R50/53 problems with new axle.
Old Dec 19, 2015 | 10:29 PM
gpwpat's Avatar
gpwpat
I'm on my 3rd set of axles. My originals lasted 160k. My cheap Chinese set lasted 60k. And now I'm on driveshaft shop axles. I always seem to have trouble with the drivers side with the spring clip. The Chinese axle I couldn't get the axle in with the spring clip on. I put it in without it.it lasted a year until the axle fell out. I got smart and ground the spring clip recess deeper so the spring clip could recess. Bingo. Manufactured wrong. But fixed. So when those wore out I went for quality and good reviews. Driveshaft shop. But I didn't get a mile from the house, twice before it fell out. Obvious the spring clip was not doing its job. After the second time I replaced the clip with one from the old axle. This lasted 2 weeks and today fell out. I took it out today and enlarged the slot width, thinking that maybe the spring clip isn't getting all the way thru so it isn't opening all the way. I really hope it works. I can swap the drivers axle now in 30 minutes. But don't feel like being stranded again. Has anybody else had problems with axles? Or am I having bad luck.
Old Dec 20, 2015 | 06:41 AM
David.R53's Avatar
David.R53
I've had problems getting generic clips to insert. Replace those with dealer clips (they are cheap) and never had one fall out. But once you've ground on the axle there isn't much to do. The dealer clips won't fit and what you have doesn't work...
Sounds like money is tight. I suggest buying some used MINI axles on eBay, rebooting them and install with new dealer clips...
Old Dec 20, 2015 | 08:08 AM
Nicefeet's Avatar
Nicefeet
How are you on your third set of axles?
My car has a 150k and the original axles have been rebooted only once
Old Dec 20, 2015 | 08:18 AM
gpwpat's Avatar
gpwpat
I have 240k miles. I'll try dealer clips.
Old Dec 20, 2015 | 11:24 AM
gpwpat's Avatar
gpwpat
Well, yesterday's enlargement to the spring clip slot seems to be working. Just drove about 30 miles the axle didn't fall out. I think the slot was a little narrow for the clip. And as it got compressed going into the spline in the differential it was sticking and not opening on the other side. Now with the slot wider the new spring clip doesn't stick and has the space it needs to open up. Time and a few hundred miles will tell.
morphix
R60/R61 Stock Problems/Issues
Nov 21, 2015 02:22 PM
krawzdogg
Nov 17, 2015 09:29 AM
vGEMATRIAv
Nov 16, 2015 02:18 PM
AvianMan
Nov 3, 2015 11:00 AM
cooper85i
Nov 2, 2015 05:29 AM
