R50/53 Tensioner stop
Old Sep 24, 2008 | 03:51 PM
Martin Brenneke's Avatar
Martin Brenneke
Tensioner stop
I am going to buy a tensioner stop for my car and would like to know which one Detroit tuned or GTT is the better item. any info would be appreciated.
Old Sep 24, 2008 | 03:59 PM
JAB 67's Avatar
JAB 67
IMO, Detroit Tuned.
Old Sep 24, 2008 | 07:17 PM
HighLife4136's Avatar
HighLife4136
Detroit Tuned. No rattles that'll drive you nuts. If you're only running on the track, maybe consider the GTT/Minspeed style of stop.
Old Sep 25, 2008 | 07:26 AM
Bigshot's Avatar
Bigshot
There are many posts about the DT stop failing, go with the Minspeed one.
Old Sep 25, 2008 | 12:09 PM
HighLife4136
Out of curiosity, could you link to a couple of the posts? The Minspeed is without a doubt beefier, but gawd it rattles like mad.
Old Sep 25, 2008 | 02:52 PM
pepegrande008's Avatar
pepegrande008
no problems with my dt. idk though havnt had my tensioner completely fail though
Old Sep 25, 2008 | 05:37 PM
//MZero's Avatar
//MZero
hmm, I don't like hearing that the DT stops failed, what the hell is the point of it then? My tensioner has never failed and I guess that is the only test for the stop, I hope my tensioner nor DT stop fail
Old Sep 25, 2008 | 07:43 PM
Partsman's Avatar
Partsman
Legion_of_Doom
The tensioner stop is not for the failure of the tensioner...it's for the failure of the belt.
Trying to keep all that spring tension under control after a belt snaps is very difficult with cable that has crimped ends.
Obviously the bar type tensioner stop will be way more effective, but they do rattle like crazy. I tried everything to keep the one I had from rattling...it just wasn't happening.
The one I have now is made with stainless cable and looped ends crimped professionally by my local marine rigger.
The moral of the story is to keep an eye on your belt.
Old Sep 25, 2008 | 09:49 PM
Poppa Bear's Avatar
Poppa Bear
I knew I needed a stop after the ~$1000 repair bill when the belt failed and tore everything up. If I'd known that this was even a potential problem, I would've installed the stop as part of the pulley upgrade, just for GP.
As for which stop, I actually liked the DT design over Minspeed because it appeared to me that the top bolt for the Minspeed would have to remain somewhat loose in order to allow the bar to 'adjust' for normal belt tensioning. And, to be quite honest, though I'd not heard of any failures of the DT design, I didn't do any detailed research beyond what was available. Not like choosing between an Alta pulley or M7. The design of the DT stop seems adequate as it was crimped and welded. Also, it appears to be be sufficient to at least slow the disintegration down to a less expensive level.
Regardless of which design, I recommend that everyone who changes their pulleys also include this inexpensive insurance as part of the whole project. Otherwise, you too might have a nice collection of parts to remember the whole adventure from, like these!!
Cheers!!
Old Sep 26, 2008 | 07:25 AM
Bigshot's Avatar
Bigshot
Check out this thread for one example......https://www.northamericanmotoring.co...d.php?t=147455
And remember that these are stock pullied cars.
ccfirelt
Oct 18, 2015 01:02 PM
martinb
Oct 7, 2015 05:00 PM
Vaderm34
Sep 27, 2015 09:25 PM
rt808
Sep 25, 2015 01:59 PM
daviday
Sep 25, 2015 01:31 AM
