JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW Suspension
Old Feb 19, 2005 | 07:50 PM
ChiliCooperS's Avatar
ChiliCooperS
JCW Suspension
Does anybody know how much the JCW Suspension lowers the MINI? I wan't a lower car because I'm rollin on 17s but I don't want them too low.
Thanks in Advance...
"Chili" AkA Mikey
Old Feb 19, 2005 | 08:21 PM
searocko's Avatar
searocko
"Chili" AkA Mikey
According to a Motoring File review of an '05 with the JCW suspension, it's a 10mm drop. What's interesting is his impressions on the ride quality. Sounds like a great setup and I plan to install it when I get my MCS!
Old Feb 20, 2005 | 10:53 AM
GrumpyGills's Avatar
GrumpyGills
Check these images out...
We have the JCW Suspension with 17" and the visual difference is nominal.
Check these 3 images out:
1- Shows the springs
2- Shows a Cooper with 15" wheels in front of a Cooper S with JCW Suspension
3- Shows a side view of the Cooper S with suspension
You can see for yourself, not much difference at all! And, very worth it.
Attached Thumbnails JCW Suspension-jcw-bloomers.jpg   JCW Suspension-suspension_comparison.jpg   JCW Suspension-height.jpg
Old Feb 20, 2005 | 12:37 PM
XAlfa's Avatar
XAlfa
How many miles on the new suspension when you snapped these pics? Just wondering if she still might "settle" a bit.
Old Feb 20, 2005 | 03:39 PM
kbseto's Avatar
kbseto
question...would it be recommended to get rear control arms when getting the jcw suspension due to the possible change in alignment, eg. camber? or is there minimal change in alignment with the jcw suspension, such that the alignment specs are still within stock range?
i believe most owners who have gotten h-sports springs, which is ~1" drop (vs. 10mm drop with jcw), have also gotten rear control arms to adjust out the additional negative camber brought on by the h-sports springs. but since the jcw suspension is less of a drop, is there subsequently less of a change in alignment, enuff that the stock alignment specs are maintained?
Old Feb 21, 2005 | 05:55 AM
KevinR's Avatar
KevinR
Originally Posted by GrumpyGills
2- Shows a Cooper with 16" wheels in front of a Cooper S with JCW Suspension
I think the "holies" are 15", not 16". Not that it matters much.
Serious question. Can you tell us why it is "very" worth it? I'd really like to get the honest impressions from someone who's had the kit for a while.
And to the group at large: has anyone fitted this suspension to a pre- 07/04 car?
Old Feb 21, 2005 | 05:59 AM
kenchan's Avatar
kenchan
There's still plenty of wheel gap there on that pict... I would recommend
the H-Sports and get the job done or leave it stock unless you are going
for particular spring rates.
Old Feb 21, 2005 | 06:48 AM
Wraith1416's Avatar
Wraith1416
i do so declare, that that is a lift kit MINI jk grumpygills, but kenchans right, if you want it really dropped go with H-sports. i've had mine for 6 months, no problems thru a michigan winter.
Old Feb 21, 2005 | 09:39 AM
ChiliCooperS
Everybody is saying that the suspension is more than worth the price, what particulary about is better than stock? What other options could I have once I get the suspension kit, that would lower my car about 2-4 cm ?
Old Feb 21, 2005 | 12:33 PM
Darkness's Avatar
Darkness
I'm going to try to talk my dealer into selling me the MCS struts and springs alone and then add my own sway bars since the SS+ ones are subpar
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
