wonder if it would fit..
Old Apr 19, 2022 | 12:27 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those look awesome When I measured the clearance on my car, I measured 18mm spacers for my Miata wheels.
@Zillon is correct when it comes to clearance. Spoke design has more to do with clearance than offset. OEM GP2 wheels are 17x7.5 +45. Not sure if the RPF1's have decent spoke clearance for those. My suggestion would be to purchase one fore test fit, and just see if it will mount up and give you clearance. If it fits, then get 3 more and have tires fitted.
In other news, you shouldn't have much issue selling those BBS wheels...
What did you use for brake hoses? Did you get the GP2 hoses, or reuse your S hoses? Did you upgrade the master cylinder?
Old Apr 19, 2022 | 12:38 PM
Nashviller56
Ahh gotcha! And I’m sure they’ll be up for sale soon! As soon as I can find some wheels I can’t live without
cheers
Old Apr 21, 2022 | 06:33 AM
Look great, major upgrade, did you upgrade to the GP2 master cylinder?
Old Apr 21, 2022 | 06:46 AM
Nashviller56
i have not. i figured i will never track the car, so i didnt see it as needed. is it a must have?
Old Apr 25, 2022 | 11:49 AM
Zillon's Avatar
Zillon
How's the pedal feel after the caliper swap?
Old Apr 25, 2022 | 12:20 PM
Nashviller56
It feels stock. I was hoping for a stiffer feel, but maybe the master Cyl will do that, and maybe some steel braided lines
Old Apr 25, 2022 | 12:26 PM
Zillon's Avatar
Zillon
You'd be correct.
Those calipers require more fluid movement, so the larger bore MC of the GP2 would help firm up the pedal.
Old Apr 25, 2022 | 12:31 PM
Nashviller56
Originally Posted by Zillon
You'd be correct.
that will be my next purchase. Thank you!
Old May 4, 2022 | 07:19 AM
I ran without it when we first tested the GP2 kit before anyone else on an R58 JCW and it needed it. Pedal feel was not that good before.
Old May 4, 2022 | 07:59 AM
Nashviller56
I ordered the GP2 brake master cylinder. Supposedly the last one available through the dealer. Just gotta find time to have it installed
Serafin
Tires, Wheels, & Brakes
Aug 14, 2019 05:23 PM
SomeguyinAZ
Aug 23, 2017 08:16 AM
cooper a
Apr 4, 2017 07:34 AM
Dailyn H
Apr 10, 2016 10:47 AM
AZMCS
37
Jun 11, 2006 03:42 PM
