R56 CA Smog Check - Warning lights galore when done
Old Mar 10, 2013 | 01:42 PM
cnolan
Had CA smog check done on our '07 MCS today, required due to 6yr registration renewal. They run it on a Dyno for a few mins at 15 and 25mph, front wheels only. Car passed fine, no issues with the smog check.
Pulling away from the mechanic the steering got heavy, ABS light came on, check engine light, DSC light, and brake lights come on. Pull over, stop car, shut it down, start it up, all lights cleared except check engine, car feels fine.
I recall seeing something about this in the past from dyno runs, so I just left and went home, hooked up my code reader and found:
P1774 - CAN Wheel Speed Rear Left Wheel, No Signal
P1775 - CAN Wheel Speed Rear Right Wheel, No Signal
Cleared the codes, car is fine. Definitely related to running car with parking brake on, wheels on dyno, rear wheels not spinning.
Anyway, for those in CA coming up on their 6 year (first smog check required if you owned since new) heads up.
Old Mar 10, 2013 | 02:37 PM
Porthos's Avatar
Porthos
Turn it off and turn it back on and you should be fine. It happens when you put it on the dyno.
Old Mar 10, 2013 | 03:03 PM
cnolan
Check engine light did not clear, had to clear w/ code reader. All other errors cleared.
Old Aug 17, 2013 | 01:58 PM
oxyblu2007's Avatar
oxyblu2007
Yes, I just had the same problem today after first CA smog! Tech said during test (DMV link failed and shop computer screwed up) which they felt might have caused the check engine light to come on ( it has never done in the 5 years of owning her) and test was canceled. He said "it" just needs to be reset, and gave me the codes P1774 & P1775 same as cnolan. I called MINI dealership and they would not tell me anything other then bring the car in so they could check it for $$$. I went home and checked the internet and I did the reset with putting in fob, holding down start, trip and RPM **** deal. All better! Took the car back and passed smog and when I left I had the whole light display as well. I went and told the tech who said just drive it and system will reset. All did but he check engine light (again!). At home I did the hold down the start button routine again but the check engine light stayed on. So, we (hubby) then disconnected ground cable to the battery for 10 minutes. All seems fine now. Just plain unnerving to say the least. I have a 2007 with sport package.
Old Aug 17, 2013 | 10:08 PM
Deluded's Avatar
Deluded
It's normal for vehicles to turn on all sort of warning lights after a dyno test in smog shop.
All you have to do is to turn off the car, wait a couple seconds and turn it back on and drive. It should clear itself.
The newer cars have much less tolerance to the shenanigans at smog dyno, so you do have to clear the code with a scanner.
Old Aug 18, 2013 | 08:45 AM
Austinsynthetics's Avatar
Austinsynthetics
For those in the SF Bay Area that don't have a code reader to clear their codes, I can assist if you need.
Old Aug 18, 2013 | 09:08 AM
cerenkov's Avatar
cerenkov
Don't forget most Autozone's, Advanced Auto's, etc. will read and clear the codes for free.
Old Aug 19, 2013 | 04:06 PM
rburna's Avatar
rburna
Had to smog a couple months ago, you could just drive around for 10-15 mins and it'll eventually go away (or pull over, turn off n turn on) no need to clear anything, the mini will eventually clear it automatically.
Old Aug 19, 2013 | 06:03 PM
EHans's Avatar
EHans
That would really freak me out.
What are they doing that causes the computer to puke like that?
Old Aug 19, 2013 | 06:51 PM
Deluded's Avatar
Deluded
It's simple... two wheels spin while the other two wheels don't spin. Computer logs this as an anomaly and tries to warn the user. But when you drive the car and all four wheels rotate at the same rate, it drops the anomaly error.
Old Aug 19, 2013 | 06:57 PM
EHans's Avatar
EHans
Makes sense I guess. Still, that would be a DSC/DTC issue, not full on dash lights.
I think cars have just a bit too much smarts built into them.
bneer
Jul 15, 2019 04:41 PM
Zettinger
Aug 25, 2015 04:04 PM
one73ronin
Aug 19, 2015 12:36 PM
JamJam43087
Aug 16, 2015 02:02 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
