MidCal MINIs MidCal MINIs...filling the MINI void between Northern and Southern California. Visit the club site at midcalminis.com
A Big Thanks
Old Jul 25, 2008 | 08:24 AM
  #12951
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Have you guys seen the new intercooler that Dr.Steve is going to be stocking? Just make sure you don't buy 27 of them.
Old Jul 25, 2008 | 08:36 AM
  #12952
JIMINNI's Avatar
JIMINNI
The pic didn't work Joe?
Old Jul 25, 2008 | 08:49 AM
  #12953
SRTech's Avatar
SRTech
I'll stock them if you'll buy all of them.
Steve
Old Jul 25, 2008 | 11:02 AM
  #12954
JIMINNI's Avatar
JIMINNI
Steve
What the heck are they? Steve, are you going to be around tomorrow morning? 9am.
Old Jul 25, 2008 | 11:47 AM
  #12955
Fracky's Avatar
Fracky
They're TMIC's with flair.
Old Jul 25, 2008 | 12:28 PM
  #12956
SRTech's Avatar
SRTech
No, I'll be in the Bay Area. I'll be here most of Sunday, though.
Steve
Old Jul 25, 2008 | 01:41 PM
  #12957
checkers's Avatar
checkers
It's getting close to time to throw Fracky out and let Checkers back in.
Old Jul 25, 2008 | 05:38 PM
  #12958
JIMINNI's Avatar
JIMINNI
Old Jul 25, 2008 | 09:00 PM
  #12959
ShellyQ's Avatar
ShellyQ
I would like the purple one. I know, I know, It won't fit on my car.
Shelly
Old Jul 25, 2008 | 09:23 PM
  #12960
SRTech's Avatar
SRTech
Yep, I got Frackys gauges fixed and now I just need to find a better intake air temp sender so they are a little more robust. Then he has to drive for a couple of weeks to remember his MINI.
Steve
Old Jul 25, 2008 | 11:13 PM
  #12961
riversong's Avatar
riversong
Shelly
With Steve's special tool we can make it fit.
Old Jul 26, 2008 | 09:31 PM
  #12962
03Eeyore's Avatar
03Eeyore
Hey Steve,
Had a problem with the car today! The service engine light came on as we were coming home from Lee Vining. We stopped about four or five times coming home due to the visit with tom's brother and fire. The last time I started the car the light went off. If I brought it down would you be able to tell what happened even if the light is no longer on??? Now Tom was the one driving when he light came on so I did not notice anything out of the ordinary. But after we stopped I dove the rest of the way and she felt fine! I know that I am only about 600 miles over my standard oil change. What do you think??
Tina
Old Jul 26, 2008 | 09:52 PM
  #12963
03Eeyore's Avatar
03Eeyore
Shelly
Dang Shelly, I said the same thing. I wanted the purple one too and I knew it would not fit my car! That is just TOO SAD!
Tina
Old Jul 26, 2008 | 10:06 PM
  #12964
SRTech's Avatar
SRTech
Originally Posted by 03Eeyore
Hey Steve,
Tina
Altitude. Tioga Pass does that to some cars. The code may not be stored after the light goes out on lessor problems.
Steve
Old Jul 28, 2008 | 09:21 AM
  #12965
03Eeyore's Avatar
03Eeyore
That is what I thought. I won't worry about it then. I will stop by later!!!
Tina
Old Jul 28, 2008 | 11:14 AM
  #12966
SRTech's Avatar
SRTech
Tina
If you drop by the shop today, would you bring me a couple of gallons of distilled water please? Thanks.
Steve
Old Jul 30, 2008 | 02:54 PM
  #12967
SRTech's Avatar
SRTech
I'm doing the Hooters thing again after work. I'll be there around 6:30pm-7:00pm. If I don't go, I'll end up working half the night.
Steve
Old Jul 30, 2008 | 05:36 PM
  #12968
CAP49's Avatar
CAP49
Steve
Ah cleavage. It doth soothe the soul.
Old Jul 30, 2008 | 05:51 PM
  #12969
SRTech's Avatar
SRTech
Hey, I've got some track-junkie **** for you that Willum dropped off.
Steve
Old Jul 31, 2008 | 09:41 AM
  #12970
willum's Avatar
willum
Steve,
Thanks again for your GREAT work yesterday. Ran like a champ all the way home. Will follow up when I have more info from the vendor. Would have been very "ugly" indeed.
Old Jul 31, 2008 | 10:02 AM
  #12971
Fracky's Avatar
Fracky
Originally Posted by willum
Steve,
What happoneded?
Old Jul 31, 2008 | 10:20 AM
  #12972
willum's Avatar
willum
Lets just say that my 2% crank pulley was about "grenade". EBmini diagnosed the grinding/creaking noise as a bad tensioner pulley but when they went to replace it (along with the timing cover gasket for an ongoing oil leak), they discovered the creak was coming from the aftermarket crank pulley. You could wiggle the pulley with the belt off and replicate the sound. FYI...a stock OEM crank pulley is $499. I have yet to talk to manufacture of said pulley, but I have a new Alta 2%. Wasn't an Alta that failed.
Old Jul 31, 2008 | 06:21 PM
  #12973
SRTech's Avatar
SRTech
Fracky, you can retrieve the Frackmobile tomorrow afternoon or I can bring it to CASA if I can get a ride back after. I am looking for some new sensors for your PLX gauges that will hopefully be more robust. I repaired the broken sensor, but they both won't last long before getting bumped and broken again. This will give you a change to get the bungs welded so I can hook up the other two sensors when I get the new ones. Also, PLX is working on a combo vacuum/boost sensor so we can remove the to Promini gauges which look like hell next to the PLXs. You can get your MINI ready for Euro Sunday and Checkers can move into your spot.
Steve
Old Jul 31, 2008 | 10:16 PM
  #12974
Fracky's Avatar
Fracky
Steve
Sweet! I'll be by sometime tomorrow. I'll call Muffler Outpost so they can squeeze me into their schedule on having the bungs welded. Oh, do we have the sensors for the bungs? When do I get to come back to finish the gauge install? Oh, do I need to help look for AIT probes or does PLX have that covered? Sid/MSFITOY has the AIT setup on his car, so we could PM him to get his thoughts on something with some longevity. I'm cool off EuroSunday.
Old Aug 3, 2008 | 04:56 PM
  #12975
Fracky's Avatar
Fracky
Dr.Steve, you were right about the large temperature difference pre & post DFIC (evident via PLX AIT probes). Holy smokes!! Just in the drive from CMS to the house there were moments that under load & at speed the delta was nearly 100degrees. As I spend more time on the road I'll post the figures I'm seeing.
Note: It'd sure be interesting to data log this & post for all the DFIC haters.
