JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
1st gen JCW brake rotors
Old May 23, 2014 | 12:43 PM
replacement's Avatar
replacement
Any suggestions for R53 JCW front rotors with hats that won't rust (and rears to match)?
Seem to have limited options - found TSW rotors with black painted hats but no JCW fitment. Slotted brembos look nice but reviews say more rust than OEM. Have read good things about powerslots but don't know where to get them in JCW fitment.
Also need street/autocross pad recommendations while I'm at it, but have found much more info on that topic.
Old May 23, 2014 | 03:21 PM
Swimbaxter's Avatar
Swimbaxter
These might be a good option. I just got their Gen2 JCW rotors and installed them last night, They appear to be of great quality. http://www.ebay.com/itm/FRONT-REAR-BRAKENETIC-PREMIUM-Drilled-Slotted-Brake-Disc-Rotors-BPRS35616-/131181374873?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACooper&hash=item1e8b04ed99
These should be the exact size you need for your Gen1 JCW setup.
Old May 23, 2014 | 04:23 PM
ZippyNH's Avatar
ZippyNH
I suggest you check with wmw again.....
The gen2 "S" rotors are the same as gen1 JCW....many folks like the "red" pads from ebc....but I like akenebono pads...even less dust... But NOT a track pad...reds are a bit more versatile with better hot performance......
Old May 27, 2014 | 07:31 AM
replacement
Also didn't cross my mind that for stock/street class they need to be OEM equivalent, so no slots allowed... will probably just go with an OEM type rotor with this being the case, but I will check in with wmw.
Reading into the EBC reds they look like a good compromise for street/autox, might go that route.
Old May 27, 2014 | 02:41 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
"Plain Jane" CENTRIC Premium OEM type with the black painted hats are the best bang for the buck. For pads, you need some that don't require a lot of heat to bite. HAWK HP Plus should do the job.
Old Jun 29, 2014 | 05:58 PM
CARdiac's Avatar
CARdiac
Is this the same for the pads?
Old Jul 25, 2014 | 06:10 AM
"Also didn't cross my mind that for stock/street class they need to be OEM equivalent, so no slots allowed"
Back in the early JCW Gen 1 brakes days you could get factory cross drilled and slotted for the fronts.
We have ECS Geomet Coated rotors here in slotted or cross drilled and slotted, pair them with HP pads and you are good to go. There is a year split for brake rotors in 7/2006. So watch for that. They also come with free shipping within the contiguous US.
Front -7/2006 JCW brakes Pair 11.57" (294x22)
http://www.ecstuning.com/Search/SiteSearch/ES2538375__ES2538315/
Front 7/2006+ CW brakes Pair 11.57" (294x22)
http://www.ecstuning.com/Search/SiteSearch/ES2538380__ES2538316/
Rears are of course the same on JCW brakes package cars as the Cooper and Cooper S.
Rears - 7/2006 Pair 10.19" (259x10)
http://www.ecstuning.com/Search/SiteSearch/ES2537031__ES2536033/
Rears 7/2006+ Pair 10.19" (259x10)
http://www.ecstuning.com/Search/SiteSearch/ES2538053__ES2536038/
Here are the Hawk HPs
Here are the sensor front and rear,
Brake Pad Sensor - Front 34356778175
http://www.ecstuning.com/Search/SiteSearch/34356778175/
and
Brake Pad Sensor - Rear Part # 34356761448
http://www.ecstuning.com/Search/SiteSearch/34356761448/
Here are the pads. Hawk Pads JCW Gen 1 fronts
http://www.ecstuning.com/Search/SiteSearch/HB560/
and the rear which are the same as the Cooper / Cooper S, MINI had the same shape pad for the JCW's just had a different compound.
Hawk pads rear
http://www.ecstuning.com/Search/SiteSearch/HB445/
Don't forget the rotor screws, one per caliper. Put a little anti-seize on the threads and you are good to go.
Brake Rotor Set Screw - Priced Each 07136772426
http://www.ecstuning.com/Search/SiteSearch/07136772426/
Old Jul 31, 2014 | 12:58 PM
martinb's Avatar
martinb
Centric Power Slots! Forget drilled rotors if you're going to track the car.
Toolman
Jan 20, 2016 06:50 AM
thebordella
Aug 31, 2015 01:37 PM
fjork_duf
Tires, Wheels, & Brakes
Aug 16, 2015 04:38 PM
