R50/53 water leaking from vent below antenna- HELP
Old Dec 24, 2015 | 03:08 AM
MiniMusician's Avatar
MiniMusician
I have a 2006 R50.... on the interior roof, just below the antenna is a bump out that looks like a vent. I have water dripping from THAT. I pulled the vent off, and found water collected.. but couldnt find the source of the leak.
Has anyone else had this problem????
Could it be leaking around the antenna base?
Old Dec 24, 2015 | 09:11 AM
Antenna base gasket or the rear brake light lens :
https://www.northamericanmotoring.co...ear-hatch.html
https://www.northamericanmotoring.co...ater-leak.html
Old Dec 24, 2015 | 10:20 AM
MiniMusician
I think I found the problem
The rear drain hoses for the sunroof were clogged. Here is a picture of the vent I was referring to.
and THANK YOU for your reply.
Old Dec 24, 2015 | 10:24 AM
Yep, those hoses clog or the rear top brake light gasket leaks
https://www.northamericanmotoring.co...-2002-mcs.html
You are welcome. Have a great holiday.
Thats it. Check the front and the back once in a while and make sure they are connected and clean. Cleaning out the rain tray on the sunroof cassette helps down the road collecting in the drain hoses.
Old Dec 24, 2015 | 10:37 AM
MiniMusician
Do you have a diagram of the locations of all 4 drain hoses? I found the rear.. but cant seem to find the front... and my shop manual is vague.
Thanks!
Old Dec 24, 2015 | 10:45 AM
http://www.realoem.com/bmw/enUS/show...diagId=54_0290
#10 front , #11 rears. one for each side.
https://www.northamericanmotoring.co...-footwell.html
Old Dec 24, 2015 | 12:28 PM
MiniMusician
drain hoses
I see that getting to the front drain hoses, will be a pain in the butt... but its also a good way to get to know my MINI.
Old Dec 28, 2015 | 08:00 AM
welcome.
Old Dec 28, 2015 | 08:38 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
You can view a lot of information about typical areas for your MINI to leak via the sunroof in this NAM thread here. There are a lot of detailed images in that thread for you while you attempt to clean out your drains. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
Old Dec 28, 2015 | 02:40 PM
MiniMusician
water leak
ECSTuning.. you are correct. The leak is around the base of the antenna... Can just the base be replaced, or do I have to buy the whole shebang?
Old Dec 28, 2015 | 02:52 PM
PelicanParts.com
Vendor
Believe you have to replace the whole base as the seal does not come separate. If you don't have phone preparation and nav it is HERE. Otherwise, with is here. Can confirm with your vin number if you want. You can also search for a used one in the marketplace or on www.car-part.com.
Old Dec 28, 2015 | 03:00 PM
MiniMusician
water leak
Thanks Pelican Parts! and so far you have the best price of a NEW base. (as long as I can get new, that's how I like to roll).. I'll go to your website to make sure it fits.
Old Dec 28, 2015 | 03:01 PM
PelicanParts.com
Vendor
You're welcome. You can PM me your vin and I can double check to make sure you're getting the correct one for your R50.
Old Dec 29, 2015 | 02:12 AM
MiniMusician
antenna base
Place the order early this morning... Thanks.
Old Dec 29, 2015 | 05:34 AM
" ECSTuning.. you are correct. The leak is around the base of the antenna... Can just the base be replaced, or do I have to buy the whole shebang? "
Some people have tried RTV black silicone a little on the gasket so they dont have to buy the whole base.
Otherwise the parts is here and pics to see. Not a generic diagram that might or might not be the part. This is the NON Navigation part version. 65206985714
https://www.ecstuning.com/Search/SiteSearch/65206985714/
Old Dec 29, 2015 | 05:42 AM
MiniMusician
Yep.. thats the part... I do not have Nav..
From the looks of the current base... the rubber edge next to the body seems to be pulling away from the base... I had wondered if putting a water sealant on that would hold until I can afford a new base.
Old Dec 29, 2015 | 05:44 AM
Yep, some people use the black rtv to seal up and buy some time. just use a dab and run a little bead as a quick fix.
shorenetworks
Dec 23, 2015 08:55 AM
rphox2003
Dec 22, 2015 10:12 AM
AU_Mini
Dec 22, 2015 06:37 AM
rphox2003
Dec 21, 2015 05:26 AM
gpwpat
Dec 20, 2015 11:24 AM
