R50/53 Free "lightly used" stock oil drain plug...
Old Dec 28, 2015 | 10:09 PM
Squid4life's Avatar
Squid4life
Hope you guys are having a better day than me. After putting the car back together from maintenance mode or whatever it is called, wanted to change the oil to be safe. (Just bought my 2006 MCS a few weeks ago with a leaky green supercharger gasket) Drain plug was so damn tight it stripped the hex head off. I used a 1/2", 1/2" drive 6pt socket, and that B was on there tight! Looked like someone had previously used a 13mm and rounded it a little.
Used a set of Craftsman bolt extractors; no joy. Ended up welding a 7/16" wrench on it and using my foot. Finally broke loose.
Have a Fumoto en route, and an O'Reilly drain plug if I get impatient.
Can't wait to get the car on the road! Since it was apart I installed a 15% Pulley and Alta cold air intake. Going to be a fun little go kart!
Attached Thumbnails Free "lightly used" stock oil drain plug...-image-4147058596.jpg
Old Dec 28, 2015 | 11:36 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
That is the start of a nice metal sculpture.
Old Dec 29, 2015 | 04:58 AM
dcantwell's Avatar
dcantwell
That sucks. I had a drain plug problem myself.
The issue? The threads in the hole of my oil pan were shot. Garage had to re-thread the oil pan. Luckily, that worked.
Old Dec 29, 2015 | 07:38 AM
Yikes,
Yea, its takes a 1/2" box end or socket.
Old Dec 29, 2015 | 09:56 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
This is one reason why I don't recommend people get their oil changed by quick lube places. I've seen over torqued drain plugs cause issues with the drain hole threads as listed above. Be sure to use the correct tightening torque now that you got it off, which is 25 Nm (18 ft-lbs).
888.280.7799 | 6am - 5pm PST
minigen
Jan 23, 2017 11:37 PM
evoq007
Aug 16, 2016 06:41 PM
Wisconsincooper10
Jan 4, 2016 02:51 AM
Sublime_565
Dec 4, 2015 02:21 PM
lalroma
Dec 4, 2015 07:49 AM
