Rear fog lights / ambient light
Hello all .
It is great to be here with other mini owners and fans.
I have two problems with my mini. Maybe not a problems but riddles.
1st - I want to add rear fog light . For now I have only switch for front lights . But ! When you look through the red glass you can see bulbs inside .
Someone told me that all wires should already be in my mini and I just have to buy new control panel with both buttons (for front and back fog lights ) .
Is it true? Has anyone done such a thing?
2nd - I have ambient light and as I know it should be placed on the pillars, on the headlining, on the door and under the air conditioning console (illuminating the place for cups etc.).
Unfortunately, in this last place I only have a hole in which the LED should be. Can I add the missing lighting myself?
If so, how and what LED should I buy?
Thanks for help
Best wishes 4 all of you
Thanks for help
Maybe someone will help me also with second question about ambient light? How can I plug Led here ( marked on the photos * I saw ambient light there in other Cooper S R56 ).
Like I said earlier - in my Mini there is a small hole but it is empty . There should be a Led but what kind and how I have to put it there? Help
Switch, knock out the black cover and take that top cover off, install, put back together, then program.
Talked about here:
https://www.northamericanmotoring.co...hting-y-n.html
Talked about here:
[QUOTE=ECSTuning;4487726]Switch, knock out the black cover and take that top cover off, install, put back together, then program.
Talked about here:
/QUOTE]
Awesome . You are the best !!!
Thanks a lot for your help
I really appreciate it
Talked about here:
/QUOTE]
[QUOTE=Legancy;4487742]
Yep!
Talked about here:
/QUOTE]
Talked about here:
/QUOTE]
Yep!
Has anybody successfully got their rear fog lights to work?
I took my dash apart and installed that chrome toggle switch. A bunch of work but it toggles nicely. I installed both switches but neither turns anything on. As I understand it, the center part of my reverse/backup light assembly is a rear fog light and it has a fresh bulb in it.
Peter
Peter
Peter
Peter
drpep
Feb 28, 2016 05:33 PM
