Spark plugs for 11 jcw r56?
You are in the Gen 1 JCW's
But I can help you.
The 2011 R56 JCW still uses the N14 JCW engine. You can use either ones listed. The JCW cars get them changes every 30,000 miles, so ore often then the Cooper or Cooper S.
http://www.ecstuning.com/Mini-2011-Cooper-R56-John_Cooper_Works-Coupe-L4_1.6L_N14B16C/Engine/Ignition/
Here is the Gen 2 section you need:
https://www.northamericanmotoring.co...cw-garage-231/
But I can help you.
The 2011 R56 JCW still uses the N14 JCW engine. You can use either ones listed. The JCW cars get them changes every 30,000 miles, so ore often then the Cooper or Cooper S. http://www.ecstuning.com/Mini-2011-Cooper-R56-John_Cooper_Works-Coupe-L4_1.6L_N14B16C/Engine/Ignition/
Did my fJCW at 30,000, most info states 30,000.
https://www.northamericanmotoring.co...-interval.html
They are boosted / modified and without testing all the options who knows if it really makes a difference or maybe causes a problem down the road, that's why we stick with stock unless a manufacturer states a cross ref or upgrade.
Thanks , you are welcome.
09R56
Nov 16, 2022 10:49 AM
blackie
Jan 18, 2017 09:56 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
