Driver door unlocking problems.
Old Oct 30, 2015 | 11:31 AM
cooper85i's Avatar
cooper85i
Hi all,
So this finally happened to me now...the driver side door will ONLY unlock using the interior door pull. It will lock using the remote and interior switch, but will not unlock via remote, interior switch, OR inserting the key into the exterior handle.
I've read other threads, some say you can reattach a loose cable, some say to replace the actuator. Any advice would be greatly appreciated.
02 R50...the other doors lock/unlock as they should.
Old Oct 30, 2015 | 01:54 PM
I would check the door cable first and then replace the actuator , they get lazy and fail first on the unlock portion, then fail down the road on the lock portion. Since you tested the other unlock / lock usual locations. Sounds like you have it narrowed down.
51200556768
https://www.northamericanmotoring.co...-t-unlock.html
Old Oct 31, 2015 | 09:12 AM
Debi's Coop S's Avatar
Debi's Coop S
51200556768
I agree, just went through this issue and replaced the door actuator. No issues after 6 months.
Old Nov 2, 2015 | 05:29 AM
Yep , most of the time is just that actuator part. I did mine in pairs to get it all done at once.
Aug 30, 2017 05:10 AM
Oct 30, 2015 11:21 AM
Oct 29, 2015 01:55 PM
F55MidnightBlackCooperS
Oct 28, 2015 07:50 AM
WayMotorWorks
Oct 27, 2015 07:44 PM
