Electrical NCS Expert for dealer-programmable options?
Old Oct 4, 2011 | 07:12 AM
alwzopn's Avatar
alwzopn
Has anyone else used this software successfully on an r50/52/53 to change the dealer-programmable options?
I have found most of them in the BC1 and KMB modules, but there are still a few that seem not to be documented - does anyone have other options to contribute?
This is what I have so far:
Central Locking
Automatic locking after starting off
BC1 module - VERRIEGELN_AUT_AB_X_KM/H
Automatic unlocking after engine off
BC1 module - ENTRIEGELN_B_MOTOR_STOP
Unlock all doors with remote (instead of driver's door first press, then all with second press)
BC1 module - ZV_SELEKTIV and FERNBEDIENUNG_1/2/3/4
-- set ZV_SELEKTIV nicht_aktiv AND
-- set FERNBEDIENUNG for each key (1-4) to einstiegshilfe
Window Regulator/slide/tilt/sunroof
Convenient opening - open windows/sunroof/convertible with key in lock
BC1 module - KOMFORTOEFFNUNG_SCHLOSS
Closing windows/sunroof/convertible top from remote
BC1 module - KOMFORTSCHLIESSUNG_FB
Lighting
Daytime Driving Light (dimmed high beams as DRL)
BC1 module - GED_FL_ALS_DRL
Follow-Me-Home (not active/40s/90s/150s/240s)
BC1 module - HEIMLEUCHTEN
Windscreen wipers
Stop wipers when car is stationary
BC1 module - STANDRUECKSCHALTUNG
Acoustic Warnings
Fuel Warning
KMB module - AKUSTIK_TANK_RESERVE
Displays/Language
Units
Temperature (degrees f/degrees c)
KMB module - TEMPERATUR_EINHEIT
Old Oct 9, 2011 | 09:37 PM
mariocaz's Avatar
mariocaz
Hi alwzopn,
I am very very interested in do it in my Mini R53 06, but I can´t find in the forum a lot of information to do this in the R53 Minis.
What cable are using it ? what software ? and did you find the instructions for the R53 ?
Please tell me, really I am very interested in this, the first thing that I need is to up the windows and close the sunroof with the control key.
Thank you in advance!!
Old Oct 11, 2011 | 12:32 PM
alwzopn's Avatar
alwzopn
I don't think there's a setting in the 1st gen for auto-up windows.
Old Oct 11, 2011 | 12:42 PM
mariocaz's Avatar
mariocaz
Of course it can, check the video:
http://www.youtube.com/watch?v=9r-Ehn_fdyU
Old Oct 11, 2011 | 06:08 PM
alwzopn's Avatar
alwzopn
Okay, I looked back through the BC1 trace file and googled a few options. It looks like
KOMFORTSCHLIESSUNG_FB set to AKTIV
should do it.
NCS Dummy translates this as "COMFORT CLOSING WITH REMOTE (POWER WINDOWS, SUNROOF OR CONVERTIBLE TOP)".
Old Oct 11, 2011 | 06:26 PM
mariocaz's Avatar
mariocaz
Dear alwzopn,
As I told I am very very interested in do this, could you help me ??, please!!
First I will buy my cable, do u have the link to buy exactly the one that you bought ??
Then I will download the software that is here in the 2nd Gen forum, is that one that u use ??
I never did something similar to any of my cars, do I have to be a programmer or an expert in things like this ??
Finally which instructions do u already install ?
Thank you so much, I hope u can answer my question to buy my cable immediately. =)
Old Oct 11, 2011 | 06:41 PM
alwzopn's Avatar
alwzopn
I have this cable, though from a different vendor - http://cgi.ebay.com/ebaymotors/220869774556
I did follow the directions from the 2nd gen forum - I used to have an R56, and the same installation methods apply to both.
I would suggest being very careful and following all the directions very closely. It is possible to mis-code the modules and break something. If you aren't comfortable with this, you may not want to go ahead with this.
I don't understand this question.
Old Oct 11, 2011 | 06:53 PM
mariocaz's Avatar
mariocaz
Ok I will check it, thx.
Ok, now I have fear hehehe, I know very well the computer things, but as I told you I never do/did something like this.
Is it risky ?? the software is difficult ? so you tell me if I do something wrong I could break the Mini´s computer ???
The last question was..... what instructions did you install to your Mini with this software ??
I don´t know what to do!!!!!
I love my car and will be fantastic install/program a few instructions that I want/need, like the one to up the windows with the remote control.
Old Oct 11, 2011 | 06:59 PM
mariocaz's Avatar
mariocaz
alwzopn, I found this one:
http://www.ebay.com/itm/BMW-USB-OBD-...item1c1fa41646
What do u think ?
Old Oct 11, 2011 | 08:48 PM
alwzopn's Avatar
alwzopn
It is risky. I have read that there have been reports of modules being damaged by bad coding. If this is not a chance you want to take, you should definitely buy the windows up module.
I used it to enable one-touch unlock for all doors with the remote and to disable the DRLs.
What do u think ?
Looks like that one ships from the UK. If you have no problem with that, then it does look like it should work.
Old Nov 7, 2011 | 04:33 PM
alwzopn's Avatar
alwzopn
BUMP - Added a few new options and their settings to the OP.
Old Nov 25, 2011 | 10:28 AM
scf's Avatar
scf
Is this also possible with an R53? If so, what software is necessary to drive the cable?
Old Dec 5, 2011 | 06:14 AM
alwzopn's Avatar
alwzopn
NCS Expert is the software.
I don't understand your question about the R53 - possible as opposed to what? This is the 1st Gen forum, isn't it?
Old Dec 5, 2011 | 07:28 AM
scf's Avatar
scf
Ugh, yah.
Old Jan 18, 2012 | 09:54 AM
hyde76's Avatar
hyde76
My Father in law with a 2006 R53 is interested in having his lights come on when the windshield wipers come on. Does anyone know if this is possible?
Old Feb 19, 2012 | 08:19 AM
alwzopn's Avatar
alwzopn
I've never seen any options for this, I don't think it's even possible considering the headlights are on a physical switch. Maybe if the auto headlights were linked to the wipers and/or rain sensor. But like I said, this doesn't sound like an option I've ever seen.
Old Feb 20, 2012 | 11:33 AM
HRM's Avatar
HRM
There is a daytime running light option if you use the SSS software. I didn't notice any for on with wipers. A good partner for NCS is NCSdummy.
http://forums.bimmerforums.com/forum....php?t=1553779
http://forums.bimmerforums.com/forum....php?t=1483234
They have done a lot of work.
Old Feb 27, 2012 | 05:22 PM
youngw682eni's Avatar
youngw682eni
Just did the daytime running light code and the convienient closing using the key fob. I have purchased the rear fog light and the switch. Does anyone know if this can be turned on using ncs? It's a dealer programmable option.
Old Apr 2, 2012 | 01:10 AM
NWminiguy's Avatar
NWminiguy
I found this online, It looks like there is a setting in the BC1 to have auto up on the windows. I just did it on my car and it works.
http://www.rogueeuro.com/forum/viewtopic.php?f=7&t=387
Old Apr 2, 2012 | 01:13 AM
NWminiguy's Avatar
NWminiguy
I dont have the rear fog light switch to test, so you will have to do a little trial and error. It looks like in NCS for BC1 just set 'REAR_FOG_ENABLE' line to active
Code:
REAR_FOG_ENABLE
	aktiv
Old Apr 6, 2012 | 01:25 PM
seamill's Avatar
seamill
Quick question for the OP. We use the R56 datens for the R53, correct? Thanks!
Old Apr 10, 2012 | 03:40 PM
NWminiguy's Avatar
NWminiguy
I think what the OP was talking about was to just follow the write up from the R56 guys. After you get the software installed you should have all the data files for any generation car, and you use what is appropriate for your car.
Hope this helps.
Old Apr 21, 2012 | 06:01 PM
inkspot1967's Avatar
inkspot1967
interesting what and where can i get a cable/program i need for a 2008 MCs cabrio
how would i be able to setup so both my doors unlock together and windows up and top up by remote
Old Jun 7, 2012 | 08:28 PM
TRIPLE_O's Avatar
TRIPLE_O
Any update on this? You can turn it on using NCS Expert but curious if you have done it or not.
Old Jun 7, 2012 | 08:58 PM
TRIPLE_O's Avatar
TRIPLE_O
Digital Speedometer
KMB module - BC_GESCHW_ANZEIGE_DIGITAL
SET TO AKTIV
Alarm Activation (Flashing)
BC1 module - DWA
SET TO AKTIV
Auto-Locking Of Vehicle 2 mins after Unlock (Without Opening Any Doors)
BC1 module - VERRIEGELN_AUT_NACH_2_MIN
SET TO AKTIV
