Electrical Window dipping part 2
Old Jun 6, 2018 | 12:32 PM
tag1260's Avatar
tag1260
OK. Finally did some digging into my issue of the drivers side window not dipping enough and here's where I am so far.
I think this is a mechanical issue as I can push my window down when the door is open to where it is supposed to be. There's slack in there somewhere that isn't in the passenger side. Now to dismantle the door and try to figure out if it's a regulator or a motor or just something came loose.
Anyone ever run into this?
Old Jun 12, 2018 | 04:05 PM
tag1260's Avatar
tag1260
Tore everything apart and found no issues that I can see. Need to find someone to help reset the software next. I wish the nearest dealer that I trusted wasn't 250 miles away.
Old Jun 26, 2018 | 06:53 AM
tag1260's Avatar
tag1260
OK. Had time to work on it again. Newest development is that I changed out the window motor. Dipping seemed to work but needed to reset the window as it would go up then halfway back down. When I reset it I lost the window dipping again.
Old Jul 6, 2018 | 02:15 PM
tag1260's Avatar
tag1260
Reset the window dipping thru INPA and all is good now.
Old Jan 24, 2019 | 07:29 AM
miklam's Avatar
miklam
Can you explain me of how i can do with INPA?
Old Jan 24, 2019 | 08:45 AM
DneprDave's Avatar
DneprDave
Here are instructions I found here on how to reset your windows without special programming.
Originally Posted by 10Zero
Insert the fob, hold both window toggles "down" at the same time until the windows are fully open.
Pop the fob out, then back in again, hold both toggles "up" until fully closed.
Pop the fob out, then back in again...you should have auto up/down again.
Old Jan 24, 2019 | 08:47 AM
miklam's Avatar
miklam
[QUOTE=DneprDave;4446215]Here are instructions I found here on how to reset your windows without special programming.
I have try this.. But nothing... I need recalibrate because the windows go up and then go down automatically for 10cm
Old Jan 24, 2019 | 04:42 PM
tag1260's Avatar
tag1260
https://www.northamericanmotoring.co...ogramming.html
Old Jan 26, 2019 | 02:54 AM
miklam's Avatar
miklam
I have installed inpa but I don't see all model of car? How is possible?
remotecontrol
Apr 1, 2021 03:11 PM
tag1260
Electrical
May 16, 2018 02:10 PM
zeus7625
Jul 1, 2008 04:26 AM
ASenna
May 22, 2003 04:16 PM
NUMMYTIME
Apr 24, 2003 01:35 PM
