R50/53 Left DRL not lighting
Old Nov 28, 2018 | 11:09 AM
Duaneo's Avatar
Duaneo
Folks,
2004 MCS. I have DRL enabled, and it has been working normally for a while now. Recently I noticed that the driver side DRL light isn't lighting up. The high beam works just fine, but the DRL (which I know is a dimmed high beam) isn't working. Any thoughts?
Cheers,
Duane
Old Nov 29, 2018 | 08:48 AM
Thats weird, never seen that. All i can think off is that maybe a bad wire or element and when on high output the filiment makes contact? Like a loose filiment
Old Nov 29, 2018 | 03:14 PM
Thinker2112's Avatar
Thinker2112
Lucas the Prince of Darkness... has come...
On a somewhat unrelated note - for about a month in my 2005 S, I had to turn on the drivers side seat warmer to get the H/K stereo to come on... once it came on, the seat warmer would turn off. My 2004 Justa has had a myriad of electrical issues... the alarm goes off for no reason is the most common one. No leaks in any of the wires to let the wire smoke out... the only "fluid" I haven't had to change.
Old Nov 30, 2018 | 05:10 AM
All i can think of is the BCM got wet from a leak or drain coming loose in the sunroof or is going bad?
https://www.northamericanmotoring.co...le-issues.html
volksfragen
Electrical
Feb 5, 2021 08:17 PM
GregoryK
Apr 27, 2016 05:37 PM
blue dragon
Electrical
21
Aug 28, 2014 06:59 PM
tekron
Jul 12, 2008 09:44 PM
ChrisMCS04
Oct 8, 2007 05:57 AM
