JCW Brembo GT Big Brake Kit
Old Aug 20, 2016 | 02:30 PM
NellyRod's Avatar
NellyRod
Has anyone replaced their factory JCW BBK with the Brembo GT BBK? Overall diameter is larger by 10 mm. Pistons remain the same with 4. The biggest advantage I see is the two piece rotor for weight savings. Does anyone have experience with the GT kit?
https://www.ecstuning.com/Mini-2015-...992/ES3142527/
Old Aug 21, 2016 | 12:01 PM
sootyvrs's Avatar
sootyvrs
Someone on the forum with MCS installed these instead of the JCW Brembos below
https://www.northamericanmotoring.co...led-today.html
He has since sold the car I believe... Not read anyone who has replaced the JCW brakes with them though
Old Aug 21, 2016 | 01:52 PM
vetsvette's Avatar
vetsvette
Moderator
Biggest disadvantage I see is shelling out $3500 when you already have Brembo brakes.
Old Aug 21, 2016 | 03:18 PM
NellyRod's Avatar
NellyRod
I agree. I'm not a fan of heavy one piece all steel rotors/hats, which is why I'm considering these. I'm going for unsprung weight reduction. I have a set of HRE R40 wheels on order, and already have a complete set of TiKore titanium lugs. A two piece BBK will be the next step. I do agree they're pricey, but not as pricey as Brembo's GT R kit for the F56 ($7500)
Old Aug 23, 2016 | 02:08 PM
Yea, if you have the JCW brakes, the big change is the weight and the two piece rotor, GTR are big money and they are a little higher in price on the BMW side, but not by much. Machined Billet monobloc 4 piston caliper.
https://www.northamericanmotoring.co...cs-tuning.html
They look awesome on Pertplus's MINI linked above.
Here is one of the pics.
Old Aug 23, 2016 | 09:24 PM
NellyRod's Avatar
NellyRod
They look really good on the PertPlus's car. Even though the rotor is slightly larger in diameter compared to the stock JCW BBK, it looks like the annulus on the GT BBK is smaller. Is that the case, and would that reduce stopping power in exchange for a lighter rotor?
Also, would the GT BBK caliper require more clearance that the factory JCW BBK caliper?
Old Aug 24, 2016 | 01:12 PM
MiniF55's Avatar
MiniF55
Nelly, if I can recall correctly i believe the JCW pro needed more clearance. The calipers on those bad boys are chunky. I'll try to find the original thread where they were fitting the BBK on different setups.
Old Aug 27, 2016 | 11:57 AM
NellyRod's Avatar
NellyRod
Sad news, they won't fit. My wheels are 18x8 ET 45, and I'd have to run a 3mm spacer to clear the Brembo GT BBK Calipers. That's unfortunate because I was ready to throw these on the car. If only they offered this 2-piece rotor with a slightly thinner caliper.
Old Aug 27, 2016 | 12:20 PM
sootyvrs's Avatar
sootyvrs
Are you sure they wont fit? I have seen a set of enkei ts10 which have a similar flat spoke surface design in 18x8 et45 on a f56 jcw and seem to fit so you may get away without small spacer
Old Aug 27, 2016 | 12:31 PM
NellyRod's Avatar
NellyRod
I haven't tried to fit the Brembo kit myself, but HRE looked at the measurements of the GT kit and said it won't fit without a 3mm spacer. Apparently the GT kit caliper is slightly wider than the OEM JCW Brembo Caliper.
Old Aug 28, 2016 | 03:06 AM
sootyvrs's Avatar
sootyvrs
Looking forward to seeing the HRE's on the Mini when they arrive
Old Aug 28, 2016 | 07:25 PM
dube53's Avatar
dube53
For $8K, there is not much metal left on the surface LOL.
What is the cost to replace both rotors if wrapped?
I believe, very few are ready to spend that much money on brakes.
jcrane82
Apr 16, 2016 07:45 PM
quickcoop
Mar 28, 2016 02:58 AM
Yam the Bomb
Mar 26, 2016 09:58 AM
ntmid8r
Mar 22, 2016 09:42 AM
2minis
Jan 16, 2003 08:51 AM
