JCW NM Lowering Springs
Old Jul 17, 2016 | 11:16 AM
jobexo's Avatar
jobexo
NM Lowering Springs
I've had these on my JCW for about 6 mos now and I still haven't gotten rid of the creaky sound in the front struts when going over tiny bumps. I've tried putting the rubber sleeves all the way up at first and then one coil turn down as recommended but the noise is still there. Rides fine though; the creaky noise when backing up slowly and going over small bumps and speed bumps is just really annoying. Any help/tips would be appreciated. Thanks!
Old Jul 17, 2016 | 11:29 AM
MarioKart's Avatar
MarioKart
Vendor
Do you have camber arms or bigger sway bar?
mQubed Motorsport, Manic Tuning Dealer
Old Jul 17, 2016 | 11:39 AM
jobexo's Avatar
jobexo
I have the NM rear sway bar. No other suspension mods
Old Jul 17, 2016 | 11:40 AM
MarioKart's Avatar
MarioKart
Vendor
Make sure it's greased and the lower OEM camber arms.
Old Jul 17, 2016 | 04:16 PM
vetsvette's Avatar
vetsvette
Moderator
Yup. Sounds like sway bar mounting brackets need a little love. That's why I installed the brackets w/grease fittings from NM.
Old Jul 17, 2016 | 04:20 PM
jobexo's Avatar
jobexo
The NM rear sway bars were greased a lot when I installed and as I mentioned in my original post, the sound is coming from the front springs :(
"I've had these on my JCW for about 6 mos now and I still haven't gotten rid of the creaky sound in the front struts when going over tiny bumps."
Old Jul 17, 2016 | 04:26 PM
vetsvette's Avatar
vetsvette
Moderator
Can't help you there. My NM springs don't make a peep.
Old Jul 17, 2016 | 04:51 PM
MarioKart's Avatar
MarioKart
Vendor
The NM rear sway bars were greased a lot when I installed and as I mentioned in my original post, the sound is coming from the front springs :( "I've had these on my JCW for about 6 mos now and I still haven't gotten rid of the creaky sound in the front struts when going over tiny bumps."
I had a front squeak before, when the top front strut nuts, where a half a turn too loose
Mike Isaacson
Mar 29, 2016 07:58 AM
Yam the Bomb
Mar 26, 2016 09:58 AM
mexminime
Mexico
Sep 1, 2003 01:34 AM
TwOMINIs
Suspension
17
Jan 17, 2003 11:41 PM
Verruckt
Suspension
Nov 14, 2002 06:27 PM
