Window dipping part 2
OK. Finally did some digging into my issue of the drivers side window not dipping enough and here's where I am so far.
I think this is a mechanical issue as I can push my window down when the door is open to where it is supposed to be. There's slack in there somewhere that isn't in the passenger side. Now to dismantle the door and try to figure out if it's a regulator or a motor or just something came loose. Anyone ever run into this? |
Tore everything apart and found no issues that I can see. Need to find someone to help reset the software next. I wish the nearest dealer that I trusted wasn't 250 miles away.
Thanks |
OK. Had time to work on it again. Newest development is that I changed out the window motor. Dipping seemed to work but needed to reset the window as it would go up then halfway back down. When I reset it I lost the window dipping again.
Reset the window dipping thru INPA and all is good now.
Originally Posted by tag1260
(Post 4404232)
Thanks |
Here are instructions I found here on how to reset your windows without special programming.
Originally Posted by 10Zero
(Post 3269352)
Insert the fob, hold both window toggles "down" at the same time until the windows are fully open.
Pop the fob out, then back in again, hold both toggles "up" until fully closed. Pop the fob out, then back in again...you should have auto up/down again. |
[QUOTE=DneprDave;4446215]Here are instructions I found here on how to reset your windows without special programming.
I have try this.. But nothing... I need recalibrate because the windows go up and then go down automatically for 10cm |
