JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
Bushing Upgrade
Old Aug 8, 2021 | 09:49 AM
tnitties1's Avatar
tnitties1
Bushing Upgrade
I’ll be doing a clutch job soon and wanted to get my front subframe bushings all swapped out as the car has 120,000 miles on her. Does anyone have a list of all the bushings I should be replacing?
Old Aug 8, 2021 | 11:18 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I JUST got done with this job! I replaced the front control arm bushings and front sway bar bushings. You might also consider adding the lower engine mount inserts. No other bushings in the front of the car.
This is what I used:
https://www.waymotorworks.com/powerf...7-r58-r59.html
https://www.waymotorworks.com/powerf...unt-large.html
https://www.ecstuning.com/b-superpro...pf227624k~spr/
Old Aug 9, 2021 | 08:17 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The biggest and most important is the front control arm bushings
We also do the front sway bar bushings with them as you will already have them unbolted
And doing the insert for the lower engine mount is a great mod as it will reduce engine rock and improve the shifting feel.
This is also another little insert bushing that fills in the gaps in the trans mount to reduce rocking even more.
Since you are doing a clutch job I would really encourage you to do the LSD if you are into performance at all as this will be the biggest gain in getting the HP to the ground and requires the trans to be removed to install.
https://www.waymotorworks.com/quaife...ferential.html
Old Aug 9, 2021 | 11:34 AM
troyegly's Avatar
troyegly
How many hours to replace control arm and sway bar bushings? Lower engine mount inserts - Can't say enough about these! Mine was complete toast, I thought I needed new suspension in a major way, when hitting bumps the entire car would move! With the inserts and new lower engine mount it is a night and day difference.
Old Aug 9, 2021 | 12:17 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I bought the loaded control arm bushings brackets from Way Motors, so I didn't have to mess around trying to get the old bushing removed and the new one installed. I also had the whole subframe dropped to facilitate the clutch replacement. If I had to guess how long just to drop the subframe and replace the bushings... maybe 2-3 hours? You could easily knock it out on a Saturday afternoon.
Old Aug 9, 2021 | 06:14 PM
Yoshimura 1's Avatar
Yoshimura 1
This is definitely something I should look into
Old Aug 22, 2021 | 10:35 AM
Yoshimura 1
I'm getting ready to order these parts and do this on two vehicles.
Old Aug 24, 2021 | 12:52 PM
We just got in some more PSB bushings. https://www.ecstuning.com/b-psb-parts/v-mini/
Its another option.
I set to install these on my R58 jcw.
Old Dec 31, 2021 | 01:51 PM
Yoshimura 1
What's the stock sway bar size on 2008 R56S
Old Jan 3, 2022 | 12:42 PM
Rear is like 17mm , 18 for spot and JCW suspension
https://www.ecstuning.com/Mini-2008-...Rear/Bushings/
Old Jan 3, 2022 | 03:58 PM
Yoshimura 1
I thought I posted about the front sway bar it has the sport suspension.
Old Jan 4, 2022 | 07:24 AM
23.5 with https://www.realoem.com/bmw/enUS/sho...78#31356772844
https://www.ecstuning.com/Mini-2008-...way_Bar/Front/
dcantwell
Jul 22, 2015 09:48 AM
astroBlackMetallic_Mini
Suspension
Aug 15, 2013 08:19 PM
JAB 67
Suspension
Nov 18, 2010 07:49 PM
MC_Sean
Suspension
Jan 11, 2010 09:12 AM
brianbreeze
Mar 21, 2008 05:44 AM
