metallic whistling sound
Old Jun 12, 2016 | 12:53 AM
genik's Avatar
genik
Any ideas where this metallic whistling sound is coming from when i hit the gas pedal hard? I believe it is the turbine but id like to hear an opinion. The mini is suffering from a loss of power but at the moment the only codes that i had were P000A-Powertrain and P0420-Powertrain. Any suggestions?
Old Jun 15, 2016 | 01:29 PM
nkfry's Avatar
nkfry
Wait for the engine to cool and remove the intake tube to the turbo, with the car off, feel for bearing play. That doesn't sound too hot, chances are you're in for a turbo.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jun 15, 2016 | 02:02 PM
genik's Avatar
genik
Awesome advice! I just dont understand the part that you say "That doesn't sound too hot"
Old Jun 15, 2016 | 02:22 PM
nkfry's Avatar
nkfry
Doesn't sound good. Sorry, young hip lingo.
Phone:586-792-6464
Old Jun 15, 2016 | 02:34 PM
genik's Avatar
genik
No worries, thanx for the comment. I wonder though, can there be loss of power due to this issue?
Old Jun 15, 2016 | 02:39 PM
nkfry's Avatar
nkfry
Definitely can cause low power issues, check it out and if it turns out it needs a turbo we have either new Borg Warner units, or rebuilt units in stock and ready to ship.
Phone:586-792-6464
Old Jun 15, 2016 | 03:04 PM
genik's Avatar
genik
Should there be a CEL?
Can you tell me more stuff/info regarding the Borg Warner units? Are they like the JCW turbo units?
Will they need a chip upgrade in order to function properly?
Old Jun 15, 2016 | 09:33 PM
Systemlord's Avatar
Systemlord
If your turbo isn't generating boost then the ECU would just operate normally as if you were lightly tapping on the pedal. I can clearly hear your turbo shaft spinning like it's not getting any oil, what's happening is you turbo shaft has to much end play causing that screeching sound. Replace the turbo oil line while your at it, those get clogged up with burnt oil over time.
Old Jun 16, 2016 | 09:09 PM
genik's Avatar
genik
Thanx for the info Systemlord! What do you mean that my turbo shaft has too much end play? Just to not, this screeching sound only occurs when the car is cold started, after few min of use the sound goes away!
Old Jun 17, 2016 | 10:50 AM
nkfry's Avatar
nkfry
All of the chargers used on the 2nd gen MINIs are manufactured by Borg Warner, we have new in stock chargers or rebuilt units.
To run a larger charger properly tuning is required.
If the car isn't reaching requested boost levels, yes, you will get an underboost code which will put you into a limp mode.
Skip ahead in the video to about the 2 minute mark, you'll get a better understanding of what shaft play is and what it causes.
Phone:586-792-6464
Old Jun 17, 2016 | 01:17 PM
genik's Avatar
genik
Where the heck is that like button, i wanna press it a thousand times Thanx guys!!!
Old Jun 19, 2016 | 10:18 AM
genik's Avatar
genik
I wish there was an R56S video showing how2fix the shaft's wiggle or other usual issues!
quickcoop
Dec 4, 2020 09:05 AM
Ol' Blue
How to
17
Aug 5, 2019 08:46 AM
Ygritte
Jan 22, 2019 06:48 PM
MES11
Navigation and Audio
17
May 30, 2016 03:55 PM
FunkyMunkey
Mar 26, 2016 05:34 AM
