Suspension rear coilovers bumpy
Old Aug 10, 2013 | 10:55 AM
Javskies's Avatar
Javskies
so i have Eibach Pro-Street Coilovers on my mini s. i have noticed that that over bumps, especially speed bumps, the front feel nice and soft when i go over but the rears are hard and rough when they land. i was wondering what i can do to make it softer? would new spring work or would i have to get replacement shocks? thanks!
Old Aug 13, 2013 | 09:20 AM
Javskies's Avatar
Javskies
Bump
Old Aug 16, 2013 | 06:23 AM
Javskies's Avatar
Javskies
ok so after more speed bump testing lol. it seems only the driver side shock is blown. also looking at it it seems it got bent a bit as well so that could also be a problem. this is also the coil that has irreversibly seized collars lol. would i be able to order a replacement through eibach?
Old Aug 16, 2013 | 08:09 AM
GreekDrifter91's Avatar
GreekDrifter91
see if they can just service it, if not just get a new one. its worth a shot. its usually cheaper to get the thing serviced then getting a replacement one.
Old Aug 16, 2013 | 08:10 AM
v10climber's Avatar
v10climber
Wait the rear drivers side shock is blown? I'd be quite concerned if the shock shaft was bent. There have been instances of shocks snapping in two in the rears of these cars. BC coilovers come to mind but some searching would turn up some cases of shocks snapping. If that shock snaps it could be very very bad news.
Yes you should be able to order a replacement shock from Eibach.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ebowling
90
Aug 4, 2019 09:15 AM
luisfv56
Aug 22, 2015 12:42 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
