JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Problem finding rotor fitment for my factory JCW with 8/2006 production date
Old Mar 1, 2018 | 02:47 PM
wikdr53's Avatar
wikdr53
Hello, I have a 2006 R52 Factory JCW with a production date of 8/2006. So it has the red JCW calipers with the 294mm front rotor and 14mm lugs. I am looking at the Stoptech Rotor Street kit, however they show nothing for 2006 for any model with 14mm lugs. Checking the specs, it looks like the front rotors of my JCW are the same as a 2007 R56. However the rear rotors seem to be .2mm different in diameter. Any clarification would be a great help.
Thanks, Jim
Old Mar 1, 2018 | 03:02 PM
jasonp's Avatar
jasonp
I have 14mm lugs on the front of my 05 s and the street kit fit no problem.
Old Mar 1, 2018 | 06:51 PM
wikdr53's Avatar
wikdr53
According to mini the 14mm lugs did not start until july 2006. All mini's prior to that had 12mm lugs.
Old Mar 2, 2018 | 03:45 AM
JackMac's Avatar
JackMac
See the link below for details. You can use the R56 “S” front rotors and R50/R53 rear rotors on your first gen factory JCW.
https://new.minimania.com/Mini_Coope...lacement_Guide
Old Mar 2, 2018 | 07:01 AM
Minibeagle's Avatar
Minibeagle
Originally Posted by JackMac
You can use the R56 “S” front rotors... on your first gen factory JCW.
+1 for this
That's what I did. Bought R56 front rotors from my 2006 JCW July build. Fit perfectly.
Old Mar 2, 2018 | 08:16 AM
wikdr53's Avatar
wikdr53
Cool. I am going to guess the rears are the same as the R56 as well. It would seem that our cars are essentially 2007 models in relation to the brakes.
Old Mar 2, 2018 | 09:16 AM
wikdr53's Avatar
wikdr53
Update. After finding some parts diagrams, the rears share the same rotors. However the calipers are different as are the pads.
Old Mar 2, 2018 | 01:12 PM
JackMac's Avatar
JackMac
Please check the link I provided a few posts back. The R52 rear is the same as the R50/R53.
Old Mar 2, 2018 | 01:52 PM
wikdr53's Avatar
wikdr53
It is different from the R56 for the Pre July 2006 models. However after July 2006, the rear rotors are the same part number as the R56's, I am guessing due to the 14mm lug holes. The calipers and pads are still different though.
So as best as I can figure, I can order the 2007 R56 S Stoptech street brake set plus an extra set of street 2006 R52 rear brake pads. That should do the trick, though I will have an left over set of rear R56 pads.
Old Mar 6, 2018 | 01:37 PM
7/2006 was the split year from m12 to m14 bolts so the rotors have larger holes.
We have them here, the rears just have the larger bolt holes and are shared on the rotors.
https://www.ecstuning.com/Mini-2007-...aking/Rotors/2
Mike1968NM
R55 :: Clubman Talk (2008+)
May 15, 2009 07:14 AM
schreyerplace
May 24, 2008 01:09 AM
pearface
Jun 11, 2006 04:10 AM
Ranzo
Oct 9, 2005 09:13 PM
MiniEd
Oct 18, 2002 08:08 AM
