MidCal MINIs MidCal MINIs...filling the MINI void between Northern and Southern California. Visit the club site at midcalminis.com
A Big Thanks
Old Feb 26, 2008 | 03:15 PM
  #12151
Scooby03's Avatar
Scooby03
Originally Posted by Fracky
Niiiiiiiice!!!!
We took out the rap crap, and put in some southern rock.
Old Feb 26, 2008 | 03:21 PM
  #12152
JIMINNI's Avatar
JIMINNI
Let us know what code you're throwing if it is a code. It might be helpful for our lil' clan to stay up on which modification combinations can potentially cause codes. Hopefully your SES light is not serious. Buuuuuuut....if you burned your head up, it could be time to upgrade, ie. "Merry Christmas & thank you for the new RMW head".
Note: Dr.Steve, how's the Frackmobile coming along?
Dang dude a head? I'm hopeful it's just a gas cap .
I have a better station for him .
Old Feb 26, 2008 | 03:23 PM
  #12153
SRTech's Avatar
SRTech
Niiiiiiiice!!!!
Ok, the steering wheel control module seems to be the main problem. I've disconnected it and wired the system without it. The remote LED connection is broken so the LED will need to be replaced if you want to use this thing. I am also going to replace the 10'-12' of wound up signal cables that run from the AV unit to amps. They only need to be about 2' long and it makes a real mess. It looks like someone used whatever they had lying around to wire up your system. I'm running a 10amp battery charger to keep your battery from going dead. I wouldn't advise running the stereo with the car off for long.
Steve
Old Feb 26, 2008 | 09:39 PM
  #12154
ChrisW's Avatar
ChrisW
So thursday forsure on my brakes?
Old Feb 26, 2008 | 09:48 PM
  #12155
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Steve
Weird, the Swi-X steering wheel control module? I never would've thought of that item as one of the culprits for my nasty stereo problem. So what keeps draining the battery dead if the positive lead for the stereo isn't connected? It sounds like there's a ground issue somewhere causing the battery to lose its juice. I like having my stereo wheel controls & not having to fumble around for the remote, so is it possible to replace the LED connection or do I have get a complete new Swi-x?
Oh, can I have the stereo cables back? Maybe I can use em' for something else down the line. You're making major headway Dr.Steve!!!
Old Feb 26, 2008 | 09:51 PM
  #12156
ChrisW's Avatar
ChrisW
I think you need to throw your mini away and buy an 05/06.
Old Feb 27, 2008 | 12:26 AM
  #12157
MINICHEF's Avatar
MINICHEF
True Dat
Old Feb 27, 2008 | 06:29 AM
  #12158
Fracky's Avatar
Fracky
I have a long-term love/hate relationship with my Mini. For better or worse, I'm sticking with the Frackmobile. If I were to get a new car, I'd probably get a Smart or the Exige S.
Old Feb 27, 2008 | 07:43 AM
  #12159
SRTech's Avatar
SRTech
We are addressing the past malpractices and the Frackmobile will be better than new. Swi-X steering wheel control module itself is not the problem, only the installation. Stranded wires attached by one strand, no excess length so the wires are stretched to the limit causing any movement to break a connection. It's a wonder this stuff worked at all. Question: is there an FM receiver with this system? I pulled out an antenna wire with an adaptor with a broken wire that was stuffed back inside the dash. The head unit wiring diagram doesn't show an antenna connection, but I don't have the user manual so I'm not sure what's supposed to be there.
Steve
Old Feb 27, 2008 | 08:14 AM
  #12160
Fracky's Avatar
Fracky
Steve
Ahhhh so, young grasshoppa. <said in my best David Carradine accent>
If the Swi-X was super-stretched (which it probably was) do I/we need replacement parts so everything is in proper working order? There is a connection for an antenna (on the back of the Pioneer brain unit), but I wouldn't worry about it. I haven't listened to the radio in my car in years. Shoot, I barely know what radio stations are in Fresno. Oh, I can drop off the user manual if you'd like tomorrow since I'm giving Chris a ride back to work. The electronic file is 20.2 megs, so it's past the e-mail phase for my .Mac server.
Old Feb 27, 2008 | 08:31 AM
  #12161
SRTech's Avatar
SRTech
If parts are available for the Swi-X, all we need is the remote LED. Brain unit? Is that the head unit? The wiring diagram shows the FM unit as a separate part and I haven't seen it in my travels.
Steve
Old Feb 27, 2008 | 08:55 AM
  #12162
JIMINNI's Avatar
JIMINNI
Shoot you barely have driven your car in the last year .
Old Feb 27, 2008 | 08:56 AM
  #12163
JIMINNI's Avatar
JIMINNI
Brad, can you order the oil filter for my wifes car? Also do you know the schedual for tomorrow yet?
Old Feb 27, 2008 | 09:58 AM
  #12164
Fracky's Avatar
Fracky
Steve
Well, there's the head unit (in the dash), which is really a display & processing unit. Then there's the brain/controller which is in the back under the NO2 bottle. If the FM unit is separate then I don't have it, which is a-ok. I'll hop on Swi-X later this morning to check out parts availability/applicability.
Touche!!!
Old Feb 27, 2008 | 10:54 AM
  #12165
Scooby03's Avatar
Scooby03
I think I still have the info on your wifes car, and will get the filter. Are we going to be doing this all the time? If so, I will get a few of them.
Calipers should be here by 11am tomorrow, then Steve will do the install. Should be fine after that.
Old Feb 27, 2008 | 11:36 AM
  #12166
JIMINNI's Avatar
JIMINNI
Yea I think you guy's will be doing these, as long as the price is good . As little as she drives, I think 2 filters would be ok for now. I'm thinking I will take a half day off next week and bring maybe both cars down? What you think?
Old Feb 27, 2008 | 12:36 PM
  #12167
JIMINNI's Avatar
JIMINNI
Cant wait to get my new goodie:
Old Feb 27, 2008 | 01:13 PM
  #12168
ChrisW's Avatar
ChrisW
I'll be by before 11 to drop the car off then. About how long do you think it will take?
Old Feb 27, 2008 | 01:39 PM
  #12169
SRTech's Avatar
SRTech
Around 4 hours.
Steve
Old Feb 27, 2008 | 09:17 PM
  #12170
ChrisW's Avatar
ChrisW
Around 4 hours.
Steve
So I should be able to pick it up by 4 or so then?
Old Feb 28, 2008 | 08:52 AM
  #12171
SRTech's Avatar
SRTech
Depends on when the parts get here. I don't want to start before that because you wouldn't have a car if the parts didn't arrive for some reason.
Steve
Old Feb 28, 2008 | 09:06 AM
  #12172
CAP49's Avatar
CAP49
SCCA Auto-X back on @ Castle
The final signing and details aren't done yet but it looks like we'll be running Solo2 events at a parking lot at Castle this season after all.This is the old site that was used for year before we got the 10 acre site we all know and love.This pad is approx. 4 to 5 acres and is amoungst the buildings in the middle of the base. Check the SCCA website in a few days for the new season schedule.
Old Feb 28, 2008 | 09:12 AM
  #12173
Scooby03's Avatar
Scooby03
I will let you know when the parts get here, after we check they are the right ones.
Old Feb 28, 2008 | 10:21 AM
  #12174
willum's Avatar
willum
Cool....
Old Feb 28, 2008 | 10:30 AM
  #12175
Scooby03's Avatar
Scooby03
Chris,
The right calipers showed up.
