Electrical DRL for Canadian cars - way to disable xenon drl?
Old Jun 4, 2012 | 05:41 PM
blue dragon's Avatar
blue dragon
This is really annoying that the xenon lights are the DRL. The moment you start the car, the xenons are on. You can't even disable them but turning the switch to off.
I've coded a bunch of stuff on my US bought X5 35D, but I can't see where there is the option to enable or disable DRL in the FRM on the R60.
Any clues anyone?
Old Jun 5, 2012 | 10:35 AM
Mojito's Avatar
Mojito
no clue, but what do you plan on using for DRLs then?
Old Jun 5, 2012 | 11:00 AM
blue dragon
^^ The city lights. I cross posted in the bmwcoding forum, along with a trace file from the frm module
http://www.bmwcoding.com/showthread....able-xenon-drl
Old Jun 5, 2012 | 11:10 AM
Mojito's Avatar
Mojito
are the mounties going to be ok with that?
Old Jun 5, 2012 | 04:13 PM
icuc's Avatar
icuc
I don't have the xenon lights on my R60 but I could turn off the DRL using BC control..
Old Jun 5, 2012 | 06:10 PM
Koopah's Avatar
Koopah
I don't think that option shows in the display for Canadian models due to country regulations.
Old Jun 6, 2012 | 09:54 AM
blue dragon
^^ Nope, it doesn't show. All I see is the option to adjust the sensitivity for the wipers, or the info messages.
Old Jun 6, 2012 | 10:07 AM
icuc's Avatar
icuc
There will be 4th sub menu (key symbol) where you can adjust other setting like.. unlock all doors, 3X blink turn signals. Do you see this?
Old Jun 6, 2012 | 11:43 AM
icuc's Avatar
icuc
Can you upload your FRM trace file?
Old Jun 7, 2012 | 10:20 PM
inh's Avatar
inh
FRM trace was posted in the bmw coding forum he linked above. digging through it now. SUBSTANTIAL differences from mine..
IGR_DRL_H_RELEVANT - you have aktiv i have nicht_aktiv
and thats as far as i got before losing patience. your trace is HUGE!
Old Jun 7, 2012 | 10:34 PM
The M People's Avatar
The M People
Is your tail light on all the time too ?
Old Jun 8, 2012 | 08:23 PM
blue dragon
Not sure for the tail lights, will check tomorrow during the day.
Old Jun 8, 2012 | 09:32 PM
Hodaka's Avatar
Hodaka
I may be talking though my hat (have not done any of this stuff), but I think I read that you need to change the country coding first?
Old Jun 8, 2012 | 10:55 PM
The M People
Mine is Canadian car too and my Xenon and tail lights are always on as soon as I start the car.
I will be really interested if you find a way to disable them.
Old Jun 13, 2012 | 07:52 AM
CountryStyle's Avatar
CountryStyle
I was just wondering why you find it is annoying?
Is it not the purpose of Bi-Xenon headlights to be on as DRL?
Old Oct 26, 2012 | 10:41 AM
Hoydi Cheng's Avatar
Hoydi Cheng
It would be nice to use the fogs only when the weather is bad so you don't reflect all that snow into your face.
Old Nov 2, 2012 | 06:32 PM
strobeyprobey's Avatar
strobeyprobey
You need to take the Canada region out of the VO string. $838 Then default at least the KOMBI and FRM modules. Then you will have the option to turn off the DRL in the BC menu. Then you can go ahead and make changes in the FRM module for different lights as well (like for me I have DRL set just for the front city lights).
Old Nov 2, 2012 | 06:57 PM
Koopah's Avatar
Koopah
Originally Posted by strobeyprobey
{snip}...Then you can go ahead and make changes in the FRM module for different lights as well (like for me I have DRL set just for the front city lights).
Strobey --
I've been trying to limit the DRLs to just the city lights on my R60 with no luck! I can easily code the FRM but I have yet to find the right settings to turn-off all DRLs but the city lights. Would you mind listing the appropriate settings?
TIA,
Old Nov 2, 2012 | 07:04 PM
strobeyprobey
All in FRM:
VERHALTEN_DRL_TFL set to drl_s
DRL_TFL_MIT_SML set to aktiv
You will probably also need to set the following to nicht_aktiv:
DRL_TFL_BLK_V_GED
DRL_TFL_KZL
DRL_TFL_RL_BL
DRL_TFL_RL_BL_1
DRL_TFL_RL_BL_2
Old Nov 2, 2012 | 08:18 PM
Koopah's Avatar
Koopah
All in FRM:
DRL_TFL_BLK_V_GED
DRL_TFL_KZL
DRL_TFL_RL_BL
DRL_TFL_RL_BL_1
DRL_TFL_RL_BL_2
Will code this weekend and reply.
Cheers,
Old Nov 3, 2012 | 02:30 PM
Hoydi Cheng
Can you elaborate a bit? I've coded a bunch of stuff according to the guide here on the forums, but what do you mean by defaulting the modules? I assume the VO string I can just code out as the other ones?
Old Aug 28, 2014 | 06:59 PM
minie's Avatar
minie
anyone have any luck on this? just installed the led DRL, with the xenon on the led ring only light up n not the full ring. any help would be greatly appreciated.
Dec 23, 2015 10:36 AM
ludedude
Aug 10, 2015 07:16 PM
PatrikKN
Aug 5, 2015 09:10 PM
tippin
Aug 5, 2015 08:43 AM
