Suspension Can I upgrade to polyurethane bushings?
Old Apr 30, 2013 | 07:54 AM
astroBlackMetallic_Mini's Avatar
Mini tech said my front A arm bushings were starting to push out some. Car should be fine for a while, but I'm going to start planning ahead.
So, do they make poly bushings for that part of the suspension?
Any other bushings I could / should upgrade when I get the work done?
Old Apr 30, 2013 | 08:04 AM
Braminator's Avatar
Braminator
Here ya go
http://powerflexusa.com/minicooper01-06.aspx
Old May 5, 2013 | 08:32 PM
andyroo's Avatar
andyroo
Yup. Waymotorworks sells them prepressed into brackets...makes installation a lot easier (or cheaper if you're not doing yourself).
- andy
Old May 6, 2013 | 08:32 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Here you go
http://www.waymotorworks.com/powerfl...shing-kit.html
there is also front sway bar bushings, and a steering rack mount bushing in poly for you.
Old May 6, 2013 | 08:55 PM
Way, what else do you suggest I get replaced / upgraded?
Here's the list so far:
Front A arm bushings
Front sway bar bushings
Steering rack bushings
Anything else?
Old May 6, 2013 | 09:37 PM
Also, any chance I could get a package deal discount or something?
Old May 9, 2013 | 05:29 PM
Melangell's Avatar
Melangell
Astro, I had a philosophy and it has served me well with a new MINI... I will continue it as The Dread Pirate gets older... Fix/replace any and all things that need to be whenever they need to be.
Old May 9, 2013 | 06:55 PM
WayMotorWorks
Vendor
Anything else?
That should be all you need as long as the ball joints are in good shape.
We can ship these in one USPS flat rate box to make the shipping as cheap as possible, so ignore the shipping price the website comes up with.
Old May 9, 2013 | 10:25 PM
Sounds good! Thanks! I'll order in a month or 2. Won't be back in FL for a while to have them installed.
Old Jul 17, 2013 | 03:11 PM
mgrant's Avatar
mgrant
while your replacing the bushings I would go ahead and replace the lower engine mount bushing and the gearbox mount bushing also
Old Jul 18, 2013 | 11:20 AM
airwick's Avatar
airwick
i ordered mine through one of the forum vendors and used a discount code. i think its like 5% off.
Old Jul 18, 2013 | 11:40 AM
bahawton's Avatar
bahawton
FYI- They squeak within a thousand miles and cause a lot more interior noise & rattles.
Yes I used the supplied lube on my bushings.
Old Jul 18, 2013 | 11:47 AM
cristo's Avatar
cristo
Alliance Member
I've had zero squeaks from Powerflex LCA, engine, and sway bushings and it's been
several years since they all went in. Yes, more vibration at idle with the a/c on if
you put most of the engine/trans mounts in, but barely any more than stock with
one large upper and one large lower engine mount insert.
Old Aug 15, 2013 | 08:19 PM
ajstefanacci's Avatar
ajstefanacci
I did all those bushings when I did my clutch cause I had the subframe out. I got all the ball joints as well on eBay and I think there was a set of all four for 60 or 70 bucks. I thought it was a good idea to give the front end a refresh since I have 100000 miles.
molala
Oct 2, 2015 01:53 PM
Sep 4, 2015 12:20 PM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
