R50/53 Front Strut Mount Trouble
Old Mar 27, 2016 | 09:28 PM
Mike Isaacson's Avatar
Mike Isaacson
I habe a 2002 R53 with the JCW suspention. One of the bolts on my front strut mount sheared off, and I've got a bit of shrooming, so I am in the process of replacing the mount. Actually doing both, as they are 14 years old.
I have the strut off the car, and the spring compressed, but for the life of me I cannot break the center main top nut loose. I've got a socket on it and my hex key keeping the shaft still, but I am actually starting to bend the hex wrench instead of freeing the nut when I try to get it to turn.
I've tried some PB Blaster on it, but it's still stuck. Any suggestions on getting it loose so I can swap the mount?
Old Mar 28, 2016 | 12:36 AM
gdomingos's Avatar
gdomingos
Originally Posted by Mike Isaacson
I habe a 2002 R53 with the JCW suspention. One of the bolts on my front strut mount sheared off, and I've got a bit of shrooming, so I am in the process of replacing the mount. Actually doing both, as they are 14 years old. I have the strut off the car, and the spring compressed, but for the life of me I cannot break the center main top nut loose. I've got a socket on it and my hex key keeping the shaft still, but I am actually starting to bend the hex wrench instead of freeing the nut when I try to get it to turn. I've tried some PB Blaster on it, but it's still stuck. Any suggestions on getting it loose so I can swap the mount?
I've dealt with this a few times. If you want to same the strut (no promises) use heat on the nut. If the heat doesn't work I'd just get a new strut casing and cut the nut off to reuse the spring bro.
Old Mar 28, 2016 | 01:05 AM
GPToyz's Avatar
GPToyz
are you using an impact gun? soak the bolt with some pb blaster, then hit it with an air impact
Old Mar 28, 2016 | 07:53 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I agree, if you have access or a friend with one, an impact may be helpful. We had to use one on our '02 R53.
888.280.7799 | 6am - 5pm PST
Old Mar 28, 2016 | 09:00 AM
Mike Isaacson
I don't have one, and my compressor is way too puny for even a small impact gun. But I'm planning on grabbing an electric one (~230 ft lbs) after work and giving it a shot. I'll let you all know how it goes, thanks!
Old Mar 28, 2016 | 06:16 PM
Mike Isaacson
Victory. The impact was the way to go. Why I didn't buy one of these a decade ago I'll never know. Bolts and nuts are flying off now.
Old Mar 28, 2016 | 07:14 PM
X757XVeritas's Avatar
X757XVeritas
You are buying the plates to reinforce your strut towers correct? Otherwise it will prolly happen again fairly soon. Might as well while you have it all apart.
Old Mar 28, 2016 | 08:17 PM
Mike Isaacson
Why yes, yes I am.
Old Mar 29, 2016 | 07:58 AM
PelicanParts.com
Vendor
They make such a difference for specific jobs like these. Sometimes I feel like the work I do on mine would have been way quicker if I just had one.
beemboy
Feb 29, 2016 08:24 AM
JCW_Coupe
Feb 26, 2016 05:33 AM
PelicanParts.com
Feb 25, 2016 09:21 AM
PelicanParts.com
Feb 24, 2016 08:51 AM
tretowrules
Feb 19, 2016 09:56 AM
