Electrical NCS Expert for dealer-programmable options?
Has anyone else used this software successfully on an r50/52/53 to change the dealer-programmable options?
I have found most of them in the BC1 and KMB modules, but there are still a few that seem not to be documented - does anyone have other options to contribute?
This is what I have so far:
Central Locking
Automatic locking after starting off
Window Regulator/slide/tilt/sunroof
Convenient opening - open windows/sunroof/convertible with key in lock
Lighting
Daytime Driving Light (dimmed high beams as DRL)
BC1 module - HEIMLEUCHTEN
Windscreen wipers
Stop wipers when car is stationary
Fuel Warning
KMB module - AKUSTIK_TANK_RESERVE
Displays/Language
Units
Temperature (degrees f/degrees c)
KMB module - TEMPERATUR_EINHEIT
Central Locking
BC1 module - VERRIEGELN_AUT_AB_X_KM/H
Automatic unlocking after engine offBC1 module - ENTRIEGELN_B_MOTOR_STOP
Unlock all doors with remote (instead of driver's door first press, then all with second press)BC1 module - ZV_SELEKTIV and FERNBEDIENUNG_1/2/3/4
-- set ZV_SELEKTIV nicht_aktiv AND
-- set FERNBEDIENUNG for each key (1-4) to einstiegshilfe
BC1 module - KOMFORTOEFFNUNG_SCHLOSS
Closing windows/sunroof/convertible top from remoteBC1 module - KOMFORTSCHLIESSUNG_FB
Lighting
BC1 module - GED_FL_ALS_DRL
Follow-Me-Home (not active/40s/90s/150s/240s)BC1 module - HEIMLEUCHTEN
Windscreen wipers
BC1 module - STANDRUECKSCHALTUNG
Acoustic Warnings --------------------------------------------
Fuel Warning
Displays/Language
Units
Hi alwzopn,
I am very very interested in do it in my Mini R53 06, but I can´t find in the forum a lot of information to do this in the R53 Minis.
What cable are using it ? what software ? and did you find the instructions for the R53 ?
Please tell me, really I am very interested in this, the first thing that I need is to up the windows and close the sunroof with the control key.
Thank you in advance!!
Okay, I looked back through the BC1 trace file and googled a few options. It looks like
KOMFORTSCHLIESSUNG_FB set to AKTIV
should do it.
NCS Dummy translates this as "COMFORT CLOSING WITH REMOTE (POWER WINDOWS, SUNROOF OR CONVERTIBLE TOP)".
should do it.
Dear alwzopn,
As I told I am very very interested in do this, could you help me ??, please!!
First I will buy my cable, do u have the link to buy exactly the one that you bought ??
Then I will download the software that is here in the 2nd Gen forum, is that one that u use ??
I never did something similar to any of my cars, do I have to be a programmer or an expert in things like this ??
Finally which instructions do u already install ?
Thank you so much, I hope u can answer my question to buy my cable immediately. =)
I don't understand this question.
I have this cable, though from a different vendor - http://cgi.ebay.com/ebaymotors/220869774556
Is it risky ?? the software is difficult ? so you tell me if I do something wrong I could break the Mini´s computer ???
The last question was..... what instructions did you install to your Mini with this software ??
I don´t know what to do!!!!!
I love my car and will be fantastic install/program a few instructions that I want/need, like the one to up the windows with the remote control.
I've never seen any options for this, I don't think it's even possible considering the headlights are on a physical switch. Maybe if the auto headlights were linked to the wipers and/or rain sensor. But like I said, this doesn't sound like an option I've ever seen.
There is a daytime running light option if you use the SSS software. I didn't notice any for on with wipers. A good partner for NCS is NCSdummy.
http://forums.bimmerforums.com/forum....php?t=1553779
http://forums.bimmerforums.com/forum....php?t=1483234
They have done a lot of work.
Just did the daytime running light code and the convienient closing using the key fob. I have purchased the rear fog light and the switch. Does anyone know if this can be turned on using ncs? It's a dealer programmable option.
I found this online, It looks like there is a setting in the BC1 to have auto up on the windows. I just did it on my car and it works.
http://www.rogueeuro.com/forum/viewtopic.php?f=7&t=387
Code:
REAR_FOG_ENABLE aktiv
Hope this helps.
Any update on this? You can turn it on using NCS Expert but curious if you have done it or not.
Digital Speedometer
KMB module - BC_GESCHW_ANZEIGE_DIGITAL
SET TO AKTIV
Alarm Activation (Flashing)
BC1 module - DWA
SET TO AKTIV
Auto-Locking Of Vehicle 2 mins after Unlock (Without Opening Any Doors)
BC1 module - VERRIEGELN_AUT_NACH_2_MIN
SET TO AKTIV
SET TO AKTIV
BC1 module - DWA
SET TO AKTIV
SET TO AKTIV
